ano ba stock tires ng FM?
taz13, kung gusto try ko magtanong dito kung may stock. padala ko sa manila near banawe area.
patricksxy, impossible makita sa pics kung ano sira, kailangan icheck yan ng mechanic kung saan may alog alog. sure na ba sa gearbox galing yung leak?
tanchu, stock ng early models bridgestone dueler HT, yung later model dueler AT na.
aldriech and dudee, try niyo sa carline, 7426651 look for allan, baka pwede ibigay ng 7k each,
[quote=patricksxy;1411990]Hi guys newbie patrick here from alabang, muntinlupa.
quick question lang sirs.. aside from basa sa gearbox & axle boot(s) looking at the 2 pics here ano sa tingin nyo for repairs na? FM 2000 A/T 4m40.
Thanks in advance!
[IMG]http://i47.photobucket.com/albums/f165/patrick***y/9b0881b3.jpg[/IMG]
[IMG]http://i47.photobucket.com/albums/f165/patrick***y/04535c3d.jpg[/IMG]
patricksxy pa underwash mo muna tapos observe mo kung san nangagaling yun oil
mga sir help na naman pinalitan nila ng nozzle tips ko parang ganun parin po pero medyo na eliminate,,, para bang sa umaga kapag start ko hard start siya tapos pa medyo konti nalang ung palya niya pero meron parin ung usok na puti,, pero kapag mainit na po ok naman po.. kapag nga mainit parin tapos start ko aandar naman po agad.. pls help po
jhoma, try mo ganito, either glow plugs lang yan or calibration na, or pwede rin both, pag namamatay pag nastart mo chances are calibartion na.
no baklas and no tools method para macheck glowplug mo.
sa umaga
- turn key to On position. dont start
- dapat naka ilaw yung mga indicator lights AT light, fuel filter light,oil pressure light, alternator light, while nasa On position, yung heater light mauuna mawala but dont start parin.
- after 5 seconds maririnig mo yung click sound ng GP relay sa engine compartment.
- dapat mapansin mo na lumakas lahat ng ilaw ng dash lights after the click sound.
- it means pag lumakas siya nag draw ng current GP mo. which means Ok pa all or most of GP mo.
- but if after the click sound ganun parin ang lakas ng ilaw, patay na all or halos ng GP.
kung Ok GP mo i guess injection pump na yan, hindi yung nozzle tips ang problem, kundi yung O ring sa injection pump mismo. pag napark overnight pinapasukan ng hangin kasi malutong na yung oring, kaya pumapalya, common problem na to ng 4m40,
Question lang po regarding sa fuel consumption ng fieldmaster ko 2003, city driving is 8km per liter, pero pag nasa sctex or nlex even at 100km/hr speed I only make less than 8km/L. if i go even faster it makes worst, mas malakas sa crudo.
what I should do? calibration na ba?
ok naman ang hatak at condition ng makina.
Thanks in advcance
sir, tanong lang po, tuwing kelan ba nagpapalit ng ATF fluid? nasa 77k na kasi sakin.
Thanks
bulmaster, mukhang ok naman FC mo. ganyan din akin, but yung atf mo long overdue na kung di pa yan nagagalaw since new. dapat every 20k kms pag drain refill. pag transtech pwede hanggang 40k kms sabay na atf filter.
nagputik na yung transmission sump ko at nearly 80k kms ko bago pinalitan atf filter. sa lagay na yan i drain and refill every 20k kms.
Guys. na observe ko lang sa pajero ko, kung mag press ako ng breaks softly, parang nag-si-swing ang buong pajero ko... has anybody felt this?
Mahina kasi ako magdrive, max is 50kph lang, and I don't press breaks quickly or hard... kaya na fi-feel ko ang yugyuog every time I press the breaks.
mga sir, question lng po. naputol ung tornilyo ng gulong ko sa likod. ano po ba ginagawa dito? thanks
sir help again pls.. gusto ko pong malamn kung nakaandar mga pajero niyo at pag mainit na tapos binuksan niu ung oil cap or dipstick niyo then may usok na lumalabas sa dipstick, tapos sa oil cap naman po malakas medyo ung usok at talsik ng oil.. anu po ibig sabihin nun po? Pls help naman po.. sino po pwedeng mag expain dito pag ang 4m40 ay blow by na or i mean may sinasabi na ung makina po.. anu mga signs and symptoms po.. pls help po mga sir..
dahc, bili lang ng bagong studbolt, mura lang yun. 100 to 150 lang isa.
I was checking out the head unit plug of my radio in the dash board when I saw a yellow box the looked like a battery pack placed on top of the carpet of the transmission tunnel, me nakakaalam po ba sa inyo kung anu yun? parang computer box yata, although I dont know which it does control or if it is an ecu?I need to know baka kasi kelangan kong bunutin, mag dadag dag kc ako ng heat insulation sa flooring sa harap under the carpet.
Thanks
