Page 65 of 162 FirstFirst ... 155561626364656667686975115 ... LastLast
Results 1,281 to 1,300 of 3240
    Aug 2005
    #1281
    Hello peeps, I've searched this thread containing "ML 109777" and ML 109770". Both are mitsu engine oils, and gave me negative search results. During my monty's 10k km PMS (I'm out of the country that time. The wifey was the one who brought the unit to SFM) the repair order listed the part no. of oils as mentioned during oil change, which I can't figure if those are mineral or synthetic. Does anybody know what kind/type of oils are those?
    Feb 2014
    #1282
    Quote Originally Posted by iwanttime View Post
    May AC air filter na OEM sa Banawe. 1,200 lang with free installation.
    iwanttime
    Hyundai Tucson Theta-II GLS A/T 2010
    Mitsubishi Monterosport GLS-V 4x2 DSL A/T 2014
    Mura tlg sa banaue. Sa casa 2,400 ang ac filter sobrang mahal dba.
    -ford fiesta M/T 2012
    -MonteroSport GLX M/T 2014
    Posted via Tsikot Mobile App
    Feb 2014
    #1283
    Quote Originally Posted by leinahtan View Post
    Nakalagay ung price jan pag nsa 550 per liter fully synthetic yun. Ung ML n may # na sinesearch mo item code nila yun. I think FS yang nilagay nila ska bka yan nirequest ni wifey
    May 2013
    #1284
    Guys ok ba ang delo 400? Ty
    Apr 2013
    #1285
    Quote Originally Posted by Erwin-G7 View Post
    Try mo motul crdi. Or mag top1 ka nalang, Sakto sa baldwin filter mo. Every 10k na palit mo.
    Feb 2014
    #1286
    Had my 40k PMS outside casa, used 15-50 Whiz Syntha. 5 days palang gamit ko, so far so good, medyo maganda hatak ko. Let's see how will it do in the long run. Planning to changeoil after 4k kms.
    Sep 2011
    #1287
    Sirs, sino may obd scanner near paranaque? ) nag cel kanina montero namin while running e. Baka pwede magpatimbre )
    Mar 2005
    #1288
    Meron ako Scanguage II. Im from QC pero work ko sa North Gate alabang. Nag CEL din dati montero ko pinapatay ko muna then nung 2nd time bumalik dinala ko sa casa.
    Sep 2011
    #1289
    Nung pinatay ko sir, nawala cel e. Pero nung tumaas rpm ko around 2.5k, nag cel na uli.
    Chineck ko na engine oil, tranny oil, at egr. Ok naman yung fluid levels tsaka ung egr nag wowork naman.
    Try ko mag reset mamaya. Tangalin ko battery. Kapag bukas bumalik, dalhin na sa casa haha.
    How much bili mo sir jmpet sa scangauge?
    Apr 2010
    #1290
    did you get the error code? my guess is fuel filter related.
    Sep 2011
    #1291
    Quote Originally Posted by ezrydre View Post
    Not yet sir. Wala ako scanner eh. Onga no, nakalimutan ko check fuel filter. Pero kapag fuel filter, ibang ilaw ang iilaw diba?
    #1292
    Quote Originally Posted by babynos01 View Post
    i will just be in makati tomorrow 8-230pm, pwede natin check ang error code. but i have already encountered yung ganyan high rpm triggered cel, air filter clogged. did you replace air filter already? oem? sports filter?
    Sep 2011
    #1293
    Quote Originally Posted by zix888 View Post
    Hindi ko magagamit auto bukas sir e. Si erpats gagamit haha. Pero tinanggal ko air filter kanina. Binugahan ko ng hangin pati yung cabin filter.
    Pwede kaya dahil madumi maf sensor sir?
    Check ko muna thoroughly sir. Kakabalik ko lang ng battery terminal e. Road test ko ngayon and see kung babalik cel.
    #1294
    ano gamit mo air filter? oem? pwede madumi maf sensor
    Sep 2011
    #1295
    Replacement na air filter sir. Nakaka 12k kms na ako using a replacement filter. 2nd filter ko na ito
    After a 15km road test, bumalik din cel kapag mataas na rpm (2.5k above). Reduced power din above that rpm range. Ramdam mo talaga yung difference. 2.5k na rpm ko pero pagong bago mareach 100kmh.
    Katulad ng dati, kapag nagka cel, hindi ganon ka smooth yung shifting niya.
    Things i did earlier this morning na maaaring nagtrigger nito (in order of events):
    1. Nag rev ako upto redline while on N to remove carbon deposit. Twice ata. Na-notice ko na umabot siya sa redline, compared sa tucson namin na hindi nagreredline. It emitted a cloud of black smoke nung unang trial pero greatly reduced na nung succeeding trial.
    2. Had an engine wash sa suking gas station
    I noticed the decrease of power before i had an engine wash. Bumabyahe ako sa macapagal tapos nanotice ko na masyado mataas yung rpm ko para mag accelerate normally.
    Its been 2200 kms since our last oil change and atf change. Last month lang yun.
    Baka nasira ko oto namin : ))
    #1296
    may ticking sound pa ba egr valve mo after shut down?
    Sep 2011
    #1297
    Yes sir. Nung lumabas cel, huninto muna ako tapos chineck ko engine oil level, atf level, tsaka egr. May tick tick sound pag pinatay makina.
    Also cleaned the maf sensor and checked the intake tube after the air cleaner element. Sobra onti lang ng dust particles. The filter seems to be good naman kahit replacement.
    It could be a clogged fuel filter sir zix no?
    #1298
    possible. but better to have it scanned para exact solution
    Sep 2011
    #1299
    Sige sir. Nasabi ko na kay erpats kanina e. Baka next time madala kasi parehas kami busy.
    Feel ko nabara fuel filter kasi binigla ko silinyador haha. Bago pa naman yun. Nagpalit kami scv tsaka fuel filter nung september. Dapat ata pinababa narin namin yung gas tank para sigurado tsktsk.
    Jan 2010
    #1300
    hello sir, anong year model ang unit nyo? just hoping that your unit will be fine sooner, feedback na lang whatever solution or findings you might have with your car....
Montero Sport PMS Thread
