Bros, Im contemplating on buying a 2002 FM with 60k mileage. All stock pa daw po. what are the things that I should check or look into? Can you suggest a checklist para hindi po ako maloko.
Thanks.
im contemplating on trading in my 01 GU patrol 4x4 to a 99 fieldmaster 4x4,anyway are the shocks of the gen 2 and gen 2.5 FM the same?if ever i get an aftermarket shocks,same lang ba mounting nila?
Check if the papers are in order. You can also double check sa LTO.
Some practical tips.
1. Inside the car, check mo kung gumagana lahat ng switches and instruments.
2. Under the car, check mo kung ok pa ang mga shocks kung wala pa tagas (assuming stock pa nga ang nakakabit), kung walang kalampag.
3. Under the hood, check mo kung ok ang pag-maintain though medyo subjective ito kasi malamang bagong detail ang mga binebenta na cars.
4. Well, check mo rin ang service booklet kung regular ang maintenance service nya. You can also verify if the mileage reflected sa odometer is the same as the mileage appearing dun sa last periodic maintenance service nya (assuming sa casa ginawa).
5. More importantly, kung hindi mo talaga kakilala ang seller, magdala ka ng mekaniko para medyo confident ka na accurate ang technical inspection mo lalo na sa makina.
Good luck.
May possibility na tampered. Pero mahirap i-speculate yan. Well, here are some pointers.
1. Check body paint pati bubong
2. Engine for oil leaks pati yun behavior niya
3. Radiator water, kung siya ba ay maalaga sa coolant
4. Interior
5. Tires
6. Tire alignment. Pag may kabig kasi, more or less may sira ang mga pang ilalim niyan
7. Aircon (very importante)
8. Lights
9. Mga electricals niya (windows, side mirror, etc)
Good luck on your car hunting!
Yes they are. Pero a Patrol to a FM, parang pa-downgrade ang gagawin mo. Bakit naman? Maganda ang Patrol ah...
guys.. anyone here with a 2003 up gen2.5? na may tire pressure monitor?
pano po pala pag nag rotate ng gulong? tangal din po ba lahat? thanks or may pwedeng galawin yung lcd para maging match yung mga led?
ahh.. i see.. pwede pala iprogram? hanapin ko po muna sa glove comparment ko.. sa alam ko.. kumpleto pa manuals ko eh.. hehe
thanks monty
dagdag lang sa mga nabanggit...
for the electricals... check mo if all auxilliary fans are working (3 yan, isa sa intercooler, isang malaki sa likod ng grill, isang maliit sa bandang ilalim ng grill/likod ng bumper)
check mo rin starting... if hard starting,one click ba etc
marami kasi pwede repair if hard starting from simple glowplug replacement to calibration
kapag titingan mo na actual unit, better make sure hindi pa nagamit dahil kapag uminit na engine marami ingay nawawala.
ser sa value ng patrol 01 at fm na 99 di masyado nagkakalayo mga 50-100k lnd diference ako may 99 fm 4x4 kabibili lng.. patrol 3p ko ren kso ayaw ng tatay ko masyado daw malapad at mahaba mahirap dalin pag nsa manila ka.. hehe pero kung sa performance mas maganda ung fm,mas matikas lng patrol pangbangaan ksi hehe![]()
tingin ko 4500cc ung patrol nyo e.. hehe ay ung fan ba ng aircon sa harap may fuse din ba un?
yung gen2 na JDM lahat may SMH... dito sa pinas ata yung gen2 walang SMH except for the later models (97-98) yung tinawag din ng MMPC na fieldmaster (in a gen2 body) may SMH yun and jumpseats na 3rd row hindi na front facing.
tapos lumabas na yung gen2.5 (blister fender) 99-2008 may SMH and varying seat configurations kasi yung late models balik front facing 3rd row ulit
