Page 71 of 718 FirstFirst ... 216167686970717273747581121171 ... LastLast
Results 1,401 to 1,420 of 14348
    Jan 2011
    #1401
    Quote Originally Posted by patsan2003 View Post
    I would like to know if it is normal for this type of engine to have splashing oil when you remove the oil fill cap? While the vehicle is idling, all of the Pajeros I have seen have splashed oil when I opened the oil fill cap ; but no oil splashes out from the engine dip stick. The sellers say that it's normal, but I am having doubts that the engines of these Pajeros are about to give up, am I right or wrong?
    I believe this is normal. Good luck on your hunt.
    Jan 2011
    #1402
    Quote Originally Posted by paj4x4 View Post
    Most likely just the repair kit of the PS gearbox. Suggest you take your rig to Motorcraft in Amoranto QC. Call first or go early before 8am coz the waiting time there can get long. 02 4148633
    Thanks sir! Will give them a ring later.
    #1403
    Quote Originally Posted by uricacidman View Post
    Mga sirs napansin ko na medyo may moisture na nanggagaling sa power steering ko. Nagbabawasan din ang PS fluid ko pero mga 3 months inabot from Max to Min. Which parts kaya ang possible na kailangan palitan? Repair kit lang kaya? Any recommendations san kaya ok mag pagawa dito sa QC/Fairview area?
    Medyo matrabaho ata mag repair ng power steering so magkano kaya ang tamang charge ng labor?
    TIA
    kelangan lang yan sir overhaul... repair kit lang kelangan mo and probably a liter of ATF/powersteering fluid.
    nagpagawa lang ako nyan a few months back
    repair kits usually cost P900-1000pesos (part number MR 272325 isang supot lang yan ng mga rubber seals)
    #1404
    Quote Originally Posted by junerski View Post
    had my a/t fluid replaced
    breakdown
    1. a/t filter P780 casa price (tabi lang namin diamond kasi, baka masmura sa iba PART NUMBER MR166573
    2. filter gasket P450 casa price PART NUMBER MR166571
    3. a/t fluid 6liters (mobil 1) forgot the price dahil stock ko pa 2years ago (sobra nung ondoy but my FM di naman victim)
    4. miscellaneous... gasoline for cleaning, liquid gasket
    5. labor P650 (ang dami pala tinantangal dun na turnilyo?!?)
    some pics
    Junerski meron specific na pangalan yung talyer sa Marcos Hiway?
    #1405
    meron sir.... balikbayan motors. katabi nung san benildo integrated school.. medyo tapat ng burger king. westbound side ng marcos highway.
    #1406
    TY bro, malapit lang pala. Paki bigay naman yung pangalan ng mekaniko.
    Quote Originally Posted by ar24458 View Post
    boss, curious lang...dapat ba regular pinapalinis turbo and change oil seal? and kung saan shop na din....
    thanks
    Hindi naman if you have an oil catch can installed. If wala, yearly palinis mo turbo mo at intercooler IMO. Yung oil seal bibihira naman masira yan based on my experience with MMC turbo.
    Nov 2006
    #1408
    ah ok...san po ba pwede ipalinis turbo? DIY lang ba ito? yung intercooler i tried DIY with gas..shake-shake lang til luminis....
    gusto ko din ma-check kung gumagana turbo? parang bitin ako sa 2nd/3rd gear pag arangkada eh...when i reached 3K rpm, parang di ko ramdam turbo...or baka nasanay na lang din ako.....comments pls....thanks ulet.
    #1409
    look for mar (siya ang head mechanic) 681-8763
    sabihin mo nirefer ka ni jun yung nakawhite na paj.hehe
    #1410
    sir nelany, inform nyo lang ako pwede ko kayo samahan, trusted mechanic ko na sila mar ever since.
    #1411
    Please enlighten me mga bro's
    Sa pajero A/T pwede ba mag engine-break? And what gear do I use or how can I do it?
    Kasi punta ko Antipolo this holyweek, from what I remember steep yung pababa. Ayoko naman ma cook at mag fade yung brakes ko ka tatapak ng preno...
    Thanks
    Jun 2004
    #1412
    If the incline is steep switch off OD and put it in 3 or 2.
    pero sa casa every 40k kms ang palit niyan with atf filter replacement... alin ba masmaganda? masmadalas like every 20k o follow manufacturers specs?
    and ano pala epekto ng sira ang intercooler fan? sira na kasi yung sa akin.hehe. next week ko pa mapapagawa
    Sir musta pagpapagawa mo ng intercooler fan? Hind na din gumagana yung sa akin eh.
    switch off Od lang tingin ko pwede na.
    #1415
    sir subukan niyo yung mga "Sanden" na fan sa mga aircon shops. usually Taiwan made yan. Sanden kuno lang hehe pero pwede mo yan i-retrofit sa itaas ng intercooler. para yung air pushing downwards. alam ko mahal ang surplus na intercooler fan.
    ang nabasa ko, pwede mo din pa-open kasi baka carbon lang nasira.
    Apr 2010
    #1416
    had my intercooler fan replaced at rey's. stuck-up na kaya palit lang talaga ang solusyon.
    #1417
    TY Bro. Check ko nalang sa kanila pag nag pa sched na ako ng palit.
    #1418
    CB, mag kano yung web design na mags at saan yung tindahan. Type ko yung web matagal na.
    Crazy Boy, saan yung tindahan ng web na mags at mag kano? TY
    #1419
    pinarepair ko lang sa reys electrical.... carbon brush lang naman ang sira. less than 500pesos binayad ko... ok na ulit. nirekta muna nung electrician to show na umaandar na ulit. although hindi kaagad agad aandar kapag nakakabit na dahil may sensor yung fan. at a certain temp tsaka iikot.
    #1420
    Yung downhill ang worry ko, kasi baka ma sunod yung brakes. I believe sa Sumulong Hi-way going down was the steep road I'm referring to...
    Curious din ako since never ko pa na felt mag engine break ang A/T ko since laging naka drive naman ako kahit sa level parking ng Malls going down like in Trinoma...
Mitsubishi Pajero Fieldmaster (Gen 2.5) [continued]
