hi sirs, ano po local fm model n may overhead LCD as OEM and front-facing 3rd row seats? tnx sirs.
Hi Sir, Im getting a Pajero na 3 door nextweek(di ko pa alam if its Gen 2 or 2.5) year model lang kasi nakita ko sa papers.. 4M40 engine siya. Im planning to do the following maintenance activity; may I know if its appropriate na yun unahin ko or would you suggest something worth spending rather than sa naisip ko po. Apologies, Im on my 3 day ( pahapyaw hapyaw reading the thread kaso dami, so I thought of asking na lang, hope you dont mind, newbie sa pajero po.
Planned Activity
1. Change Oils on Engine, transfer case, diiferential, transmission) & flush radiator
2. filter change (oil, air, fuel)
3. tires , sana bigger if reasonable ung makita ko
4. tint (3M)
5. seat cover (MG or Seatmate)
6. tie rod end, ball joint (ung orig sa pajero fieldmaster pwede po ba sa Subic 3 door pajero)
- Detailing Job
Optional
7. Would you advise me to rewire all the electrical?
8. Gearbox, replace?
9. Steering component check
Hope you can give me some inputs. Maraming salamat
May sakit na naman FM ko. Kakainis
Based sa volt meter ng turbo timer, 12-12.5 lang voltage sa system. Daming pumutok na fuse: walang map lights, central locking, radio and power windows.
Si Jemson sa Banawe kaso can't go there now. Di ako makalabas ng Commonwealth.
Correction on my post above, isang 100A blue fuse lang pala sa engine box. Kaso hindi ko matanggal. Yung ibang fuse naman simpleng hatak lang. May screw kaya to?
any suggestions para sa 16" rims ng paj? ano mas ok 265 70 r16 or 275 70 r16?
what can you say about the bridgestone h/t and a/t ano ba mas ok?
^ Ok na yang 265x70r16. yan gamit ko. Much better performance talaga at mas matagal mapudpod yung A/T vs the H/T and mas maporma kaya dapat A/T tire bilhin mo IMO.![]()
