Page 549 of 718 FirstFirst ... 449499539545546547548549550551552553559599649 ... LastLast
Results 10,961 to 10,980 of 14348
    Aug 2009
    #10961
    pajero02, ito yung positive side ng battery going to alternator. gauge 4 then may fuse for protection. pinaikot ko sa firewall yan.
    yung negative side is grounding kit lang kailangan mo. ilapit mo lang sa mga electrical. Like headlights, wiper motor, horn, engine block, fans, 4wd solenoid.
    pag luma na kotse mataas na resistance ng wires kaya makakatulong to fluctuations.
    Sir ask ko lang po sana ilan amperes lagay nyo na fuse?
    Posted via Tsikot Mobile App
    Aug 2009
    #10962
    Hindi ako makapost ng pic, bakt? Papakita ko sana ung nawala na tube
    Mar 2003
    #10963
    9701, 30 amps yung fuse ko. Kamusta pala yung boost readings mo can we compare. max ko talaga 11 pero saglit lang dun. madalas 10psi ako. based sa mga nabasa ko stock setting daw talaga ng 4m40 is 10 to 11 psi nga.
    Aug 2009
    #10964
    Almost the same sir pb ang boost reading natin but still not tested it on a 1 long stretch po. Usually mkti taguig area lang po kc daily trip ko sir.
    Apr 2013
    #10965
    Share ko lang 😄
    Aug 2009
    #10966
    Baby_scar, hope this can be of help to you. Gd am
    #10967
    Quote Originally Posted by baby_scar View Post
    Attachment 22762Attachment 22762 sir this one, kasi pagbalik ng mekaniko ng parts mayrun nahulog tapos tiningnan namin, tapos may nakita ung mekaniko sa baba ng pajero parang mali ung nilagay. Pls post lahat ng wire dito salamat
    Bro ung saken conversion gusto mo pic? If it can help
    Aug 2009
    #10968
    imageuploadedbytsikot-forums1408761973.171545.jpg sir gambit thank u, Dto banda na part may nahulog.. Kun tangalan ung valve gasket tapos ung intercoler withthe socket, kailangan ba tangalin ung postive sa battery?
    Aug 2009
    #10969
    Sir gambit good mrng pwde last request ..... Pasensya na po sa abala. Pwde mo ba picturan lahat ng connection sa intercooler at ung madaanan na parts. Compare ko lahat ng connextion baka may hindi nakabit or mali pagkabit. May "toktoktok na parang chain if apakan ang gas" thank u ulit
    #10970
    Quote Originally Posted by K.I.L.L. View Post
    Did you use double sided tape for that?
    Yup, double sided tape lang ang ginamit.
    #10971
    Sir if i remember correctly, ung brown plug lang tinatanggal ko para kalasin ung buong intercooler.
    If meron la nariring pag ni re-rev ung engine. Have some one step on the gas for you and try to listen and pin point where the sound is coming from. Better yet pa back job mo sa mechanic mo yan. Responsibility nya na i restore sa orig state or better yan before repair ...
    Censya na di ko yan pinapa engine wash... hehehe
    Tsaka converted unit saken kaya it maybe different sa local unit mo ..
    #10972
    Quote Originally Posted by junerski View Post
    Sir baka may tagas na radiator top nyo... had my radiator top repaired recently... Please check my post sa page 1040...
    Thanks for the tip. May damage nga ang upper tank ng radiator ko. Had it replaced by Cool Charge/Keyser last Saturday. Hopefully e tumagal din sya.
    Feb 2014
    #10973
    Good morning po mga sir. Pa advice naman po. Magpapalit na kasi ako ng compressor ng aircon . Ang pinapabili po kasi saakin nung pinapagawaan ko ng aircon is surplus lang na worth 7,500. Pero nakakita ako ng bnew denso compressor for 8,500. Pero ang sabi kasi sakin eh replacement lang raw yun. Nasa 20k raw yung magandang klase nung denso na kapareho nung sa naka kabit saakin. Anong pong sa tingin niyo? Dun nalang sa surplus na ang bnew ay worth 20k? Maraming salamat po.
    #10974
    Kung ako siyempre yung brand new ang kukunin ko. Tingin ka sa olx daming compressor na brand new pang pajero duon. Tanong mo nalang sa seller yung details.
    #10975
    Magkano damaged sa replacement?
    #10976
    Quote Originally Posted by specialtikoy View Post
    If denso na surplus yan... napakamahal nyang 7k.. almost 4k lang ang surplus na 17c denso compressor. Ung replacement is made in thailand while surplus is japan
    Hanap k ng iba na gagawa.. if surplus have the bearings replaced it will be good as new ...:D
    Feb 2014
    #10977
    Sir nelany, yung denso po raw kasi na binebenta sa sulit is replacement lang raw. Swerte na raw if hindi mag ingay within a year. Ewan ko lang kung totoo yung sinabi nung mekaniko. Icheck ko nalang rin siguro muna tong bnew. Thanks po!
    Feb 2014
    #10978
    Oo nga po sir eh. May kamahalan na rin. Malapit kasi saamin yung shop kaya yun na ang inuna ko. Mag canvas canvas nalang siguro ako. Thanks po sir! Hanap nalang ako ng 4-5k.
    #10979
    Inquire mo sa seller para me first hand information ka. Yung nakikita ko na nag bebenta lalo na yung taga Paranaque na meron tindahan ng aircon parts ay specialty niya yung aircon parts ng Pajero. Sa akin lang mechanical ang compressor so ang wear and tear niyan ay nandyan.
    Dec 2013
    #10980
    Thanks for posting. So bale direct alternator to positive side ng terminal ng battery tama ba? Tapos negative terminal ng battery ko saan ko ikakabit dun ba sa mga binanggit mo? Pasensya na sa ignorance ko ah di kasi ako DIY guy. TIA.
Mitsubishi Pajero Fieldmaster (Gen 2.5) [continued]
