Page 539 of 718 FirstFirst ... 439489529535536537538539540541542543549589639 ... LastLast
Results 10,761 to 10,780 of 14348
    #10761
    Si nelany, dito ko po nakuha adjustment procedure. DIY na lang yan basta may small ruler ka. hehe
    Kickdown cable adjustment
    *BG: yung TPS ba yung throttle cable din yun or iba pa. Tingin ko need ko din i-check if standard pa sa akin or hindi na. Minsa kasi on 4th gear and 140kmh bigla siya mag-downshift. Pero puwede din na may slight clutch slip na si paj kapag sinasagad. 1st to 4th gear wala naman kasi basta wala pa 140kmh.
    Magkaiba ung dalawa.. TPS is "throttle potentiometer sensor" ginagamitan ng multimeter to check the current going through when the accelerator is pressed or depressed.. ung values ng standard adjustment ang hindi ko alam. Si joseph lang nakakaalam nun..
    Sa 4th alam ko naka engage saken sa 60-80kph (2k rpm yata) pa lang .. as per joseph tama lang daw ..
    Pero tingin ko bosch alam kung panu adjust ung tps, kasi naka mount sa injection pump naten un ... ;)
    Posted via Tsikot Mobile App
    #10762
    Quote Originally Posted by PapaPaj View Post
    Sir alam ko ang TPS gingamitan ni Joseph A ng ohmeter to adjust. Ginawa nya TPS ko at kickdown since laging 2.5k shifting ko nun. Ngayon 1.5 -1.7 palit na agad.
    Chambahan method lang yun sa akin sa position ng TPS. Di ko rin naman kasi alam yun values
    #10763
    Meron ako na post dito before na thread from Pajero club UK regarding sa pag adjust ng TPS. Nandoon din values. Subukan ko hanapin ulit
    Aug 2011
    #10764
    Salamat sir testament at sir nelany
    Sir CB paki na lang ha. Need to check mine. hehehe.
    Apr 2012
    #10766
    Quote Originally Posted by K.I.L.L. View Post
    Go to Exalta on N Roxas street close to Banawe. They can fix it for you there. If you need parts, Triton is just around the corner.
    Sir Kill salamat sa tip .
    Jan 2011
    #10767
    Nasolve na problem ng blinking AT indicator ko.. Maluwang lang pala yung connector ng TPS.. Ni-reinforce ko lang ng alambre tapos wala na blinking..
    Aug 2011
    #10768
    Ano po naiaadjust nong tps? Effect po nya sa tranny?
    Feb 2012
    #10769
    fellas,
    ask ko lng kung san magandang shop magpalagay ng tint. at anu ang recommended ngaun.
    un nasa akin is 3M pa din.
    may nabasa ako dati dito, un naka aircon pa na shop, iwas alikabok kung ginagawa lng sa kalye sa banawe.
    many thanks
    #10770
    Quote Originally Posted by nobih View Post
    fellas,
    many thanks
    sa Solargard Santolan or sa VKool ok magpa tint based on experience.
    ito sir.
    Code No.21: Lever position sensor system <4M40>
    http://pajero.2de.ru/22/html/M122110560005000ENG.HTM
    #10771
    sirs,
    rough idling (low rpm) FM namin esp sa umaga. Pero after some time mag-normalize naman. Already changed fuel filter pero ganun pa din.
    Plan ko palitan ng glow plugs. any recommended brand ng glow plugs?
    thanks
    #10772
    Quote Originally Posted by zee View Post
    Don't adjust kung ok ang shifting ng sasakyan mo. Yan kasi ang magdedetermine ng shifting characteristics ng sasakyan mo.
    fellas,
    many thanks
    Nakapagpa-tint na rin ako dyan dati at ok naman doon sa sinasabi mong shop. Puro Solar Guard ang dala nilang tints at mas ok ang Solar Guard sa akin kesa sa 3M.
    Quote Originally Posted by mcdon View Post
    sirs,
    thanks
    HKT PM165 na original or HKT CP-05. Mas recommended ang CP-05 kaso mas mahal at 400 per piece, depende sa tindahan
    #10773
    Napalitan ko na yun yun valve cover seals ko at wala nang mga tagas doon. Kaso ang problema ko ngayon ay may oil na lumalabas sa oil cap na.
    #10774
    Testa, wala ka naman oil catch can na hindi tama ang size ng hoses? Kasi yung kilala ko hindi tama ang size ng hoses for his OCC nagkakaroon ng back pressure dun sa oil cap lumalabas yung langis...
    Kung wala ka naman OCC, pwede rin yan medyo sikipan ng konti kung maluwag na yung parang ngipin nung cap (medyo ibubuka mo using a screwdriver) para sumikip at lumapat sa valve cover.
    #10775
    Quote Originally Posted by junerski View Post
    Nope, wala naman akong OCC na nilagay. Tsaka pansin ko sa bagong oil cap ko eh parang hindi maganda ang pagkakahigpit niya. Sige, gawin ko nga yun suggestion mo. Kung wala pa rin, baka ibalik ko yun dating oil cap ko.
    #10776
    May oil seal/gasket din yung oil cap. Check if meron nakakabit.
    Sent from my Nexus 7 using Tapatalk 2
    #10777
    Panu ba malaman if palitin na ang glow plugs? Any signs sa start-up?
    #10778
    Medyo hirap na mag-start
    Hard starting kapag more than 1 na busted. Rough idling naman kung mga isa pa lang busted, yun bang mababa rpm mo habang hindi pa nakaka-warm-up yung engine. Yan ang experience ko dyan. HTH
    Yung TPS adjustmet, hindi ko pala kaya i-DIY. Need to consult an expert electrician hehe.
    #10780
    ^kailangan mo lang ng multimeter
Mitsubishi Pajero Fieldmaster (Gen 2.5) [continued]
