Page 548 of 718 FirstFirst ... 448498538544545546547548549550551552558598648 ... LastLast
Results 10,941 to 10,960 of 14348
    Dec 2013
    #10941
    imho pag fluctuating yung power niyo. sa car audio kasi upgraded kailangan ang big 3 kung tawagin. guaranteed stable kuryente niyo
    grounding kits for negative lang and isang fused gauge 4 wire from alternator to positive terminal. Di na yan bababa ng 13v kahit sa start up compressor ng aircon. the only time mo makikita mga 12.6volts sa umaga unang start pag umaandar pa glow plugs. Di pa na circulate oil low idle but, after 10 secs 14 volts na uli.
    Can you give us a diagram kung pano ang wiring ng groundkit? Yung tinatawag nyong big 3. Planning on doing it pero hinde ko alam kung pano umpisahan. TIA.
    Dec 2013
    #10942
    Quote Originally Posted by direk View Post
    sir nards, here's my current intercooler tubing set up. had i mandrel bent at alpars. hope this helps.
    Posted via Tsikot Mobile App
    Sir, ano po benefits ng ganitong tubing system? Parang gusto ko din palitan yung sakin.
    Mar 2003
    #10943
    pajero02, ito yung positive side ng battery going to alternator. gauge 4 then may fuse for protection. pinaikot ko sa firewall yan.
    yung negative side is grounding kit lang kailangan mo. ilapit mo lang sa mga electrical. Like headlights, wiper motor, horn, engine block, fans, 4wd solenoid.
    pag luma na kotse mataas na resistance ng wires kaya makakatulong to fluctuations.
    Aug 2011
    #10944
    salamat po sa mga reply. I tried sa casa kahapon wala sila nun. para daw mag down shift agad pag sagad apak sa throttle. ill consult mr atutubo. salamat po ulit.
    Aug 2009
    #10945
    Good pm sir. Mayrun kami 2006 pajero fieldmaster local edition. Pinalitan nami ng oil kanina tapos may konti leak ung sa top. So bumili kami ng valve gasket (rubber), oil ginamit aisin brand 5w40. After ng palit umuwi ako 5km ung layo. Tapos while going home wla na hatak ung pajero tapos uusok sya. Nakita ko un pagawa sa pajero ung ginawa ng mekaniko pour engine flush pinaandar for 2 to 3 mins then drain oilfilter, then tangal ung cover thenpalit gasket. Tapos binalik ung tube at wire. Nasauli lahat ung tube at wire. Pwde ba un, hindi tagalin postive sa battery kung palit valve gasket, pls help sir
    Aug 2009
    #10946
    Naglagay sya 7 liter 5w40 aisin brand. Pwde ba un na mag reset un turbo kung hindi tangalin ung postive sa battery?
    #10947
    Quote Originally Posted by baby_scar View Post
    Yung sa leak maaari rin dahil sobra dami nung oil na nilagay, may kilala kasi ako lagi sobra nilalagay na oil nagleak valve cover niya tapos sumunod yung oilpan gasket... 6-6.5 liters lang ang capacity ng 4m40. Pero subjected rin naman sa wear and tear ang valve cover gasket
    Yung pagpalit ng valve cover gasket hindi naman electrical related so disconnecting the battery while replacing it is not necessary
    Although kelangan tanggalin yung intercooler... baka hindi naisoli ng maigi mga turbo hoses kaya walang hatak... pwede rin baka marumi na air filter mo or barado na fuel filter.
    Aug 2009
    #10948
    Pwede po kayang gamitin ang water temp sensor as oil temp sensor? Got an oem oil temp gauge but without the sensors po.
    Aug 2009
    #10949
    Quote Originally Posted by junerski View Post
    7 liter palagi ko gamit sa change oil. Un nga sir baka hindi nasauli ung iba hose pero nakita ko may nahulog na something then may nakita ung technician tapos binalik nya. Maghanap pa ako same model para makita ko ung hose connection kung same ba an kabit. Tapos kung tapak mo gas may tutunog.
    Aug 2009
    #10950
    Bfor change oil at palit valve gasket ok ung hatak sa pajero fieldmaster, wlang problema
    #10951
    BS, agree ako kay Junerski. Baka nga di naibalik ng maigi yung mga turbo at intercooler hoses. Nangyari na sa akin dati yan wala ring hatak tapos malakas na ingay pag tapak ng selenador ay parang malakas na higop ang tunog. Yun pala may intercooler hose na hindi nahigpitan ng mekaniko.
    Aug 2009
    #10952
    Try ko maya check lahat ng hose at cable. Maghanap ako ng pajero dito para macheck ko ung differrnce ng connextion. Pwde ba mag requeat sir? Pwde ba picturan ung pajero nyo near sa turbo na connection. Para macheck ko pls thank u. Kasi duda ung on the top side sa turbo may connection na hidi na connect thanx
    Aug 2009
    #10953
    Sir ok lang patakbuhin toh for 4 kms sa talyer or dito nalang sa bahay pacheck. Takot ako masira ung pajero maraming salamt
    Aug 2009
    #10954
    image.jpgimage.jpg sir this one, kasi pagbalik ng mekaniko ng parts mayrun nahulog tapos tiningnan namin, tapos may nakita ung mekaniko sa baba ng pajero parang mali ung nilagay. Pls post lahat ng wire dito salamat
    Got my analog voltmeter installed yesterday. Nasa P900 din lahat, labor mahal *P500 kasi sa ibang electrician ko pinagawa, hindi ko kinaya i-DIY, kinakabahan ako kasi wirings eh. Tapos wala pa suking electrician, out of town. okay na din. Sa sulit kais hindi nagreply yung na-PM ko na seller nang digital.
    Maliwanag nga masyado ilaw kapag naka-on na kasi pinalitan ko nang white LED light yung bulb. hehe, yun lang na-DIY ko.
    #10956
    RT, hindi ba mahirap tingnan yan sa ilalim pag tumatakbo ang sasakyan mo?
    #10957
    Eto yung pwesto ng voltmeter ko. Pwedeng masilip maski in motion ka.
    Nope malaki naman na gauge kasi tsaka nga pinalitan ko nang white LED light yung ilaw. Litaw na litaw ilaw eh. hehe
    #10959
    Sa three spoke steering kita yan sir, unobstructed actually ... hehehe :D
    #10960
    Did you use double sided tape for that?
Mitsubishi Pajero Fieldmaster (Gen 2.5) [continued]
