it means sir it will not also solve the rear bottoming and body roll? btw, I saw you wife's 2.5gen pics on other forum site, I like the stance and increased ride height. did you obtained that ride height and stance with the ranchos alone or with the Ironman TBs and Coils installed?
Thanks sir renault, dominee & junerski for the quick reply, yung hook nga ang salarin. Finished with my headlight replacement... Next Grill and rear bumper/reverse lights..Hehehe
+ 1 paj4x4, any performance enhancement is useless if the main part like the springs is not up to standard. I think O-sulee only softens up the rebound part, when the springs compress. But if the springs already sag, it will still sag and bottom out. For sagging springs if tipid mode spacers will fair better I think... but nothing beats a fresh set of springs and shocks.
Dami ko nakakatapat na Paj, ok pa ride height ng ride ko kaya the o-sulee is just for added protection ng spring para hindi madali mag-sag if ever.
* Monty: Thanks sa info, meron kasi dito, size "A'' pala sa paj.
Gen 2 na JDM SMH na kasi. FM ata yung local na may SMH tama ba?![]()
Dami mong mods ngayon ah BG.hehe ayos!
Fasten your seatbelt! Or else...Driven To Thrill!
hindi, OEM all the way pa rin. balak pa lang naman... na-intriga lang din kasi ako, hindi naman siya gaano priority. may neighbor kasi ako may ganyan (although hindi sa paj), pa-obserbahan ko muna sa kanya. supporta rin kasi sa very pricey SMH shocks natin yung o-sulee sabi dun sa website nila. nothing to lose naman.hehe
sirs,
ano ba ang dapat gawin kasi yung center na gauge sa cluster ng mga compass yung may parang liquid ay nauubos, ano ba dapat gawin dun?
Sir ginawa na yang DIY ni sir PK before, search mo na lang yung "pajero inclinometer losing fluid" or use this thread;
http://www.4x4wire.com/mitsubishi/te.../inclinometer/
Nice! Are you also using Ironman shocks? If so, how's the performance.
I'm looking for suspension upgrade for my FM and was quoted by Ironman Phil. 38.5k as the total cost. Here's the cost broken down:
15.5k - Torsions
8k - Rear Springs
15k - 4 Shocks
Haven't really looked at other brands yet, but is this a good deal already. Can you also suggest alternatives where I can bring the cost a little lower without sacrificing performance and durability.
Thanks!
mga bossing question:
my 2.5 fm temp lagi namang nasa middle lang. do i need this lavramon treatment? 2001 model sya and has gone 73k kms. salamats... isasabay ko na rin siguro ang atf palit & other fluids...
ngapala, san may lavramon sa pasig-ortigas area?
salamat ulit!!
so ok pa sya? i read kasi somwer dito na marami nagpapalavramon, baka kako preventive maintenance para sa fm ko para iwas laki gastos in the future...
ask ko na rin if needed ba replace oil ng rear differential (kung meron), if yes tuwing kelan?
salamat crazy boy for the reply.... hirap ko walang alam kasi sa oto ... my 2001fms been with me for 10yrs na kasi, tho nothing major na sira, gusto ko lang ingatan para magamit ng anak ko in the future....![]()
kahit na hindi ka mag lavramon actually ok lang. as long as hindi naman sobrang rust ng radiator mo. pwede mo gawin,
1 remove thermostat.
2 tapos remove radiator drain plug, drain mo muna yung tubig.
3 replace with water,
4 put radiator flush. follow the instruction of the radiator flush
5 remove radiator drain plug again. drain water
6 put water again. to flush out all remaining radiator flush.
7 drain again.
8 return thermostat
9 put coolant. pref. 2-3 liters
10 put distilled water.
11 eat snacks hehe
ok na yan dapat after. DIY ka lang. and do not use tap water after you use distilled water.
