Page 12 of 66 FirstFirst ... 289101112131415162262 ... LastLast
Results 221 to 240 of 1303
    Feb 2010
    #221
    sir sa may passenger seat po sa likod nya try mo open ung matting may makita ka dalwang lock dun open mo un you'll see the battery and the water reserve for the radiator. . .
    #222
    Quote Originally Posted by Surfee View Post
    gudam mga sir. . . do you happen to know the rigt valve clearance or tappet of our Z20 engine vanette? please i need to know. . . balak ko kasi check kung tama pa clearance or tappets ng vanette ko . . . kasi ang alam ko one factor din ung tappet sa gas consumption ng engine. . . thx in advance. . ..
    pre, i set mine to 10mil - intake and 12mil - exhaus medyo maingay but good power. you may try 8i-10e medyo tahimik.
    Feb 2010
    #223
    ok tnx sir shauskie i'll have mine adjusted tomorrow. . . nga pala sir do you happen to know if nabubuksan ung parang hood natn sa harap just like the other vans and trucks? and i'm wondering kung pano adjust ung headlights ntn? medyo mababa ksi ung dim ko eh. . . kahiya nmn sa kasalubong ko kung parati me nakabright eh ang lakas ng bright ng vanette salamat sir. . .
    #224
    hindi nabubuksan yung harap ng vanette pre...to adjust your headlight, open or remove mo yung mga round rubber na takip sa mga butas sa loob ng van sa tapat ng likod ng mga headlight. dun sa mga butas mo iaaccess yung mga adjustment screws for headlights. (high ang low beam - 2 screws each ligth so 8 na butas yun lahat).
    Feb 2010
    #225
    ok salamat sa reply sir... kala ko nabubuksan hehe. . . i'll try to adjust my headlight later salmat po. . .
    #226
    Yup,- medyo nga mababa ang ating low beam. Kita mo when you're by yourself in a dark road..... However, I have not adjusted the headlights....
    9505:spam:
    Feb 2010
    #227
    *sir shauskie
    gudpm sir, i had mine adjusted na po same as yours 10m intake and 12m exhaust, normal lng ba ung parang ingay na may kalansing sa engine? un ba ung ingay na sinasabi mo sir? ksi ang naalala ko sa corolla namin dati sabi pag may ganong tunog daw tope daw ng engine un eh. . . hope hnd naman kasi kung hindi papaulit ko sa mechanic na pinagawaan ko. . . pero ramdam ko nagbago hatak. . . mas malakas nga compare sa dati. . . thx sir. . be waiting for your reply and feedback salamat.
    #228
    guys san banda nakalagay yung thermostat ng vanette? madudukot ba ng kamay?
    and bat ang hirap makapasok dito sa tsikot?? waaa
    #229
    *sir shauskie
    ang alam ko iba ang tope na sinasabi...related sa ignition timing yun...engine pinging...happens when you accelerate hard or paakyat..nawawala pagnakabwelo na. yung ingay na sinasabi ko sa valvetrain medyo mahirap idescribe ang tunog e..pero sounds like rattling lalo pag bago ang oil mo..kasi nga medyo malaki ang mga clearances. ganun yung sa vanette ko..pag medyo nag-aalanganin ka sa naririnig mo pwede mo rin muna try pabawasan yung clearance then compare mo yung result..baka lang kasi magkaiba tayo ng sinasabing tunog e..or try mo patingin sa ibang mechanic baka iba rin diagnosis nila para maverify mo ng maigi.
    * sir nismo..di mo madudukot ng kamay..nakakalungkot na kailangan bakalasin yung cover under passenger sit. dun nakatapat tabi ng intake manifold, likod lang ng power steering pump. dun sa housing ng thermostat nakakabit yung return hose ng radiator.
    Feb 2010
    #230
    guys and mga gurus. . i've read something about sa engine ng dating vanette na A15 it's a 1.5L engine na pang vanette. . . do you happen to know more info. about this engine. .. meron kaya dito nyan sa pinas? baka sakali tumipid tyo sa gas pag yan ang engine na ipalit. . . any opinion on this mga sir? i'll be waiting for the inputs and comments mga sir. . . thx. . .
    Feb 2010
    #231
    gudpm mga sir. . . ask ko lng po does anyone have any idea kung how much ang price ng mga parts na ito for our vanette:
    fuel filter
    contact point sa distributor
    tensioner bearing
    repair kit for the carburator
    thx po. . .
    Feb 2010
    #232
    mukang wala na post dito sa thread about vanette. . .
    #233
    Am still here, but I have no answer for your queries. Contact point should be cheap, P100ish.... That's about all that I can answer to you...
    Apr 2010
    #234
    May binebenta po sken n Nissan Vanette99 model mganda po b un? based po kc s mga nbasa k dito thread eh ung ibang model like 94 model ng vanette eh mlakas maginit ang makina. thank you po.
    Feb 2010
    #235
    *kharen
    ok yung 99 model na vanette or what they call the grand coach. . . wala na cyang overheating problem just like mine. . . kasi tama na yung position ng condenser. . .
    Aug 2007
    #236
    Hi, just want to share. my vanette spews white smoke a few weeks ago. I had it checked and my mechanic suggested to check the piston rings as he was certain the problem emanates from there. he was 100% correct. Had it overhauled and I love how it drives now.
    I need to check my front shocks also but I can't seem to find them.
    pls help me locate these shocks. I'm planning to try the KYB gas.
    thanks.
    Apr 2010
    #237
    Mga tol, saan tayo makabili ng Z20 engine or engine block/ taga Cebu po ako ,pls tulong !!!
    Apr 2010
    #238
    hi, Z20 engine block was damaged, i need to replace it, pls help me where to buy.....tnx
    Feb 2010
    #239
    *reno
    why sir? ano nagyari sa engine block mo? i'm planning to have my vanette engine swaped to a diesel. . . pag natuloy yung swap ko pm kita about my engine maybe i can sell it to you at a low price. . . very good condition po ito and no leaks or what so ever. . . regularly maintained the only reason i'm going to swap it with diesel is because of it's fuel consumption. . . hehehe
    Apr 2010
    #240
    fuel filter
    tensioner bearing
    thx po. . .
    Sir , estimated prices for your inquires;
    fuel filter - 200 - 250 Vic ang brand
    contact point - 220 -250
    tensioner - 250 - 300
    carburator repair kit - 650 -750 japan
    this prices are here in cebu mas mura siguro sa maynila.
Nissan Vanette [Merged threads]
