Page 149 of 162 FirstFirst ... 4999139145146147148149150151152153159 ... LastLast
Results 2,961 to 2,980 of 3240
    #2961
    My first 1k service was 4000 pesos calamba branch
    Feb 2010
    #2962
    [QUOTE=fireice2;2855759]Diesel yan kaya maitim talaga oil. It simply means the oil is doing its job. [emoji5]=QUOTE]
    yes sir, and for the best result of my break-in, we went tarlac then baguio for 3 days then manaoag the following day...as in travel galore even reaching 120km/hr max speed limit at sctex & nlex as stated in the manual...and the experience is quite satisfying as the montero easily breezed through uphil climb overtaking slow moving trucks as well as fast paced new vehicles like fortuner & everest or maybe mabagal lang konti hehehe
    and for added observation when I check the dipstick before going down from baguio I noticed that the oil level is on the second hole meaning alanganin ako to proceed without adding half a liter of mineral oil good thing the same oil used by the casa for break-in...
    upon PMS sched I was surprised to found out that we accumulated 1,802 km mileage hehehe but ok lang sa SA namin coz of provincial trip we made...no regret for our choice of vehicle...
    May 2017
    #2963
    I have a 2015 montero sports gls-v which is due for 35k PMS. Is it required to have it done in one of the mitsubishi service centers since it's still under 3-yr warranty or it's okay to do it elsewhere. Will it not void the warranty? Can you recommend trusted non-casa shops in rizal area (binangonan/angono/taytay/cainta/pasig)? Ang sabi kasi sa akin ng diamond motors mga P9K daw for 35k PMS. Appreciate your response.
    May 2017
    #2964
    Quote Originally Posted by rovic815 View Post
    Up ko lang
    Jan 2017
    #2965
    If ok labg na mavoid warranty mo do it outside casa otherwise go with casa for the warranty.
    Aug 2017
    #2966
    Good evening. bagong tsikot member here. I've been reading the posts in this thread and I find them very helpful. I'll be getting my 2017 Montero GLS this coming wednesday.
    Sir Zix I'm planning to intall OCC and washable filters. Could you kindly pm me how much and what brands do you carry for the occ and filter. Do you have a baffled occ with filters? Thanks
    #2967
    Quote Originally Posted by aabugarin View Post
    PM sent sir
    Aug 2017
    #2968
    Quote Originally Posted by zix888 View Post
    PM sent sir
    Thanks sir zix
    Jan 2017
    #2969
    10k pms
    Estimate yung nakacheck lang babayaran sa casa.
    Actual na binayaran ko sa casa yung oil binayaran ko na lang sa advisor 3k
    Happy na naman si monty for the pms pati bulsa ko. [emoji6]
    Aug 2017
    #2970
    Guys, question po.
    Normal lang ba sa montero na mag bawas ng oil once na reach ung 5k? kasi nag 1k PMS ako 3 months ago. Then umabot na ako ng 5k. Pero pag check ko sa oil nasa low level na at nag signal na sya na need na ng additional oil. For sure puno naman nung 1k PMS ko. hindi ko lang alam parang an lakas naman ata mag bawas ng oil na umabot na sa low level. hindi naman ako nag papatakbo ng mabilis. 80-90kph lang.
    #2971
    Quote Originally Posted by abatayola View Post
    Guys, question po.
    in the olden days, when engines had iron and very little silicon, it was "acceptable" that the oil level in the dipstick would have gone from max to min, in the interval between oil changes, which was about 5K km, then.
    nowadays, when i change oil every 5K km in my siliconized non-mitsubishi diesel, the oil level has hardly gone down at all.
    Aug 2017
    #2972
    Thank you sir.
    Parang sobrang lakas at bilis naman kumain ng langis yan bro. Mas maigi patingin mo agad kasi baka may leak somewhere rig mo
    when you look into the abyss, the abyss looks into you
    #2974
    Guys, question po.
    How old and what is the mileage of your Monty? Its not normal to burn that much oil from top level to low level. It may signal engine wear or you are using a poor quality oil.
    Sent from my SM-G920F using Tsikot Forums mobile app
    #2975
    Quote Originally Posted by Gijoe_ View Post
    10k pms
    Wow drain plug 400pesos! Papalitan at 10k pms.
    Apr 2009
    #2976
    2013 glsv 30,000 PMS at Diamond motors valle verde branch last august 26.
    pinasok ng 930am and tumawag na ready na ng 3pm.
    overall ok naman, no hassle, inasikaso ng SA.
    total cost is 9,800 pesos.
    Aug 2005
    #2977
    Quote Originally Posted by clayman688 View Post
    30k km pms ko kay bro zix kalahati lang nyan sa price, may snacks pa. he he.
    Sent from my SM-C900F using Tapatalk
    Feb 2006
    #2978
    Saan po nakakabili washable cabin filter?
    Sep 2009
    #2979
    I brought my car (4d56 Montero) for oil change but was only able to bring 6 quarts of oil (Mobil 1 TDT - lost the loose bottle). Since my car requires 6.3 liters (6.7 quarts - 7 bottles) of oil, I figured that 6 bottles/quarts (5.68 liters) is not that far from the required 6.3 liters. My plan is to just top it up with 7th bottle at home.
    A day after, I checked the dipstick but was surprised that oil level is literally at the middle of the minimum-maximum holes. I did not add more oil. Anybody experienced this?
    Sep 2016
    #2980
    I normally just add 6 liters and then monitor in case it goes down. Same with yours with the dipstick.
    Sent from my ONEPLUS A3003 using Tsikot Forums mobile app
Montero Sport PMS Thread
