sa pagkakaalala ko. orig sa motorix, 3200 sa front 2800 sa rear. mga a year ago yun. not sure ah.
O.T.
leave my ride parked for at least 4 days every week sa basement opisina
ok lang ba 'to?
should i remove one of the battery cables (read this somewhere)?
di ba masama sa gulong yung nakaparadang matagal?
i used bendix sa brake pads ko. i know it way way cheaper than th eprices you wrote here sa thread.
i think even if you leave the pajero for 2 weeks without starting, it should still be ok. but i think 3 weeks to a month bad na. dapat may occassional starting na yan.
how oftern kayon mag pa align?
saan maayos mag pa align ng pajero
servitek medyo spotty ang service
servitek san juan (turn left after North Park wilson) siningil ako 17k dami kasi da dapat paayos
servitek pasig kapitolyo ala naman sira inalign lang okay naman lahat
nangkang 265/60 18
32 on all 4 cold ones
spare should be 5-10lbs higher kasi we often forget to inflate them
kcboy: san kayo nakabili bendix pads?
rlp: haven't gotten the paj aligned ever since. hehehehe. i think i do need one din.
get ko bendix brakes with installation sa motorcraft sa may banawe. mura n good service. u should have ur pajero aligned atleast once ayear other wise d ganda pudpod ng front wheels mo.
once a year nga rin align ko and every 5k ang rotation including the spare...
masayado anal na ko sa pms kasi sa hirap at mahal ng piyesa at mag paayos
OT: does anyone have list of paj replacement parts, where to buy????
para naman ma stretch ang shrinking pesoses natin
minsan magpapalign ako sa good year. may play na daw idler ko kaya ayaw nila ialign. that was 2 years ago, hinihintay ko pa kasi yung so called wiggle sa steering wheel. hanggang ngayon di ko pa napapagawa. ok naman kain ng gulong ko. mali ba yung thinking ko?
play in the idler can be considered normal so long as not excessive. Maybe those guys were just trying to sell you stuff.
Remember how large and heavy SUV tires are. And your suspension can really take a beating. If parts can't flex, they'll break.
ahhhh. pantay naman tire wear, so i take it it's a good sign.
i'll drop by motorcraft sometime. any specific instructions to get to there, like landmarks? is it on the old banawe side or the other one?
pajero peeps, help me locate surplus relay box for v24 (3dr gen2 pajero - subic).
my headlight dim is intermittent. traced the wirings underneath dash - not the culprit, cleaned the contacts on the switch and steering column - not the culprit, finally isolated the problem to the relay box in the engine bay, sockets tend to get lose in time, kahit nasikipan na yung terminals. i guess hanap na lang nga ako ng relay box.
Hi guys,
M back with another shock absorber query. Has anyone here tried replacing the shocks of his/her Gen 2.5 Pajero with aftermarket shocks (i.e. OME, Rancho, Bilstein, etc.)? What aftermarket shocks did you replace the oems with?
I've read that OMEs improved the ride of the Gen 2 Paje, but then these did not come with adjustable shock settings as in the Gen 2.5. Do the Gen 2 and 2.5 share the same shock absorbers?
Got a friend who's not satisfied with the ride of his Gen 2.5. Mejo matagtag na dati, nadagdagan pa nung nag-18"s siya. When he uses the Soft setting, nababawasan yung tagtag, pero di masyadong ok yung stability.
Thanks.
i think old man emu shocks are good. my friend recommends it, but he uses a 4x4 hilux (previous model).
i'm contemplating on that too since the stock 3-way adjustable shocks of our gen 2.5
is starting to leak.
if the gen 2 has the adjustable shocks, then yes, they share the same ones with the gen 2.5.
ours naman is starting to go soft na with the ride. the current hard setting only feels like the medium setting when it was new.
i saw somebody selling their gen2.5 oem shocks...try checking the for sale section or classifieds ofthe ff sites......kotse.com, autoindustriya.com, mymitsuph.com. kita ko 12k lang daw. mura na yun sobra eh. a pc of the gen2.5 adjustable shocks cost 8k a pc. kindly look for it. it's a great bargain ifthe shocks are still ok.
