Page 152 of 162 FirstFirst ... 52102142148149150151152153154155156 ... LastLast
Results 3,021 to 3,040 of 3240
    Jun 2012
    #3021
    nuon ganyan din unit ko. try mo bro palit air filter kung oem, linis lang if k&n, linis ng maf sensor, linis ng egr if hindi naka-blank. if malapit ka kay bro zix ipa-system check mo
    Pano linis maf sensor sir?
    Baka naman nagloloko na turbo niyan.
    Di naman sir. Kaya pa rin humataw. Not a big issue really. Pero pansin kong humina
    Sent from my SM-A9000 using Tapatalk
    Apr 2012
    #3022
    Quote Originally Posted by dct View Post
    pwede cotton bud saka isopropyl alcohol bro, linisan mo lang yung probe o yung parang palito ng posporo baka madumi. better kung may quick drying contact cleaner ka, bugahan mo lang. try mo lang along with the air filter cleaning
    Jun 2012
    #3023
    What and where is maf sensor sir?
    Sent from my HM 1S using Tapatalk
    Apr 2012
    #3024
    yung sensor in between ng air intake box saka turbo
    #3025
    ^ imo, compromise na ang ride comfort if mag lift. for reference, check mo fb ng blueline car accessories, atoy customs 4x4 and bodykits at jeff's offroad. marami silang pinapalitan ng suspension assy to give you an idea
    Ganon ba yun sir mon_gtv, pag nag 2" lift compromise na ang ride comport eh kung hindi mag 2" lift then palit ng 4way ridemax shock at lovells spring mas gaganda ba ang ride comport compare sa stock spring at shocks, need ko idea bago ko visit blueline
    Apr 2012
    #3026
    ^ no idea sir sa ride comfort ng mga binanggit mong items, all stock ang 2012 old na unit ko. wala pa ginalaw sa suspension assy
    Nov 2014
    #3027
    Quote Originally Posted by spiderjon96 View Post
    mga master plan ko mag 2 or 3 inches lift kay monty but no idea kung ano ang papalitan, priority ko is comport wala naman laging dalang mabigat except kung mag grocery o mag out of town, may nabasa ako sa ibang tsikot forum na pinalitan yung rear shackles with 2 inch lift, no idea kung ano yung shackle na yun, magkaiba ba yung shackle at spring na nakikita ko sa ilalim ni monty
    Shackles are only applicable to cars with leaf springs (usually pickup with the exception of Navara). If you plan to lift your Monty, just do it the right way para di macompromise ang comfort. Instead of using coil spacers to increase height, use aftermarket springs na may 2" lift, then use longer shocks with softness/stiffness adjustment. If done correctly, it should not affect ride comfort pero di maiiwasan yung increase sa body roll kasi nga mataas na oto mo, or you can add space arm (stabilizer) to help stabilize your monty when approaching curves.
    Sep 2017
    #3028
    How much egr cleaning sa labas ?mahal kasi sa casa
    Sep 2006
    #3029
    Quote Originally Posted by JoeW View Post
    Contact zix.. 1000 lang ata
    Oct 2017
    #3030
    Guys pa help nmn gusto ko i DIY yung change oil ng Mitsubishi montero sport 2016 gen 3, ano ba yung need ko na oil and oil filter thank you! first time car owner kasi ako and nakapag change oil na ako sa casa at sa labas, looks simple enough and labor nun, ang di ko magets yung oil na gagamitin at code ng oil filter.
    Jan 2017
    #3031
    Quote Originally Posted by carlsongo View Post
    Its not just as simple as change oil yan may mga chinecheck pa sila every pms and they have heavy pms.
    Oct 2017
    #3032
    Mga master ask k lng sana kung ano da best gawin if prang nalulunod takbo ng Monty and minsan mamatay makina. Based sa scanning SCV daw & nirereccommend ng shop na replace daw SCV = 13.5k, Cleaning EGR = 4k, Injector testing etc - 12k meron pa cla nilagay na estimate bsta aabot ng 32k lahat. Ano po ba best option pag gn2 na di nmn magugulpi sobra sa expenses. Montero 2010 GLS with 96k ODO.
    Quote Originally Posted by HugoThor View Post
    zix performance on fb. he is metro manilas ppv center 😅
    Apr 2012
    #3034
    go to Zix Performance shop. you will not spend that much. 4k for EGR cleaning? that's robbery
    Oct 2017
    #3035
    Hi Sirs,
    I will be having my 1k PMS soon and would like to check with you if I can bring my own engine oil and what variant of full synthetic engine oil should I get for Montero 2017. Thanks !
    Sent from my SM-G950F using Tsikot Forums mobile app
    Oct 2017
    #3036
    Yeah, grabe nga charging nila. Anyway, I am based in Cebu so medyo malabo kay Zix. Also do you recommend cleaning of EGR & SCV muna or needed n rin tlaga isama injector? Di nmn ako mausok lately lng talaga lumabas ung prob na humina hatak. Also for the Engine Oil do you recommend the motul crdi engine oil? Currently I'm using the shell fully syn engine oil. thanks in advance
    Apr 2012
    #3037
    Quote Originally Posted by Raynim999 View Post
    Hi Sirs,
    it depends if your casa allows you to bring your own engine oil, better to ask them prior to your PMS. check your manual what oil is applicable.
    EGR lang usually ang nililinis, you can DIY actually, you need only few tools to do it. SCV very seldom din nagkaka-diperensiya now, unlike nung mga earlier 2009-2011 models. Injectors my 1st time to read na nililinis na rin pala yan ng casa. i used Motul CRDI din before, ok din naman performance pero a bit pricey.
    Oct 2017
    #3038
    They mentioned na need n daw calibrate din ung injector and on the quotation nakalagay dun 4 x 3k total of 12k calibration lng. Actually di sa casa price n yan kc ung Mitsu casa d2 Cebu di kaya mag calibrate ng injector need p daw padala sa manila. Kaya lng nila is EGR cleaning ska replacement ng SCV (16k price ni casa for SCV).
    Apr 2012
    #3039
    it's my first time to hear yung injector calibration or baka kaya yung MUT learning yan? kung malapit ka nga lang kay bro Zix you will not spend that much. you may want to message bro Zix, inquire ka sa isyu ng sasakyan mo to get his opinion. or ask mo siya how much yung scv niya, baka makamura ka kung ipa ship mo na lang sa cebu din ipa-install sa knowlegeable mechanic. better still, if you know a reputable shop there that can service your vehicle baka makamura ka. out of warranty naman na unit mo di ba? you can avoid casa lalo kung grabe maningil...
    Oct 2017
    #3040
    Not really sure about that, basta sabi nila tatangalin daw ung assembly and prang may computer na mag calibrate. Nwy try ko contact si Zix na lang, medyo nanga2pa pa ako konti, kc now lng nagka prob gn2, nsa manila din kc tong unit nilipat k lng here sa Cebu last 2015. Btw sa tires pla ok lng ang Yokohama Geolandar G056 265/65 R17 mas mura kc cya compared sa current tire k ngaun na Bridgstone. Salamat sa tulong sir!
Montero Sport PMS Thread
