Nag install ako ng volt meter to monitor our battery and alternator health... ;)
Posted via Tsikot Mobile App
Sir monty tnx sa reply..ung suggestions mo nagawa ko n un ung tire ko new lahat..npaunderchasis ko n rin..balancing, alignment. .same p rin nbawasan lng ng konti..pero ung rim stock p rin..di kaya bengkong un..? Ano p kaya possible cause nun? ..pahelp nmn mga sir sa mga maraming alam at experience. .salamat po godbless
Sir ano meaning ng HTH? Sensya n po now lng ako nagkasasakyan. .tnx
Dennis, "HTH" ay short for "hope this helps".
Sir monty hm ng gastos sa WMInject? Saan ba pwede painstall nyan..kc tested n daw yan..give me info bowt dis sir..tnx
2pcs. 300/ea bili.. pag isa lang 400 benta sa sulit. Nakipag neet up lang ako. If u need i can post the number of the seller.
Sa accessory naka tap sya, or tap mo sa cigarrette lighter. If below 12v ang ave. (While idling)Reading malamang alternator... pag patay makina tpos accessory, below 11v battery na cguro problem tpos hard starting ka na. Best is tandaan mo ave. Reading while ur car is ok. Pag nag below it means something is wrong...
good morning gents.
Ask ko lang po sana saan ang most advisable "tapping" point if i were to install a boost gauge for our turbo po?
Browsing through "you tube" and the net gave me confusion/s po.
TIA po...
9701, yung sa akin in between turbo at waste gate. Kialangan mo ng t-connlector.
