Results 91 to 100 of 1303
June 17th, 2009 11:30 AM #91
Our Vanette model is 1998. And it had only 1 aux fan on a horizontal-positioned condenser that is below the radiator.
The other condenser is placed in front of the radiator and had no aux fan. Just the regular clutch fan. This is the condenser that we repositioned horizontally below the front passenger seat and for which we put in another aux fan....
Agree. It is smoother to use the Vanette. This is my favorite vs. our other 2 Y2005 vehicles....
My favorite feature in this vehicle is the pop-up rear glass. With this, you can efficiently store a lot of stuffs at the back of the vehicle. All current van offerings do not have this cool feature so it is hard to stuff the vehicle from the rear...(SUVs have this though....)....
8101:oops2:
June 17th, 2009 05:08 PM #92
cool nga ung rear glass window
gustong-gusto ni esmi un, kasi pag nag-grocery di sia hirap iaangat ung buong pinto
last saturday pala, nagkarga ako 500 xcs/ 7 adults, 5kids. taguig-to-antipolo (via marcos highway) then cogeo then balik taguig. then nung monday and tuesday ito ung route ko, taguig to libis, libis to ayala-ayala to taguig (monday/tuesday, 2pass), may onti pang gas. not bad for a "gas-guzzler"
- May 2009
- 18
June 17th, 2009 07:49 PM #93Mga Vanette owners,
Maraming salamat po sa inputs nyo about sa tanong ko. Sensya na at ngayon lang ako nakareply. Its been awhile bago ako naka log in uli eh. Right now nagtitingin tingin pa din ako at nagbabasa sa mga threads dito. Mahirap talaga maghanap ng sasakyan lalo na kung medyo limited ang budget. hehehe...try ko din check ang mga FC ng ibang van para mas magkaroon ng comparison. maraming salamat po uli...
June 18th, 2009 08:12 AM #94
Pareho pala tayo,- very convenient iyan lalo na sa mga grocery items.... Kaya nga ito rin ang paborito kong dalhin pag naggo-grocery kami ni wifey.... Pag nakikita ko ang mga nag-i-stock ng grocery items sa likod ng ibang van,- nakakaawa.... :hysterical:
Whew! Way to go with your baby Vanette bro.!
8101:oops2:
- Dec 2006
- 273
June 21st, 2009 07:51 PM #95Magandang i-drive ang Vanette, lalo na ang suspension nya, superb. Mas napapagod akong i-drive ang kotse keysa Vanette.
June 23rd, 2009 08:23 PM #96
June 24th, 2009 11:42 AM #97
I have to disagree with you on this, bro.
Matagtag ang Vanette, dahil leaf spring suspension ang unahan at rigid axle naman ang likod.... Para kang nakakabayo lalo na kung kaunti ang sakay. Dapat palaging puno, pero matagtag pa rin....
And overtime, lumalambot ang leaf spring,- kaya dumadapa ang unahan....
8101:oops2:
- Sep 2008
- 6
July 7th, 2009 01:01 AM #98ano po ba ang PCD ng mags ng vanette? saan din shop sa quezon city ang meron mura at maraming available parts ng vanette?
- Jan 2006
- 230
July 9th, 2009 05:06 PM #99hi all,
i owned a 93 vanette, two weeks ago maganda takbo then tumirik, found defectvie fuel pump. napalitan ko na ng bago saka yung fuel filter. but last week naman, bigla na lang namamatay engine. palit na ako ng point, condenser, sparkplugs. kinalas ko na rin carb, bagong linis. one click in the morning but engine stall after few minutes of driving without pattern. hard start na pag namatay. intermittent stalling also while driving. had my coil for resistance check, normal temp ok naman, 1.6 ohms. tama rin yung ballast resistor and connection. pagtinest ko coil after mamatay, malakas din naman spark, medyo puti (even jump on 5/8" - no load, sa engine block lang). done also valve clearance adjustment..10i/12e..anyone experienced same trouble? baka alam nyo na, help naman. di ko pa pinalitan coil kasi based sa test na ginawa ko parang ok naman but possible parin kaya na coil pagmedyo umiinit na? gamit ko shell E10. possible din kya na bad gas (too much alcohol content)? hope to here some tips. thanks. baka may kakilala rin kyong mekanikong sanay sa vanette natin...
July 9th, 2009 05:49 PM #100
cc81352 saan ka sa taguig medyo out of topic?
btw mga pafs lagi ako nauuntog sa vanette pag sumasakay ako sa likod
So tl;dw: GM has a massive engine recall going on. For affected cars they will inspect the...
Mineral , semi synthetic or fully synthetic?
