Page 538 of 718 FirstFirst ... 438488528534535536537538539540541542548588638 ... LastLast
Results 10,741 to 10,760 of 14348
    Aug 2011
    #10741
    Quote Originally Posted by frankedz32 View Post
    mga boss napalitan ng lahat ng host ko sa power steering pero bakit matigas parin...ok din naman daw gear box kase pag sira na yun ...at liniko liko manibela tutunog daw..ano kaya sira ..malaki kase gulong ko baka daw dahil dun kaya matigas iliko..
    sir ipacheck mo steering pump baka may bumara na metal fragments or parts ng oil seal sa loob. pag hindi naman yun mahina na ung steering pump.
    Apr 2012
    #10742
    i replaced my motolite 3sm today with Amaron 3sm galing kay powerstruck. 5.4k free delivery kasama swap ng luma ko. iba talaga pag may bago sa sasakyan. when i replaced my battery, feeling ko mas malakas headlight at aircon blower ko hehe. compare to motolite excel mas malakas cranking power ni amaron pero obserbahan ko pa this week baka ako lang to
    speaking of power steering pump, may repair kit b tayo for JDM or FM ? saan ba may reputable na shop to fix or repair the pump? May naririnig akong occasional grind sa pump parang naggigrind na bakal sa loob.
    Thank you guys.
    Aug 2011
    #10743
    Meron po repair kit. Mostly puro rubber seal lang papalitan dyan sir. Natry ko na kasi na bumigat steering wheel ko may nasira na rubber seal at bumara ng konti sa daanan ng fluid.
    Posted via Tsikot Mobile App
    #10744
    Check mo din kickdown cable, baka wala na sa specs. Search mo lang sa net yung tungkol sa pajero kickdown cable. Dati 2,500rpm bago mag-shift paj ko, nung inayos ko yan at palit ATF ay 2,200-2,300rpm shifting na siya. It helps.
    Inadjust ni joseph kickdown cable and tps sensor ko... pag nag titipid ako sa diesel it shifts at just 1.5-1.7k rpm... hehehe ;)
    #10745
    Quote Originally Posted by zee View Post
    San ung rubber seal na pinalitan mo sir? Can you elaborate? Na curious ako
    #10746
    BG, alam mo papaano mag adjust ng kickdown cable? Just curious kasi di pa ako nag aadjust niyan, wala naman problem yung sa akin.
    Si nelany, dito ko po nakuha adjustment procedure. DIY na lang yan basta may small ruler ka. hehe
    *BG: yung TPS ba yung throttle cable din yun or iba pa. Tingin ko need ko din i-check if standard pa sa akin or hindi na. Minsa kasi on 4th gear and 140kmh bigla siya mag-downshift. Pero puwede din na may slight clutch slip na si paj kapag sinasagad. 1st to 4th gear wala naman kasi basta wala pa 140kmh.
    Kickdown cable adjustment
    Jul 2014
    #10749
    ahh sir mag kano naman po kaya ang steering pump..dapat ba kasing lambot ng revo manibela ng pajero..sa revo kase namin malambot sya..or matigas lang talaga power steering ng pajero.
    #10750
    RT, salamat.
    Aug 2011
    #10751
    sir paano po iadjust tps at saan located?
    Aug 2011
    #10752
    sir my oil seal yan 1 at 3 na rubber gasket or bushing sa loob. the rubbers are in between metals inside the pump. nag wewear off din yun. before nag brittle na sakin at natangal. bumara sa daanan ng fluids kaya medyo bumigat steering. pwede mo mabili individually ung mga rubber dalhin mo lang sample o ung size. sabay mo narin oil seal. pag metal fragments bumara malamang galing sa steering gear i check mo steering gear baka may pudpud na.
    Aug 2011
    #10753
    salamat sa link RT. sobrang off na ung kickdown cable ko...
    Aug 2011
    #10754
    Sir pa advice ulit. Saan po makakabili mura na matino na dashboard natin, upuan.?
    #10755
    zee, na adjust mo na yung kickdown cable?
    #10756
    Check mo sa sulit ole ang dami ko pang nakikita na dashboard at upuan. Ka titingin ko lang the other day.
    #10757
    Crucial itong TPS adjustment. Sort of kapaan ito. Pag kasi mali ang position ng TPS, hindi magiging smooth ang shifting mo. Also, pag busted ang TPS mo, problemado din ang shifting mo. Siguro ganito nalang gawin mo, lagyan mo muna ng tanda yun current position ng TPS mo at gawin mong reference point, then tsaka mo galawin nang paunti-unti, clockwise o counter clockwise. Then test run mo at observe mo ang shifting mo. Pag tingin mo ok na, wag mo na yan galawin. Pag hindi ok, balik mo sa reference position mo
    Apr 2012
    #10758
    Sir alam ko ang TPS gingamitan ni Joseph A ng ohmeter to adjust. Ginawa nya TPS ko at kickdown since laging 2.5k shifting ko nun. Ngayon 1.5 -1.7 palit na agad.
    Apr 2012
    #10759
    Saan ba may malapit sa QC to check my power steering pump ? Ayaw ko kasi pumunta kung saan saan lang and its like 4 years na d ko napapa check up yung pump ko. Laging super gaan ang steering ko pero may instances na mabigat ang manibela pagka start ng pajero. yung repair kit ng power steering pump baka meron din kayong part # at price.
    Thank you ;)
    #10760
    Quote Originally Posted by PapaPaj View Post
    Thank you ;)
    Go to Exalta on N Roxas street close to Banawe. They can fix it for you there. If you need parts, Triton is just around the corner.
Mitsubishi Pajero Fieldmaster (Gen 2.5) [continued]
