Page 153 of 162 FirstFirst ... 53103143149150151152153154155156157 ... LastLast
Results 3,041 to 3,060 of 3240
    Jul 2014
    #3041
    Question po.
    Kakasya ba ang Baldwin BD7028 sa Montero 4D56?
    Thank you.
    Sent from my SM-G7102 using Tsikot Forums mobile app
    Apr 2012
    #3042
    Quote Originally Posted by HugoThor View Post
    Not really sure about that, basta sabi nila tatangalin daw ung assembly and prang may computer na mag calibrate. Nwy try ko contact si Zix na lang, medyo nanga2pa pa ako konti, kc now lng nagka prob gn2, nsa manila din kc tong unit nilipat k lng here sa Cebu last 2015. Btw sa tires pla ok lng ang Yokohama Geolandar G056 265/65 R17 mas mura kc cya compared sa current tire k ngaun na Bridgstone. Salamat sa tulong sir!
    i have not use yokohama geolandar. you may want to check out gt savero at+, i'm on my second set na, so far ok naman...
    Quote Originally Posted by Mask Rider Blac View Post
    Question po.
    Thank you.
    anong model year sir? iirc, BD7028 will fit sa mga 2010 and earlier models.
    Jun 2012
    #3043
    Vs stock na HT, di naman maingay sa highway?
    Sent from my SM-A9000 using Tapatalk
    Apr 2012
    #3044
    Quote Originally Posted by dct View Post
    hindi naman sir...
    Oct 2017
    #3045
    Hi,
    Pahelp naman anong K&N air filter and cabin filter ang kailangan for monty 2017. Yun part number. Paturo naman po kujg paano hahanapin. Thanks
    Sent from my SM-G950F using Tsikot Forums mobile app
    Jul 2014
    #3046
    Thank you, Sir. Hindi ko sure kung anong year. Sabi lang ng kapatid ko 4D56 Turbo. Pero I believe pasok sa 2010 and earlier.
    Oct 2017
    #3047
    Hello sir
    Ano po yun model o product code ng K&N Cabin filter for montero 2017 gls premium ? Salamat in advance
    Oct 2017
    #3048
    [QUOTE=monty_GTV;2886347]i have not use yokohama geolandar. you may want to check out gt savero at+, i'm on my second set na, so far ok naman...
    Alright, il give it a try. Ilang years din ang lifespan nya?
    Oct 2017
    #3049
    Hello sirs
    Question lang po sa Cabin filter ng Montero 2017 Gls premium. Ano yun compatible equivalent nya sa K&N ? Thanks
    Apr 2012
    #3050
    * mask rider, you need to know the model. BD7028 will fit 2010 or earlier. kapag gen2 na 2011 and up to 2015, BD28 yung kasya.
    * hugo thor, lifespan depende sa gamit mo. iirc, 1st set ko lasts more than 86k+ kms, almost 3yrs used
    #3051
    15KKm PMS - P7.2K
    Practically oil change (semi synthetic)...
    Waived recommended cleaning of EGR and wheel alignment
    Condenser fan replaced under warranty (mabagal daw ang ikot - i have not noticed it,- so maybe caught through a diagnostic test).....
    Mar 2005
    #3052
    Peeps anybody tried using Blue Chem CRDI fuel additive? pros and cons?
    Sep 2016
    #3053
    What's the biggest tire size that can be installed in Montero without any lift/mods?
    Sent from my ONEPLUS A3003 using Tsikot Forums mobile app
    Nov 2014
    #3054
    Quote Originally Posted by Danilog View Post
    If you are using the OEM rims, you can use 265/70/17, but if you are using an after market rims with less than +30 offset, stick to 265/65/17. If you are using 20" rims, 265/50/20 will do.
    Sep 2016
    #3055
    Am using stock rims. Gusto lang sana lakihan gulong while maintaining stock. Thanks.
    ^ ganda nga tingnan iyong mga slightly malalaki gulong pero stock rims na naka a/t tires at mas lalo na naka mud tires. 😍
    Usong uso sa australia at russia ata iyong ganyang setup sa mga 2nd gen na monty aka challengers sa down under at pajero sport naman sa russia at ibang bansa. Bangis eh! 👌
    when you look into the abyss, the abyss looks into you
    Feb 2006
    #3057
    Meron po ba naka-eperience sainyo na bigla na lang hindi nag-accelerate while in drive mode? I experiencing this yesterday while I drove my montero 2011 matic in slow traffic but when I put it back to nuetral and back to drive again ok na ulit sya . Still observing it po if mauulit. Do you have any idea kung ano problema kaya? Salamat!
    baka inhibitor switch mo may problema. napalitan na ba iyang part na iyan before?
    if you're from manila, check w/ bro zix to be sure
    Feb 2006
    #3059
    Hindi pa po napapalitan almost nasa 60kms na ODO, ganun po ba symtoms pag-inhibitor switch may problema nawawala acceleration/rev nya on DRIVE mode need pa ibalik sa nuetral then back to Drive mode? Salamat po!
    Oct 2017
    #3060
    [QUOTE=HugoThor;2886585][QUOTE=monty_GTV;2886347]i have not use yokohama geolandar. you may want to check out gt savero at+, i'm on my second set na, so far ok naman...
    Sir, planning to have my EGR blanked, then bka try din K&N filter ska OCC. Newbie question lang, ano po advantage? Ska magkano din kaya budget na need allocate?
Montero Sport PMS Thread
