mga sir, hingi lang ako ng advice regarding sa adjustable shocks natin. may leak na kc yung 2 rear shocks ko, may mga nag pa repair na ba dito? ok ba sya pa repair or palitan ko na lang ng KYB gas adjust shocks which is 1200 sa carline. 7.5k yung oem.
for me pards i'd rather have it replaced kahet kyb, baka di rin tumagal ang repair eh, and doubtful akong maging kasing reliable siya ng performance ng hindi reconditioned if ever ma repair din siya. you might end up paying more kung saka kapa bibile ng shocks when maging busted ulet yung na repair mong shocks.
mga bro, singit lng ako.whats the usual fuel consumtion range of a pajero fieldmaster 2800? im clueless about this. by the way its a 2000 model
also, the smoke of other vehicles is entering our pajero eventhough i close the airvent and all the windows. can i DIY?if not, how much does it cost to get it fixed?
i found a pajero forum and i really wanted to become a member but the problem is, it is not that instant for a pajero owner to become a member. for now patulong naman muna. thanks
taz13, it really depends sa budget, siempre super ok yung adjustable. Kung gas ajust it will be on the hard side. I used it mga 1 month lang and pinamigay ko na
Zososkot kendimann, first welcome to tsikot. try this, pag nasa hiway kayo doing 80kph. Patay niyo aircon. Then pakiramdaman niyo kung may hangin parin sa vents. Dapat nasa closed yung recirculate. Pag may hangin malamang yung foam sa vents ubos na.
thanks for the welcome promdiboy
"Dapat nasa closed yung recirculate" ano ibig mo sabihen sir?
and if ever ubos na yung foam? pano ko i replace?
TIA
tnx sa mga advice nyo. Baka meron po naman kayo pic ng fuse diagram ng FM yung nandun sa engine bay, burado na po kasi yung sa akin. TNX
guys, pinalitan ko na ang stebel nautilus ko ng eto...
stebel gp-2 twin tone air horn!
some pics...
out of the packaging:
eto na siya nung na-assemble ko:
at eto na siya mounted sa harap ng sasakyan:
isa lang masasabi ko dito, mas matining sa nautilus at mas buo ang tunog!
Hello All, It's ben awhile. Again I need your help, Having trouble with my alternator and I tried to look for a surplus at banawe qc. Unfortunately I didn't manage to get one. I end in one of the car electrical repair shop in E.Rod
Pina repair ko nalang, pinlaitan nila yun rotor and diode. Cost 3K and yun hindi parin nag charge. Overnight lang drain yun battery. Battery is 2 months old.
Baka you know where I can get bnew alternator that is less expensive. OEM cost around 27K Thanks!
luma na yan na stock. matagal ko na nakikita yan eh. ang bili ko dyan, 800 lang
mga sir tanong ko lng po. balak po ksi nmin bumili ng 2nd hand pajero field master, ano po ba mga dapat ko iconsider sa pagpili. ano po mga dapat ko icheck. budget ko mababa lang po budget ko. 500k. thanks a lot...![]()
sir, wala pa pong 500k na fieldmaster. kung meron man, mga gasoline engines na fieldmaster yun na malalakas lumagok ng gasolina.
pointers in choosing:
1. handling
2. engine oil leaks
3. a/c system
4. records ng casa kung meron man
5. interior condition
6. engine performance
7. dapat 1 click starting
