sad to say,bumalik na naman hard starting problem ko,considering napaltan ko na glow plugs and ok pa naman charging ng battery ko,baka you guys can help kung ano pa pwede kong pa check.thanks.
*nOxiOus
I had that problem too not long ago, I thought sa drain nangagaling but I was wrong, sa aircon pala that needs cleaning, when the condensed water is naipon it will over flow & spill it to the passenger flooring. Aircon tech. can solve your problem. After cleaning my aircon nawala na iyong basang basa sa passenger flooring ko.
RTS
Ac and janrye, thanks for your kind words,![]()
noxious, try mo muna yung sundot sa drain hose, check mo kung may tumutulong tubig under the car pag naka aircon, kung talagang sobrang dumi na maybe cleaning na nga yan gaya ng sabi ni rts. imho pag rainy season talaga di maiwasan may di magandang amoy sa aircon, carpets din ang isa sa cause ng bad odor, kailangan tanggalin carpet and labhan at ibilad sa araw. and avoid using car perfumes it will stink up your pajero.a temporary remedy for bad smell that I do is I spray lysol or pure rubbing alcohol (on a spray bottle) at the aircon intake, its behind the glove compartment just remove the 2 locks on the sides and spray away while the aircon is running. its behind the white grill, you'll be able to feel the air flow going in.
drake, injection pump calibration. I know how you feel mahirap tanggapin dahil parang ok pa naman ang takbo pag mainit na at kakapalit ko lang ng glowplugs, ganyan din pakiramdam ko dati.the more mo patagalin ang repair, susunod na masisira is yung battery not to mention the engine vibration pag pumapalya, cant imagine whats happening inside the engine pag umaga pa naman nasa baba lahat ng langis. kawawa 4m40 parang sinasakal at di makahinga. when I had that problem I was able to use my mannix auto start, I set the auto start at 3am it will run for 15 minutes, then sa umaga no hardstarting. the trick is start your car every 6 to 8 hours or else hard starting ka,
ako naman pb. ganito ang panlaban ko sa amoy. hindi na ko gumagamit ng glade na nasa aircon vents. ang gamit ko, yun gel na pabango combo with uling. so far so good! maganda ang amoy ng sasakyan kahit na minsan lang gamitin
sa mga jdm pajero dyan, may ishashare lang ako. little diy project ko. ang tailight grills natin, instead of black, ginawa kong metallic silver, style fieldmaster! check this out...
before:
at eto na ngayon:
at eto na siya pag nakalagay na sa pajero
right side:
left side:
sir drake.. check mo din.. kung ok ba electricals mo...
kuha ka po ng tester... (voltmeter)
dikit mo sa positive yung glowplug.. and negative sa body... then ask someone i-turn yung susy para mag heater.. tignan mo kung magreregister yung 12 volts for a while..
mga sir share ko lang po, eto po ang panlaban ko sa unwanted smell sa loob ng kotse, gamit ko na ito sa dati kong kotse, nabili ko ito sa C3 store dyan sa may kanto ng araneta ave at bonifacio for 800 pesos. ok sya at hindi nagkakaron ng amoy kahit maulan. hindi ako gumagamit ng any car air freshner kasi may asthma yung 2 yr old son ko. naka plug sya sa lighter plug
Hello recently aquired a 2.8 fielmaster ’00, and presently I’m thinking of replacing my rims.
E2 yung current setup niya:
current setup ng pajero
e2 naman ang choices ko :
first
second
or maybe even this one
di naman necessarily white colored, what do you guys think?
gusto ko din yung white na 5 spokes, di ko lang alam ang tawag, yung ralliart naman, ang hirap hanapen, nabile na yung sa evangelista na nakita ko at yung sa west![]()
sir zosotskot..
magkano po ngayon yung ralliart spiderweb design? yan po ang gusto ko bilhin eh.. kahit used... hehe
nice din naman rims niyo.. pm niyo ako... pag... bebenta niyo na.. baka afford ko.. hehe
my vote goes for ralliart spiderweb... pero grey...
