Page 144 of 718 FirstFirst ... 4494134140141142143144145146147148154194244 ... LastLast
Results 2,861 to 2,880 of 14348
    #2861
    [QUOTE=acertan;1838308]gastos na naman need new tires yung mags pinagiisipan ko pa
    got new quotations today
    Bridgestone 30x9.5R15 6PR D694 P8,050.00 -< this is the one that is currently installed and needed to be replaced
    Bridgestone 31x10.5R15 6PR D694 P8,650.00
    Falken 31x10.5R15 6PR Landair AT P7,900.00
    Falken 31x10.5R15 6PR STZ04 P7,750.00
    Hankook 31x10.5R15 6PR Dynapro AS P6,930.00
    Hankook 31x10.5R15 6PR Dynapro ATM P7,300.00
    Gajah Tunggal 31x10.5R15 6PR Savero AT Plus P6,990.00
    Gajah Tunggal 30x9.5R15 6PR Savero AT Plus P6,500.00
    Price includes free installation and wheel balancing. Wheel weights not included.
    We offer nitrogen filling at P50.00 / tire only.
    ok lang ba yung gt? savero at plus 31x10.5r15? gusto ko din kasi sana tumaas sya kahit konti di na kasi ata stock ng orig paj yung mags ko kaya 15`s siya
    Sir if i were you, i will get the 31x10.5 ng bridgestone, sa mileage halos even ka na sa ibang tires na nacanvass mo kasi sigurado na mas matagal mo siya magagamit. Falken kasi ilang beses na kmi nasabugan although sa car tire, but still scratch na sa lists ko yan. Dunlop talagang madaling mapudpod, pero talagang makapit.hankook naman madyado makunat kaya madulas especially when raining, the others hindi ko na try . Stock ng pajero is 265mm which is roughly 10.5", pero definitely mas mataas fc mo sa 9.5"
    Dec 2009
    #2862
    thanks for the info
    bahala na tom sana makapili din ako ng mags, hindi kasi stock pajero yung nakakabit sakin parang kamuka siya nung sa l400 like this one so wala naman problem kung 31x10.5r15 ang isalpak instead of the 30x9.5r15?
    btw ano yung offset na sinasabi nila sa mags? anu ba pcd ng pajero gen2?
    #2863
    Quote Originally Posted by acertan View Post
    thanks for the info
    Gamit ko r15 31x10.5 ayus lang naman, yun ang nakalagay sa driver side door eh. Anung Mags ba pinag pipilian mo sir? mapintahan nga... hehehe
    Dec 2009
    #2864
    ime eyeing on these two kaso nga lang wala na ko iba mapagpilian sa 15 yung iba over 15k na eh dito pa lang 15k na agad
    yung 20`s malabo out of the budget eh tsaka parang angnipis na. tom need ko na mabilan ng tires medyo limited kasi free time ko
    btw im planning to change tires pa ubos nadin kasi eto nakita ko sa blumentrit baka meron kayo ma recommend and brands to stay away from
    china tires 4.8k ea 31r15
    dunlop/hankook/nankang at 6k 31r15
    bridgestone at 8k 30r15
    mags 15k
    complete set 20`s w/ tires - 40k
    #2865
    China mags ba yan? yung 1st pic vote ko. hehehe
    #2866
    Bolt pattern is 6 x 139.7mm ( 5.5")
    kelangan mo malaki centerbore kasi malaki yung hub , cb should be 108mm. Malamang na ang wheel option mo lang eh yung may centercap.
    Yung offset paglumalaki ang value, means mas pasok siya sa fender, pagnegative naman, mas nakalabas parang off road set up. Between +15-25 offset wala ka splashing diyan sa pajero mo
    Dec 2009
    #2867
    china? i guess so ang layo kasi ng price nya dun sa iba lalo lalo na yung advanti around 30k and up yung ibang may centercaps na pede sa pajero
    *zix888 i see, yun ang gusto ko yung sakto or pasok kasi wala naman ako fender flares kaya hassle pag maputik yung daan,
    gusto ko yung sa shogun sa sulit kaso di naman pede wala kasi center cap
    illl try my luck kung anung mags makukuha ko pero the 1st one on the pic is my choice talaga 15k minus 7k with the trade in of current mags since wala naman ako pag gagamitan problema lang eh 4pcs sabagay di naman lage gamit yung spare tire
    #2868
    Okay in that case, the least offset you could go will be +15mm, para wala kang splashing, hirap maglinis eh. Yung spare tire mo meron naman yata cover? If yes, then you dont need to change it.
    #2869
    Mga pre nagpalit ako ng mga sumusunod, 2pc tie rod end inner and outer,transfer case support, shifter bushing,at replace ATF fluid..all in all P8800, lasama na labor,ok ba to or mataas?
    555 at orig yung mga piyesa tapos yung ATF mobil ata..
    Quote Originally Posted by oliver1013 View Post
    Parang mahal ah, that is if 2pcs tie-rod end lang talaga at hindi 4 pcs. Kahit kasama pa alignment dyan (kelangan kasi diba? ). Mobil ATF 220 mga P200 1 liter right? tapos you need 6 liters.
    Inner TRE - P570-650
    Outer TRE - P420-500
    ATF - 1,200
    Transfer case support - ?
    Shifter bushing - ?
    Labor - ?
    Dec 2009
    #2871
    found the adjustment manual guide for the kickdown it now shifts better than before .
    sayang yung isang mags ganda sana kaso ang laki ng offset
    finally natapos nadin ang pagpili in the end bridgestone padin pinili ko
    #2872
    Gwapo paps, 15's ba yan? how much breakdown ng lahat? parang gusto ko nyan ah... hehehe
    Dec 2009
    #2873
    btw ibang shop yung binilhan ko hindi yung date yun kasi e china iba brand pero same design ata
    trade in value 4pcs old mags with 10% tread less 6k pero sa iba ang buying price nila sa mags ko 3k
    16,500 mags razo 15"s 1yr warranty
    8,400 bridgestone dueler 31x10.5r15 -6 mos warranty i chose this
    8,000 bridgestone dueler 30x9.5r15 - 6 mos warranty
    7,000 dunlop at3 - 6 mos warranty- parang ang kitid tapos ang lambot di ko din type yung tire pattern
    free na yung weights and lahat nung 24 bolts bnew
    44,100
    closed at 44k
    if 16"s 24k mags same design tapos 8500 bridgestone dueler r16
    may option to buy 2nd hand tires kaso 25% nalang * 3,500p so useless din kung ibbyahe ng malayo
    yung 20`s meron din kaso 40k tapos 12k tires westlake lang pinakamababa na price
    very far from my budget so nag stick ako sa 15"s nalang
    tsaka iba na yung pakiramdam parang tumaas siya and mas tahimik na compared sa date kasi nga 10% na yung replace na mark eh kapantay na ng threads so it means replace na replace na dapat
    #2874
    ATF - 1,200
    Shifter bushing - ?
    Labor - ?
    Paps bale 2 pc tie rod end outer 650x2=1300
    2 pc tie rod end inner 850x2=1700
    transfer case suppport = 1400
    shifter bushing 450x2 = 900
    atf 5x 380 = 1900
    Labor al in all = 1600
    Total = 8800
    #2875
    44,100
    closed at 44k
    Bro anu material gamit nung mags na nabili mo? magnesium alloy or aluminium alloy? Can't find the web site for it...
    Dec 2009
    #2876
    di ko natanong kung what type siya
    haha, akala ko dunlop na eh.
    Nice combo naman, no worries.
    atf 5x 380 = 1900
    Total = 8800
    Ah mura na yan.
    Dec 2009
    #2879
    oo nga pinipilit ako sa dunlop kasi dun daw pasok budget ko kaso sabe ko ayaw ko parang ang kunat kunat tapos ayaw ko design ng thread niya nung around 4pm pumayag na din sa price na tinatawad ko kasi pasara na sila hehe.
    btw after pala ng negotiation edi ikakabit na, meron pala free drinks and food while waiting,
    1yr naman binigay na warranty sa mags if merong microscopic na butas pero upon installation chineck naman and nilinis wala naman singaw.
    next project: painting of calipers pangit tignan walang kulay
    Nov 2011
    #2880
    Quote Originally Posted by zix888 View Post
    Sir try mO sa evangelista, surplus, dun ko nabili 2 sets ko na oem adjustable shocks ko, p3k per pair. Magsama ka na lang ng marunong tumingin. Iba pa rin kung naka adjustable shocks ka
    thanks sir zix.try ko pahanap ng surplus oem
Mitsubishi Pajero Fieldmaster (Gen 2.5) [continued]
