Page 21 of 718 FirstFirst ... 111718192021222324253171121 ... LastLast
Results 401 to 420 of 14348
    #401
    Quote Originally Posted by GoNeIn60SeC View Post
    [SIZE=4]Mga sir para san po ba ung turbo timer? How do you install this thing? May pics ba tayo nito?[/SIZE]
    [SIZE=4]K&N air filter, how much po ba ito? im planning to put this on my paj in the near future... Mukang okey pa naman condition ng paj namin eh.. I made 158kmh sa coastal last night, onti nalang 160 na.. [/SIZE]
    Gone, subukan mo ang Roadstar 896-2914 o 896-2913 para sa K&N filter. May branches sila sa Makati at Muntinlupa.
    Galing sa Wikipedia- "A turbo timer is a device designed to keep an automotive engine running for a pre-specified period of time in order to automatically execute the cool-down period required to prevent premature turbo wear and failure. After a period of driving when a turbocharger has been working hard, it is important to let the engine run at idle speed for a period of time, allowing the compressor assembly to cool from the lower gas temperatures in both the exhaust and intake tracts. At the same time the lubricating oil from the engine is able to circulate properly so the turbine won't burn the lubricating oil that would otherwise be trapped within the charger with the turbine rotating at high speed. With regard to modern automotive turbochargers, the need for a turbo timer can be eliminated by simply ensuring the car does not produce any 'boost' (during driving) for several minutes prior to the ignition being shut off. Most turbo timers are based on digital electronics."
    Nakabili ako dati sa Concorde sa mga SM Malls. Ok iyong sa kanila kasi exacto iyong laki niya sa blank switches sa Pajero kaya mukhang OEM.
    #402
    Quote Originally Posted by Monty View Post
    AR, depende na sa iyo iyan. Ang drop in filter ay walang hassle kasi salpak lang. Ang open type tatanggalin pa iyong air filter box at mag lalagay pa ng tubo. Ang drop in ay nasa original closed container at iyong intake is from the side fender so kahit ilusong mo sa baha (huwag lang abot ng hood) kaya pa ng pajero natin. Ang open type ay exposed kaya ingat na mabasa ito at mas mabilis madumihan. Kaya lang medyo masmalakas nga ang higop ng hangin ng open type.
    It must be somewhat secluded or else hihigupin niya ay yung hot air sa engine bay.
    Nov 2006
    #403
    Quote Originally Posted by paj4x4 View Post
    Its really up to you.
    I went for the drop in since its the easiest route...just drop in the new K&N filter. My rig's engine is bone stock. A simple drop in filter will do the job.
    engine bay.
    Thanks mga paps....widely available ba ito sa mga shops? or any recommended shops na lang para derecho na ako agad dun aside sa Roadstar as posted by MOnty..
    thanks
    #404
    Have not used BFG's on my rigs. Couple of my friends have tried them. They swear by it. Medyo may kamahalan nga lang and nowadays quite hard to find a tire store/dealer that carries BFG's.
    If you stay with the AT you'd be fine with road noise.
    You're right ang hirap nga humanap ng BFG tires... hanap uli ng iba... hehehe
    Mar 2003
    #405
    Bg, hanap ka ng Bf goodrich it would last you more than 100k kms di pa ubos, nasa 85k kms na yung tinakbo ng akin, di kaya abutin ng pako para iflat, sa ingay dont worry di mo na maririnig yan sa hiway sa ingay ng makina natin did i mention na super gwapo ng tire na ito and ang sarap hawakan ng sidewall. definitely ito parin bibilhin ko, after 100k kms kahit di pa ubos ireretire ko na, hirap ubusin ng tires na to grabe!!!.
    heres a pic of my tires, offroader ang dating,
    ar, buti ayos na makina mo, ayos talaga diyan sa CDC magpagawa,
    #406
    ganda nung BF. around how much per piece yan?
    Sep 2010
    #407
    Sir PB, mabibili bang sticker katulad nung nasa side ng FM (pajero) mo? gusto ko kasi palagyan ung 99mdl pajero ko..
    #408
    PB sa sobrang tibay ng BFG tires mukhang konti ang recurring sales kaya di na yata binebenta dito yan, dami ko na na pag ask, wala talaga ....... hehehe
    Jun 2004
    #409
    BG, try calling RYCO in Makati. I know they used to carry BFG's. Now they also carry Cooper STT's. Phone no 02 8161667 and 02 8161508.
    Suggest you also look at Nitto Tires. I have them on my LC 80 (Terra Grappler AT's) - aggressive looking All Terrain Tires. Check out how it looks on www.nittotire.com. Its done almost 20k kms on my rig parang di pa rin nababawasan ang tread. On my Gen 2.5 I have Pirelli Scorpion ATR's - maayos din at matagal maubos. Although not as aggressive looking as the Nitto Terra Grapplers. By the way - Concept One along Santolan is the distributor of Nitto Tires.
    Jun 2004
    #410
    Quote Originally Posted by ar24458 View Post
    thanks
    Log on to www.4x4ph.com/forums. Go to the For Sale section. Look for the thread on K&N Filters started by carcas. He's selling the 38-9207 for P4.5k with free shipping.
    Before ordering check if the 38-9207 fits the air box of your Gen 2.5. Local unit ba yung sayo?
    #411
    sir paj4x4 thanks for the assist I'll try to contact them tomorrow... how much score mo sa pirelli scorpion atr's?
    I was pondering a few months ago of getting h/t tires, but di ko gusto itsura, iba pa rin ang AT's...
    #412
    sa jaffa's sa banawe meron, di ko lang maalala magkano... pero pansin ko lang yung ibang sticker na ganito namumula?!? defect ba yun or sakit talaga ng sticker na toh.
    #413
    Sir, around how much is the nitto?
    Jun 2004
    #414
    I got the Pirelli Scorpion ATR's (265/70/16) for less than P6k/pc. Can't remember the exact amount anymore. Mid 2007 pa kasi ang purchase non.
    Jun 2004
    #415
    Got the Nitto Terra Grappler (285/75/16) for P8.5k/pc
    Jun 2004
    #416
    PB - still owe you the pics of the Hirschmann power antenna na nilagay ko in place of the OEM power antenna na medyo madalas masira. Post ko this weekend
    May 2004
    #417
    BG; concept one also sells BFgoodrich. kakacanvass ko lang sa kanila last month. Look for Lei Alejandro, she's very accomodating. What size do you want?
    paj4x4 is correct, punta ka lang sa 4x4ph kung hanap ka suv tires. if you want cooper(cheaper than BFG but less agressive) look for Caloy Legaspi. or if you want i can PM you his number.
    #418
    Swerte mo na man sir, Pirelli's for less than 6K. Right now Only china made tires can be had for 6K below. almost all ng na canvass ko is nasa 7K and above...
    sir newde11, i'll try to contact concept one. thanks. pa PM na rin nung number ng 4x4ph, di ko ma puntahan site nila me problem yata. thanks
    Aug 2005
    #419
    hi guys,
    how much na kaya mabebenta yung 1999 FM 4X4 Manual na Pajero??? My father in law is planning to sell his FM Pajero
    #420
    mga 600k to 700k depending on the condition...
Mitsubishi Pajero Fieldmaster (Gen 2.5) [continued]
