Page 151 of 162 FirstFirst ... 51101141147148149150151152153154155161 ... LastLast
Results 3,001 to 3,020 of 3240
    Feb 2006
    #3001
    ipa balancing mo muna at alignment kung makapal pa brake pads mo.
    kung manipis na brake pads at may tama rotor thats the time na need ng refacing. they need to machined the rotors to even and flat the surface para maganda lapat ng brake pads. yun kung may kayod o uneven yung surface, if not i sandpaper lang yan at cleaning. sa machining i think mahal yang 6100. yung bendix brake pads nasa 980 pesos sa LVC banawe dati bili ko, bendix db1774 GCT front, db 1390 rear. kung malapit ka o nasa manila ka rin lang dalhin mo na lang sa shop ni bro zix. oem yung brake pads niya malayong mas maganda kesa bendix
    Maraming salamat po mga bossing! May idea po ba kayo how much replacement for new rotors rather than pa refacing ko kung sadyang manipis na sya? Thanks
    Apr 2012
    #3002
    Quote Originally Posted by bsvubana View Post
    no need to replace the rotor, i reface lang siya kung may kayod o uneven tung surface. if wala naman as i mentioned, i sandpaper lang at sprayhan ng brake cleaner
    Feb 2006
    #3003
    After rotor refacing and cleaning of break pads yesterday, nawala na yun wiggle/vibration ng manibela ko when breaking at high speed (80-100kph). Dinala ko lang sa ordinary tires and mags shop and they charge me for 1,600 only for 4 phase refacing. Salamat sa mga advice mga master solve na problem ko!
    Apr 2012
    #3004
    glad to know na-solve problem mo. safe driving!
    Jun 2016
    #3005
    Hello Po.
    Regarding battery po
    Ok na po ba ang motolite enduro? Mas mura po kasi sya sa motolite gold. Thanks
    Ano po ba pinagkaiba ng dalawa? Warranty 15 months lng po si enduro, si gold is 21 months. Ano pa po ba advantage ng gold sa enduro?
    Thanks
    Apr 2012
    #3006
    Quote Originally Posted by nicoadik View Post
    Hello Po.
    Thanks
    nasa tanong mo na sir yung sagot, 6 mos difference sa warranty so mas shorter ang life ni enduro kesa kay gold.
    Jun 2007
    #3007
    Though im not expert sa battery, pero the difference could be the quality of materials used in each class of battery or could be the no. Of plates. Kaya mas mahaba ang buhay ng ibang batteries over the other. This is the reason why the warranty varies. I tried motolite gold several times sa civic at lhat naman ay lumagpas sa warranty period. Also the gs brand na tumagal sa kin ng 4years. For maintenance free batteries, after the warranty period, tinatanggal ko temporarily yung sticker sa ibabaw then dagdag lang ng distilled water. Naiiwasan ko yung biglang mamamatay na lang ang battery. Now, im using the ac delco brand para masubukan ko rin. Hth.
    Jun 2009
    #3008
    ah salamat po bossing, just want to confirm lang kung tama sinasabi mekaniko. He charge me po 6,100 for 4 phases refacing, replacement 2 bentex brake pad and brake fluids. Reasonable na po ba yun 6,100 at yun brand bentex pad? Salamat bossing!
    have you tried zix performange original tokico brake pads cost me 50% off casa price. reasonable rates.
    you can ask for estimates at no cost as all. Lahat yata ng kasuluk-sulukan ng montero eh alam nya. highly recommended siya
    Jun 2007
    #3009
    Nalilinis din ba ung evaporator ng rear ac ng montero? Meron bang separate filter un just like the front cabin filter.
    #3010
    bro ask ko lang yung amaron hi life pro battery ay nalalagyan din ba ng distilled water at paano, hindi ko makita yung hole na pwedeng lagyan ng distilled water
    Jun 2007
    #3011
    Never encountered an amaron battery pero for motolite, pretty obvious na pag tinanggal mo yung sticker, meron 6 cap covers na pwd mo i unscrew using a peso coin.
    #3012
    mga master plan ko mag 2 or 3 inches lift kay monty but no idea kung ano ang papalitan, priority ko is comport wala naman laging dalang mabigat except kung mag grocery o mag out of town, may nabasa ako sa ibang tsikot forum na pinalitan yung rear shackles with 2 inch lift, no idea kung ano yung shackle na yun, magkaiba ba yung shackle at spring na nakikita ko sa ilalim ni monty
    Apr 2012
    #3013
    ^ imo, compromise na ang ride comfort if mag lift. for reference, check mo fb ng blueline car accessories, atoy customs 4x4 and bodykits at jeff's offroad. marami silang pinapalitan ng suspension assy to give you an idea
    Jun 2012
    #3014
    Ano pa ba dapat gawin sa 2012 montero na nasa 51k pms na? Parang makupad na sya compared dati e. Di naman sobra. Hahataw pa rin. Pero medyo napansin ko na sluggish na. Change fluids na. Change oil na rin nung 48k km. Am i missing something?
    Sent from my HM 1S using Tapatalk
    ^ palit na kayo lately ng fuel filter? Everytime.change kasi ako nyan napapansin ko mas mabilis response ng Monty namin bro
    when you look into the abyss, the abyss looks into you
    Jun 2012
    #3016
    Pinalitan din sir nung mga 45k km e. Egr blanked na rin pala yun dati pa
    Apr 2012
    #3017
    Quote Originally Posted by dct View Post
    install a throttle controller bro, sisipag yan walang biro
    Jun 2012
    #3018
    Hehe. Pero nagtataka ako kasi bakit parang kumupad? I mean ok lang sakin ang takbo dati. Bakit kaya nagiba?
    Sent from my SM-A9000 using Tapatalk
    Apr 2012
    #3019
    nuon ganyan din unit ko. try mo bro palit air filter kung oem, linis lang if k&n, linis ng maf sensor, linis ng egr if hindi naka-blank. if malapit ka kay bro zix ipa-system check mo
    #3020
    Baka naman nagloloko na turbo niyan.
Montero Sport PMS Thread
