went to mitsu casa. pwede pala gamitin present montero oil filter (P900) para sa fieldmaster 2003. :-)
though, mas mura pa din vic oil filter (P500).
Mukhang glow plug nga problema ng smoking rig ko. 2 daw pundido. Anong magandang replacement?
Hi Guys, having problem with my right rear disc brake, since my FM has a sensor in the dashboard. it always indicates a much higher temperature than the rest of the tires/rim. When i went on a long distance cruise, sobrang init. it was over heating. tried replacing the pads, but i still notice the same effect as before. Sometimes when you go out of the driveway as if something is rubbing from the brake.
Who or where is the best service shop to trouble shoot or repair such problem. Thanks
sir nangyari n skin yan, linis lang ako nong shapting n may goma sa dulo lagyan ko lang grasa stock up kasi d n nalaro nong n linis ko ok n d n dikit preno ko nalaro n. . . .
mga sir, saan ba pwede bumili ng exact replica ng pajero fieldmaster sticker yung nasa lower part ng passenger doors? ang mahal kasi sa ATCO 8Kplus ang isang set. baka may alam kayo mas mura. salamat!
any suggestions sa brand na kukunin ko for clutch replacement? daikin exedy? may fake po ba nito
clutch disc
pressure plate
release bearing
