Page 55 of 162 FirstFirst ... 54551525354555657585965105155 ... LastLast
Results 1,081 to 1,100 of 3240
    #1081
    Approaching 15k PMS now, (Monty is 7 months old), and I am really more of a DIY person. Sabihin man ng iba I am being "kuripot", pero I am now leaning towards opting out from Casa, and have it serviced by MitsuPrime in Las Pinas and get the opportunity to watch over how they do things and eventually be able to master the craft myself.
    Given that I havent had any mechanical, electrical issues since I got my MS inspite of heavy use during long drives, my big question is --- What are the usual/common warranty claims you already had? Weighing in risks for future warranty claims versus just buying/paying those parts myself outside.
    #1082
    Quote Originally Posted by ash0279 View Post
    May nakasabay ako sa Casa, engine for montero & AT for Mirage. Yung kapitbahay namin yung turbo/egr 2yrs pa lang (slightly use).
    our monty's abs sensors went bonkers just before its 10k pms. the casa replaced it w/ little fanfare naman
    #1084
    Quote Originally Posted by Noel Salisipan View Post
    thanks sir noel. ano kaya details nung engine warranty claim for the montero?
    regarding sa turbo naman, i will research further on what are the common cause of failures.. appreciate na rin if you can share here further details kung ano nangyari sa turbo nung neighbor niyo.. right now, i already have an OCC as an initial care for the turbo, plus ensuring i will stay within factory settings not to play with it. (i.e wastegate actuator settings, etc.)
    Aug 2003
    #1085
    Sir ash, nothing wrong with your choice not to have service sa casa. At least you know your car is properly maintained because you are on top of things concerning it. Also since you are a forumer, you are informed about the do's and don'ts sa montero. Baka yung mga nasiraan ng turbo e after revving patay agad (old school driver) o kaya short trips hinintay yung scheduled PMS ng casa yun pala sludge na yung oil. Yung EGR naman e linis linis lang katapat niyan. SCV upgraded na, basta malinis diesel mo, tatagal yan.
    May mga minor issues na pwedeng kahit maingat ka e affected like the fuel filler and tank rust.
    #1086
    Quote Originally Posted by ek2jayvee View Post
    *ek2jayvee - i really appreciate your insights sir. this made me more confident sa plan ko on self-maintenance or at least non-casa maintenance. and yes, i really want to be on top of things concerning my car. also, i will try to my best to stay updated dito sa forums para lalong ma-inform ako sa mga maintenance tips, tricks, do's and donts.
    Aug 2013
    #1087
    Hi guys!
    Anyone here who has the price list of the PMS? up to 150,000 km for every 5,000 km PMS? TIA
    Mar 2007
    #1088
    Ranges from 15K to 20K sir...
    thanks sir
    #1089
    Quote Originally Posted by matty View Post
    With delo 400 sir and baldwin, change oil ka every 5k pero yung filter di mo pinapalitan or palit din? and if you don't mind magkano kuha mo sa delo 400 sir?
    Sir yung delo 400 kuha ko sa caltex aurora 256/L. Ang baldwin bd28 pede hanggang 10k km so d ka palit every 5k. HTH
    #1090
    Quote Originally Posted by jj10910 View Post
    thank you sir jj.
    just talked to my SA sa diamond valle verde, no problem in bringing my own oil basta right viscosity daw pero yung oil filter ang medyo nag-alangan sya. didn't argue na for the sake of warranty hehe palit na lang every 5k.
    #1091
    by the way, 5w-40 is ok for our ride? kasi sa manual at booklet 15w-40 ang nakalagay e.
    Dec 2009
    #1092
    ^15w40 mineral (cheap, prone to gumming or gelling, recommended for 5thou km oil change interval)
    10w40 semi-synthetic (moderately expensive, resistant to gumming allows extension of oil change to 7thou km to 8thou km)
    5w40 full-synthetic (expensive, more resistant to gumming allows extension of oil change to 10thou km)
    w stands for WINTER which is not applicable to the type of weather there is in a tropical climate
    #1093
    ...5w40 full-synthetic (expensive, more resistant to gumming allows extension of oil change to 10thou km)
    Hindi ba mas prone naman sa sooth at sludge pag FS ang gamit sa Diesel engine?
    Nope, nasa engine design ang problem nang soot at sludge with how oil is made right now. Maganda na ratings nang oil ngayon kasi.
    #1095
    Pero hindi advisable ang FS sa diesel engine with DPF?
    (hindi rin basta nasusunog ang FS na nakakalusot sa piston chamber kaya nagkakaroon ng sooth at sludge?)
    Apr 2012
    #1096
    i believe merong mga oil na compatible sa mga may particulate filters.
    yung oil na lumulusot sa piston chamber ay sumasama sa blow by gases, that's the reason why you need to have an OCC para masalo at di magbuild-up ang sludge sa intercooler mo. intake manifold build up of sludge naman is caused mainly by the EGR.
    #1097
    Isarado na lang natin egr, then mineral o semi-synthetic na lang ang engine oil? O sapat na OCC?
    Apr 2012
    #1098
    sir noel, marami naman nagsarado na ng EGR nila. it's a matter of choice between your contribution to the environment or added performance and longevity of your ride. FS pa rin ako na oil. maaring di sapat ang occ, as i mentioned earlier you're just preventing oil going with your blow by gases to your intercooler
    #1099
    Thanks Monty, makes thing clearer na!
    Aug 2003
    #1100
    Pag may DPF dapat API CJ-4 ang oil. Pero wala naman DPF all variants of Montero. CI-4 pwede na.
Montero Sport PMS Thread
