Page 154 of 162 FirstFirst ... 54104144150151152153154155156157158 ... LastLast
Results 3,061 to 3,080 of 3240
    Oct 2017
    #3061
    Sir gud am san po location ng shop nyo plan ko PMS 40k thanks.
    Aug 2011
    #3062
    hi guys, ask ko lang kung meron ba ok na shop for pms, egr cleaning/blanking, svc checkup, fuel filter replacement, etc na around fairview, quezon city lang sana. medyo nag alangan magdrive si mrs kila sir zix888 sa manila eh. tia
    #3063
    Good day...ask ko lng if ano kaya ang def kapag my natunog sa front shock..mas dinig kapag mabagal ang takbo... Shock kaya o un rubber sa ibabaw ng shock? TIA
    Sent from my LG-H540 using Tsikot Forums mobile app
    Jun 2009
    #3064
    Quote Originally Posted by teroy2010 View Post
    had an experience too. ball joints ang assessment but sir zix did something (i believe it's greasing) and it went away but expect it to be back in a few months he said, just in time to prepare for the budget. But its more than 3 months and is still working fine, no knocking sounds 2012 glx-v here
    Yep, the mechanic found the same problem, upper ball joints. Changed both kahit sira lang yung isa. Cost 3.6k w/ labor.- originally posted by monseratto
    Yep, the knocking sound is gone. Replacement part lang. Part number is SB 7841. 3.6k w/ Labor.-monseratto
    Oct 2017
    #3065
    Mga Master, ask ko lng mga naka OCC, ano po benefits/advantage nya? Saka how much din budget? thanks!
    Aug 2005
    #3066
    Quote Originally Posted by HugoThor View Post
    You may want to watch this video >>> What Is An Oil Catch Can? - YouTube
    Better pm zix for pricing.
    Sent from my SM-C900F using Tapatalk
    Feb 2006
    #3067
    baka inhibitor switch mo may problema. napalitan na ba iyang part na iyan before?
    if you're from manila, check w/ bro zix to be sure
    Thank you sir zix for personally replaced the defective inhibitor switch and for the tip how to reset the code of wheel audio control. Their shop is highly recommended!
    Oct 2017
    #3068
    Hi sirs..question on the 2017 montero. With the push start button i need to press the brakes first to start the engine.. i have noticed the breaks are hard sometimes as if there is no break fluid.. is there something wrong with the car or the way i park ?
    Sent from my SM-G950F using Tsikot Forums mobile app
    Quote Originally Posted by Raynim999 View Post
    wala lng vacuum assist(because engine is off) ... its normal.
    Power Brakes - Vacuum Assist - Explained - YouTube
    Oct 2017
    #3070
    Sir StockEngine,
    My observation is that this doesnt happen everytime i start.. sometimes its soft..sometimes its hard again... may impotent na yata to lolzzz
    it could be a vacuum leak.. when you depress it sometimes lubog? but when you pump several times it should harden though. lol impotent 😅
    Oct 2017
    #3072
    Ahh hindi naman lubog when i depress the pedal..it comes up everytime... just in the morning before starting the pedal is sometimes hard or sometimes soft... normal ba to ? Or kailangan na ng viagra ? Lolzz
    Jun 2011
    #3073
    Sir StockEngine,
    Baka naka handbrake ka...
    Minsan naman hindi..
    Jun 2007
    #3074
    I think kaya inconsistent is sometimes, may vacuum pa naiiwan sa brake system. Try stepping to your brake pedal several times right after you turn off your engine at mararamdaman mo na unti unting tumitigas ang preno. Unlike sa mga bus or truck, meron silang air tank to store the air kaya kahit turned off na yung engine, brake is still soft.
    Jul 2017
    #3075
    pacheck mo sa mechanic yan baka me trap air kaya ganyan. Bleeding lang kailangan nyan
    Nov 2017
    #3076
    Good afternoon mga bossing.
    Maliban po sa OEM brake pads, anong aftermarket brake pads ang pwede pamalit sa montero 2nd gen natin? (2011 GLS SE)
    Maraming salamat.
    Apr 2012
    #3077
    Quote Originally Posted by CaptBarbel View Post
    Maraming salamat.
    tokico, bendix.
    better still, if nasa Manila ka, go to Zix Performance shop. bro zix have a good replacement brake pads. pwede mo rin ipa-ship in case nasa probins ka. you can pm him here o check mo Zix Performance fb page...
    Nov 2017
    #3078
    tokico, bendix.
    sir, yung mga bosch na brake pads, ok kaya yun? may nakapag try na po ba?
    salamat ulit.
    Maraming salamat.
    project mu brake pads gamit ko bro. maganda ang kapit parang oem at halos walang brake dust
    Nov 2017
    #3080
    thank you sir baludoy. pabulong naman sir ng price. thank you.
Montero Sport PMS Thread
