Results 701 to 710 of 14348
- Oct 2010
- 58
December 10th, 2010 11:38 AM #701
- Aug 2009
- 420
December 10th, 2010 05:39 PM #702sir, queries po:
1) saan po ang aircon filter of pajero fieldmaster? on how to remove it? proper?
2) air filter to use for pajero fieldmaster?
thanx
December 10th, 2010 09:43 PM #703
December 11th, 2010 06:00 PM #704
December 12th, 2010 08:03 AM #705
December 12th, 2010 08:08 AM #706
- Oct 2009
- 52
December 12th, 2010 01:25 PM #707Finally nakuha ko na paj ko galing central diesel ok na ngayon di na hard starting at wala na rin yung white smoke pag first start of the day at bumilis na takbo at lumakas hatak:D dati parang may pumipigil sa kotse pag paakyat ngayon di na! change oil na lang kulang para mas maramdaman pagbabago
- Oct 2009
- 52
December 12th, 2010 01:33 PM #708BTW para san ang throttle lever? sabi sakin sa central pag papainitin ang makina mas tama daw kung throttle lever ang gagamitin rather dun sa gas pedal.
December 12th, 2010 07:40 PM #709
tanong ko lang po sana mga sir kong sino na po nakaencounter na hindi gumagana yong sa A/T MODE napansin ko lang kanina going to Tagaytay nong nasa SLEX ako nilagay ko sa HOLD MODE walang ilaw sa dashboard ganon din sa POWER MODE tinignan ko both fuse box wala namang nakaindicate doon na for A/T MODE
December 12th, 2010 10:36 PM #710
sir, walang signs of oil inside the rad. plain water and konting rust. suspect ko ngayon rad cap may problem. kasi yung reservoir, nasa low lang kahapon. tapos kanina, pag open ko ng rad, nabawasan, pag check ko sa reservoir, nasa high na yung level ng tubig. hindi bumabalik sa rad.
tapos last week. natuyuan ako ng rad. pati reservoir.
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
