ok lang normal lang just dont beyond 2nd hole of dipstick
Thanks, Danilog/JMS12 for confirmation.
I think, moving forward, I'll just add 6 bottles of oil (5.6 l - 6 quarts) during oil change. I had 300+ km drive last weekend, checked the dipstick the day after, oil level is at the middle of min/max holes. It looks like I have been overfilling my engine.
May konting kabig ang 2012 montero namin. Pantay naman ang psi ng gulong. Ano next gawin? Alignment? Balancing?
Sent from my SM-A9000 using Tapatalk
If you have to choose between the 2, better to choose alignment. Best option is to do both. In Servitek, it would cost less than 1k to correct alignment (camber, caster, toe). It would cost around 500 for balancing of all the wheels, another 500 for rotation. So there, ~2k.
Tell tale sign of misalignment is uneven tire wear. Hindi pantay yung kain sa gulong, either sa loob lang o sa labas lang.
Bale 3 yung usually ina-adjust pag sinabing "alignment". Sasabihin naman nung technician kung alin yung kelangan i-adjust.
Guys,
Ask ko lang if anyone experiencing steering wheel shaking when braking at high speed 80kms-100kms? Ano kaya po problem montero ko at saan recommended nyo po gumagawa nun? Salamat!
Got my pair of bendix brake pads for my front wheel at approx 2t 6 months ago. Di ko pa napalitan yung likod pero brake drum yun. At least you have an idea how much would be the estimated total cost...
Uhm, parang ang mahal naman haha. Honestly, di ko na matandaan kung magkano inabot ng samin kasi that was more than 2 years ago pero sa labas lang din ng casa. Iirc, nasa 3-4k lang ata nagastos namin sa refacing at pagpalit sa lahat ng brake pads kaya nagtataka ako bakit 2 bendix brake pads lang sayo + refacing pero umabot ng 6k.
ipa balancing mo muna at alignment kung makapal pa brake pads mo.
kung manipis na brake pads at may tama rotor thats the time na need ng refacing. they need to machined the rotors to even and flat the surface para maganda lapat ng brake pads. yun kung may kayod o uneven yung surface, if not i sandpaper lang yan at cleaning. sa machining i think mahal yang 6100. yung bendix brake pads nasa 980 pesos sa LVC banawe dati bili ko, bendix db1774 GCT front, db 1390 rear. kung malapit ka o nasa manila ka rin lang dalhin mo na lang sa shop ni bro zix. oem yung brake pads niya malayong mas maganda kesa bendix
