yung OEM front brake pads nasa 5.5k na sa el dorado. 4k naman sa rear.![]()
Anyone from Cebu City na nakapagpa install na ng OCC ska nagpa blank ng EGR? Any recommended shop(s)? TiA
I still prefer the OEM pads (Tokico), a bit pricey at 4500 (Mitsuprime) pero I think it's worth it. You don't have to worry about your pads squeaking or creating powder residue sa mags mo and ofcourse same braking feel, same braking power. Madami na nag try ng ibang brands then after a few weeks or months, magpapalit din to OEM simply because they don't like it. Doble gastos. This is just my opinion though, not in any way meant to force you to go OEM.![]()
Mga sirs, anu recommended niyo na oil for monty? and how much? 109k Odo - alagang kasa before until 100k. 1st time na lalabas ng casa. thanks.
Mine got serviced by Casa for only a year then inilabas ko na, 25k odo back then.
After that, I used Mobil Delvac 1 5w40, around P900/L, Oil change every 14k-15k kms with oil filter(OEM) change halfway at around 7k kms. Odometer now is at 95k kms, so far so good. HTH.
Yup. I agree that most oils give almost the same performance, it's just that I am a heavy user when it comes to mileage and I don't want to go change my oil every so often because my schedule might not permit me. I went for the oil which I think can be stretched and this is what I got. Another is, it has always been my belief that you buy the best oil you can afford.
Mga master ano ginagamit nyu na pang-correct sa maliliit na sira sa paint ng ride natin pra di mag tuloy kulay kalawang? TiA![]()
clear coat damage ?
Premium Scratch Repair Pen - Turtle Wax
You may check also the Turtle was Scratch Repair Kit. For light, clear coat scratches.
For scratches need to re-touch, you may try to google the " Color n Drive" site. Its a german tech., you just encode your unit color code if itts not on their list. Very fast reply, and good delivery service. Complete touch up paint kit na sya. I've tried it with my Deep Bronze unit, so far I was able to repair the scraches, but need several trials before I got a good results. Around 1-week only i received it from Turkey.
Mga master ok rin lng ba ang Shell HELIX ULTRA 5W-40 fully synthetic motor sa monty natin, GLS 2010 4x2 model po sakin.
Sent from my Z00D using Tapatalk
ano api rating?
nasa likod usually.
api-sm api-sn "s" is for spark. gas engines
youre looking for api-cj or api- ci+
"c"for compression ie diesel engines..
use imgbb and use the bbcode to imbed the pictures here..
