Page 20 of 470 FirstFirst ... 101617181920212223243070120 ... LastLast
Results 381 to 400 of 9388
    Nov 2006
    #381
    Lets start a Montero Sport owner's roll call!
    Tsikot Handle - Model - Color - Location
    (((example: ianmitsulancer - 3.2 GLS SE 4x4 - Silver - Baguio)))
    1.cashewchord - 3.2 GLS - White - Alabang
    2.leonleon - 3.2 GLS SE - Silver - Manila
    3. arkuo14 - 3.2 GLS SE - White - Manila (on the waiting list)
    6.
    7.
    8.
    #382
    Quote Originally Posted by KCboy View Post
    just to give you guys an idea of what you can do with the money you will be saving by buying the gls, but there will be more stocks of the gls se than the gls.
    hope you guys like the pic.
    WOW! I like your wheels bro! Parang stock na "high-end." Di ko maexplain basta yan ang mga style ng mags na gusto ko. It doesn't look like a GLS talaga... mahirap na talaga madeterming kung anong variant ang owned mo unless you get inside the vehicle or look for the rear emblem. KEWLNESS! Parang mas mataas pa na variant look ng MS mo ngayon.
    #383
    [quote=lilv;1128993]Lets start a Montero Sport owner's roll call!
    6. Omega16 - 3.2 GLS - Black - Makati (on the waiting list)
    7.
    8.
    Jul 2005
    #384
    congrats sa mga new and future owners ng mitsu montero. i myself nagandahan sa porma. kahit i-launch na ang 2008 fortuner i bet mas marami pa rin ang kukuha ng montero. aesthetics lang kasi halos ang binago sa fort. i guess our streets will be flooded with monteros by next year. also, for those who will line up, better be ready to wait, say 6 mos kung humaba na pila. just like what happened to me in 2005 wherein the fortuner was selling like hotcakes..
    Apr 2006
    #385
    Quote Originally Posted by leonleon View Post
    For SE model you get these additional:
    1) Climate Control A/C
    2) All leather seats
    3) Hybrid LSD (Limited Slip Differential)
    4) 8-way power adjustable driver's seat
    5) TPMS (Tire Pressure Monitoring System)
    6) Rear fog lamp
    7) Wood grain accent (for GLS SE) v.s Titanium accent (GLS)
    8) Backup sensors
    Is it worth the difference in price? Personally, I think it is worth it.
    -> yup its worth it.. especially the Limited Slip Differential..
    The main advantage of a limited slip differential is by considering the case of a standard (or "open") differential where one wheel has no contact with the ground at all. In such a case, the contacting wheel will remain stationary, and the non-contacting wheel will rotate freely—the torque transmitted will be equal at both wheels, but will not exceed the threshold of torque needed to move the vehicle, and thus the vehicle will remain stationary. In everyday use on typical roads, such a situation is very unlikely, and so a normal differential suffices. For more demanding use, such as driving in mud, off-road, or for high performance vehicles, such a state of affairs is undesirable, and the LSD can be employed to deal with it. By limiting the angular velocity difference between a pair of driven wheels, useful torque can be transmitted as long as there is some friction available on at least one of the wheels.
    With a normal, or "open" diff, if one tire loses traction and spins, the engine will send all of it's power to the wheel that slips... and none to the tire that actually has enough traction to propel the car. Replacing the diff with an LSD will reduce this tendency and put more power to the non-slipping wheel and less is wasted on spinning the other tire.
    When properly adjusted, it allows for better acceleration in the corners. If there is too strong a limited-slip effect, then both the inside and outside wheels will try moving at the same speed, or close to it; almost like having no differential at all.
    Apr 2006
    #386
    [quote=Omega16;1129033]
    Quote Originally Posted by lilv View Post
    7. JPG111 - 3.2 GLS SE - Black - Greenhills
    8.
    9.
    May 2007
    #387
    ayusin ko lang po...
    8.
    9.
    10.
    Dec 2007
    #388
    Wow, dami na agad ng tsikoteers na owners ng Montero Sports ah! Congrats sa inyo
    Jun 2008
    #389
    to the MS owners, have you tried connecting your USB port to your ipods? can we choose the songs through the ipod or do we have to control it via the head unit?
    #390
    Hi guys,
    im planning to replace the HU of my MS. lata ang sounds. any suggestions from the xperts where to put 10 or 12" subs and addtl tweeters.
    thanks and enjoy your new ride...
    Nov 2006
    #391
    Quote Originally Posted by arkuo14 View Post
    Yes you can use the USB port of the JVC headunit + the supplied USB cable of the iPod. You can't control the iPod once it is connected thru the usb. You can control it by selecting the source of the Headunit and pressing 1 to show the playlist of your iPod
    Nov 2006
    #392
    Quote Originally Posted by SNA View Post
    Hi guys,
    Sir may tweeter ba yung sa inyo sa front doors? sinilip ko yung MS namin wala naman tweeter na kasama. 4 speakers lang. kaya pala kulang sa high freq.
    #393
    YUp, dalawa ang twtrs pero yung crisps and clarity of sounds hinahanap mo pa e. well, the Mitsu dealer in Paco quote me 20K for the new HU AVT w/ small as in small ,TV screen. yung subs 9K , i have to look elsewhere for an alternative. thanks
    Dec 2004
    #394
    Is the new montero sport equipped with drive by wire throttle or cable pa rin?
    Jun 2008
    #395
    thanks for the quick reply lilv!
    hopefully the head unit wont lag when it browses thru the songs... maybe a good pair of seps would kick things off nicely... for starters...
    May 2005
    #396
    #397
    just to let you know montero owners, when using the shift othe fly 4H, release your foot on the gas pedal and shift to neutral, then shift to 4h...you'll be on 4wd high already. then put the transmission to D.
    Oct 2007
    #398
    What do we really have to do that? Sa xtrail ko you can shift to 2WD, real time 4WD or full time lock 4WD, and v-v in just pushing buttons while you are running on D, 2, or L.
    Nov 2006
    #399
    Nafeel niyo ba when shifting to drive medyo umaangat ng konti yung likod ng MS? Then shift it back to Neutral, naglelevel yung sasakyan? Tapos sa Reverse naman medyo naglolower ng konti yung rear ng MS
    #400
    Quote Originally Posted by kokey View Post
    yo kokey musta na? tagal mo ata di nagparamdam sa forums ha? ano galit ka pa ba sa starex? LOL! montero sport na lang tayo dude! hahaha!
