I had my power steering oil sending unit changed. It sprung a small leak which I didn't really notice. Luckily, a friend looked under my hood and pointed it out to me.
*Nelany: 100k odo. Yung filter linis lang pwede pa naman kasi sayang daw sabi ng trusted mechanic ko. Oil used Shell spirax yung Black yung bote 300+ pesos ang isa. Result is ganda ng shifting halos di mo ramdam.
*all Sir paano kaya ayusin yun roller ng 2ndrow seat ng pajero jdm? Ayaw kase mag slide paharap nag stuck though naiaangat naman namin yun seat. Thanks!
Posted via Tsikot Mobile App
Sir ilan liters of ATF sa change ATF nyo?
may nabibili ba gasket para sa oil pan or sealant/3bond lng?
tnx
Wag ka gagamit ng 3bond sa oil pan, masyado matagal yan bago mag set kaya mag leak. Just use silicone sealant ... nagamit ko yata was 12ltrs pero full bleed un kasama atf cooler
Ganyan din maintenance ko sa A/T... every 40k palit filter.
ang sabi naman ng mechanic ko, lumalaki raw kasi butas nung strainer/filter ( due to wear and tear) kaya maganda rin na palitan na... and tsaka nakababa na pan might as well replace it with a new one.
Mobil 220 gamit ko... I think hindi naman maselan ang A/T natin as long as tama ang specs ng fluid na ginamit![]()
A friend recently had his a/t pan pulled down and it consumed around 6-6.5 liters of ATF... mas marami nagagamit ATF kapag dialysis style or bleeding.
AFAIK, wala talaga gasket ang pan ng A/T... ang meron gasket yung filter/strainer
Although may nabibili gasket (for the pan) sa ATCO Pasay pero hindi OEM (parang gawa sa cork na manipis)
Ah talaga? Kasi thrice na ako nakawitness ng pulldown ng pan (first time pulldown and first owned units) wala gasket except for the red gasketmaker na factory installed (like yung kay pajero02, Im seeing remnants of the red gasketmaker) ...thanks for the info
baka may batch ng units sa planta na walang gasket like mine and yung sa kakilala ko.hehe.
I also used gasketmaker when I had mine done wala naman din leaks.
guys.. anyone here using SAE40 oil? on gen2 or gen2.5? will there be a problem using monograde oil? thanks
Pan pull down and dialysis every 40K-50K. tapos yung dialysis lang at wlanag pull down puwed siguro every 20K if madami budget. hehehe
Si testa pala wala din gasket yung sa pan niya. Pero malamang hindi na din first time na pull-down yun. Anyways ang mahalaga may gasket or gasketmaker at maganda pagkakalagay para walang leak sa at pan.![]()
