Page 25 of 470 FirstFirst ... 152122232425262728293575125 ... LastLast
Results 481 to 500 of 9388
    Jan 2003
    #481
    Thanks for the welcome guys. It's been great so far (smooth enough ride, ease with steering, medyo 6.5km/l lang because of heavy traffic lagi dinadaanan ko), I can give more feedback after a few weeks of breakin and getting used to driving it.
    I got the GLS color red, very minimal waiting period about 2 - 3 days.
    BTW, does anybody out there know the recommended Tire Pressure (stock tires and rims) for this?
    Quote Originally Posted by rsyu_88 View Post
    yap wala talagang remote. the manual says its optional. congrats sa new montero mo.
    Oct 2008
    #482
    ^ i don't think you can go wrong with tire pressure of between 32-35psi.
    Sep 2008
    #483
    Quote Originally Posted by N T Y c E View Post
    All it does is it starts the measuring of the fuel consumption again.. if you don't reset, it will give you data from the time you start using your car until you reset it.. So its as if, when you get gas, it would be good to reset it before you go so that it'll start with new data. Rather than an average from the beginning.
    a okie bcoz sometime i notice the numbers like the km/L and the speed avg is not moving so i press the reset. Nxt time ill try not to reset it but as for your FC is it actual in manual computation and onboard computer?
    Oct 2008
    #484
    ^ who knows.. i really doubt that its really really accurate. Whatever number is coming out, all we can do is believe that its the correct info?
    But we have an american car that has the fuel consumption gauge also.. i really don't think its real time.. since it'll say 100km to go before tank empty.. but go for another few km and it'll drop to like 50km. so its really hard to use that as your gauge for fuel consumption.
    my advice to everybody who loves setting up their cars.. or even just sounds.. take the display out and put a touch screen dvd head unit! There's actually a provision behind the display for a 2-din headunit!
    May 2005
    #485
    To All owners of New MS, Bagay kaya tong tires nato sa MS nyo?
    Post kayo ng pics pag may nag try.
    Oct 2008
    #486
    sorry, not my cup of tea.. i'm more of the "bling-bling" look.. go with the biggest possible set.
    Oct 2008
    #487
    i prefer the swuabe look...parang kay KCboy...
    I'm getting 7km/l on the MS...that's manual computation. 80% City Driving.
    #488
    for those who are wanting to install a turbo timer to their MSs, i believe the strada's turbo timer will fit in the MS, you can check out miggyboy.com and have theminstalled at their shop in caloocan. if you guys know or have installed any new accessories on your MS, kindly post it naman, am looking for things to add to my MS.
    Sep 2008
    #489
    Quote Originally Posted by KCboy View Post
    pareng KCboy got my montero na..btw para san ba yung binabangit mong turbo timer?
    Dec 2007
    #490
    Turbo timer
    From Wikipedia, the free encyclopedia
    A turbo timer is a device designed to keep an automotive engine running for a pre-specified period of time in order to automatically execute the cool-down period required to prevent premature turbo wear and failure. After a period of driving when a turbocharger has been working hard, it is important to let the engine run at idle speed for a period of time, allowing the compressor assembly to cool from the lower gas temperatures in both the exhaust and intake tracts. At the same time the lubricating oil from the engine is able to circulate properly so the turbine won't burn the lubricating oil that would otherwise be trapped within the charger with the turbine rotating at high speed. With regard to modern automotive turbochargers, the need for a turbo timer can be eliminated by simply ensuring the car does not produce any 'boost' (during driving) for several minutes prior to the ignition being shut off.
    Most turbo timers are based on digital electronics.
    Sep 2008
    #491
    Quote Originally Posted by woohoo View Post
    Turbo timer
    a ok tnx sa info kinda complicated hehehe
    Dec 2007
    #492
    Simply put, mainit kasi ang turbocharger. Di ba metal expands when heated? Para hindi mabigla ang pag-"liit" niya habang lumalamig, dapat hinay-hinay din ang pag-lamig, kaya sabi "it is important to let the engine run at idle speed for a period of time..." o kaya, kung walang turbo-timer, bago mo patayin ang makina, maghinay-hinay na lang ng takbo pag malapit na sa paroroonan, para hindi na mag-activate/boost iyung turbo, parang iyun na rin iyung "idle speed for a period of time"...
    Isabay mo na rin ang pagpatay ng A/C compressor (naka-todo ang FANs) habang pinalalamig ang turbo, para maibuga palabas ang lamig mula sa aircon ducts, para hindi pamahayan ng molds...
    Oct 2008
    #493
    tagal mag antay ng white gls se, red lang yung dumating sa mitsu cdo tried the cool silver nung dinala nila sa pagadian 101% better than the fortuner hahaha sa fortuner kasi after 10-15mins of driving parang kelangan ko na ng back massage.
    Oct 2008
    #494
    Fyi to everyone who wants/wanted the white MS.. i heard from a source, that the story the showrooms have of the white not being delivered to the philippines from thailand is false. the real reason why the white units aren't coming out from the plant is because the paint of the white units have faded. The paint of some of the units were ruined in the plant from being under the sun the bird droppings. The pearl white paint that they used aren't of good quality hence the fading and damaging. So right now, they are repainting or 'touching up' the white units. Hence the delay.. so for those who insist on white, pls check the paint thoroughly before recieving the unit.
    KCboy. what are your plans with your MS? i'm very much interested in hooking mine up too.. right now, i'm just waiting for the lowering kit for it. The front is easy because its the same as the strada.. its the back that's a problem, we tried using the old montero's springs but it was smaller.. i heard that the rear suspension might be patterned after the fieldmaster.. So we'll try that next, problem is the fieldmasters springs are out of stock and there aren't many in the phils that are lowered so its hard to know for sure until we get it in stock.
    Oct 2008
    #495
    dumarami na mga montero sa kalsada...from las pinas to makati...i've seen 3 black gls and 1 red gls.... everyone's getting the low-end variant. great value talaga...hehehe
    Nov 2006
    #496
    Re: sa turbo timer. Optional lang po ba ito? Kasi sabi ng SA namin. Ok na daw na i-turn off ang makina di tulad ng old pajeros noon na kailangan pa ng cool down period bago patayin ang makina.
    #497
    Quote Originally Posted by lilv View Post
    no matter what they say about not needing to cool down the turbo, you really need to do that, whether a turbo timer or you wait a few minutes of idling before you turn off the engine....the bad effects are more of long term if you dont take care of your turbo. turbo leaking, loss of power, etc...so please take care of your turbo....
    Nov 2006
    #498
    Thank You Sir KCboy, siguro hahanap nalang ako ng turbo timer. As said from the earlier post, Mas cheaper magpakabit ng turbo timer kesa masira ang turbo in the long run
    Jan 2008
    #499
    Hi, sa mga new owners ng MS, meron ba kayong alam kung me lalabas na 2.5 version nito at manual tranny? Medyo costly ang maintenance ng 3.2 lalo na at auto tranny pa. Sana dumami pa ang variants ang MS, katulad din ng sa fortuner. I'm planning to have MS kasi this coming November kaya lang di ako ganado sa automatic transmission eh. I always prefer the manual one. Sana somebody enlightened me if there are coming variants ng MS na manual at ang engine eh medyo di magastos i-maintained at lower ang engine displacement pero di compromise ang torque at horsepower rating.
    #500
    you can always do the waiting and idling thing for the first year or so of your MS, baka kasi they might void your electrical warranty, just dont let the rpm go past 1000 in your last kilometer or so of driving so that the turbo wont heat up that much then let the engine idle for 30 secs to 1 minute, i personally think that's good enough.
