Page 308 of 330 FirstFirst ... 208258298304305306307308309310311312318 ... LastLast
Results 6,141 to 6,160 of 6591
    Jun 2004
    #6141
    Quote Originally Posted by bougartt View Post
    Hi tsikoteers..
    I'm shopping around for a second hand SUV and my budget is 600 - 700k
    The choices that fit my budget were the following..
    1. 2003 Trooper
    2. 2001 Pajero Fieldmaster
    What would be the smarter choice interms of..
    - Maintenance
    - Availability of parts
    - Smoke Belching Issue
    - Fuel Consumption
    - Reliability
    I plan to keep this car for another 5-7 years.
    Hope to get some inputs from you guys.
    Thank you.
    as others have said, "X" na ung trooper (as I've heard a lot of horror stories as well on the maintenance side; ride is great though)
    mine's a 2001 FM 4x2 a/t, properly maintained and i'm getting 6-6.8 city and pag highways, between 7.5-12.
    i'm planning to get an LC90 VX3400 a/t. ride is superb (parang crown) and I heard maintenance is easy as well. downside is the FC though * 5-6 city and 9-11 highways (same sa FC ng FM pero petrol cost).
    between the FM and the LC:
    -I'm for the LC if for the ride
    -I'm for the FM if for the FC
    #6142
    there were some local lc90s that came out with the 1kz 3.0liter tirdo disel, now that would be better than the fm pajero, but i really like the pajero for its looks, east to maintain and lots of accessories that you could add to it, now if you are looking for a 4wd, then fm pajeros will only be available from 99 to early00 models...
    Apr 2010
    #6143
    Quote Originally Posted by junerski View Post
    sir try ninyo sa zexel east calibration... its located along marcos highway, sa petron gas station mismo located sa may salve regina hospital...
    contact number 6462661
    sila gumagawa ng mga calibration ng union motors
    salamat po sir.
    Apr 2010
    #6144
    Quote Originally Posted by paj4x4 View Post
    I suggest you go to Denso in Banawe. Maayos sila don. More expensive than the usual tabi tabi calibration shops but you get a quality job.
    salamat po sir.
    Aug 2005
    #6145
    No wonder the 01 Paj FM has the same value as the 03 Trooper..
    I'm pretty worried that I'm getting a car that is close to a decade old.. hopefully the "bullet-proofness" of the Paj is still true today.
    Thanks for all the inputs. I found an 01 Paj that costs 720k is this overpriced?
    Mar 2003
    #6146
    bougartt, mas ok siguro pag nag check ka ng pajero, dapat yung malamig na malamig yung makina, yung na overnight na hindi na start, mas ok pa nga kung mas matagal, yung unang start up will tell you alot about your pajero, baka hard starting=(glowplug or battery), baka pag fire up buga ng black smoke, baka mayanig na makina pag start=(engine and AT supports), baka may ibang tunog(fanbelts or bearings), baka pumapalya (injection pump seals), baka yung idle bumababa ng husto(dapat 750 to 800 rpm lang, pag malamig nasa 700 rpm siguro dapat wag mayanig), imho a healthy pajero should start smoothly, susi lang dont step on the pedal. pag uminit na kasi makina natatago mga minor defects niya.
    May 2008
    #6147
    I just purchased my '99 4x4 last March '09 with about 160k on it for 600k. Topnotch performance pa rin. :showoff:
    Jun 2008
    #6148
    Sir pb..ask ko lang where can i find a reputable pajero mechanic? pansin ko kasi my alog na ang idler arm ko at my "eek" sound sa ilalim, i think near sa lower balljoint. aside from that may leak ng oil near sa propeller, hindi ko lang alam kung transfercase tawag dun? bandang harapan kasi propeler. actually kakapalit ko lang ng goma dun. kaso mukhang mahinang klase ang kinabit ng mga taga baltak. tnx
    Jun 2008
    #6149
    nabasa ko in some threads here na ok daw c joseph, kaso ang layo samen sa rizal. ok ba sa servitek? quezon ave.?
    Jun 2004
    #6150
    Quote Originally Posted by collosus View Post
    I have all my rigs (once out of dealer warranty) serviced at Motorcraft in Banawe. Try it out. Maayos don. Di pa harang maningil. You only have to be very early though as the lines can get long. Tel 024148633 - Owner is Robert. Assistants are Annalee and Beth.
    Mar 2003
    #6151
    colosus, sorry bro taga province kasi ako, cant recommend a mechanic. imho servitek is ok, meron narin sila alignment. para di kana lilipat, pag oil leak alamin mo muna anong oil yan, tatlo lang yan, yellow is gear oil, red is ATF, black is engine oil. usually oil leak galing sa half moons ng valve cover. harap at likod yun.
    Jun 2008
    #6152
    bale pards pb, yung oil is from the rear part of the propeller pala (correction), near sa diff. what do u think of that, oil seal kaya? and magkanu naman ang usual na charge ng servitek sa labor nila sa suspension naten?
    Sir paj4x4: saan po sa banawe ang motorcraft? anu po ang landmark? near them.
    Mar 2003
    #6153
    collosus kulay ng oil?
    #6154
    probably an oil seal on the prop shaft on the diff. unless its gushing down from the tranny.
    I dont know if it will be of use to anyone here, but I tried sa isa kong auto nung mahirap humanap ng oil seal. Is to go to an Oil seal centre, I measured the dimensions of the oil via caliper or bring the sample itself. And the price I paid was significantly cheaper than sa auto supply and it was japan made. They also said in the absence of their stock, they can even fabricate me (minimum of 3 I think) those oil seals I require (industrial grade), though that would be locally. Also they are quite knowledgeable as to the pairing of oils seals, as some oil seals are just dust cover and they have an internal pair, such as those on a power steering box that are sources of oil leaks. FYI lang
    Sep 2009
    #6155
    just had my rig changed oil today, habang naka lift siya ipinatrace ko sa technician kung san galing source ng leak na langis, kasi at first I thought it was from the back half moon, di naman kasi malakas ang leak just a drop or 2 in a week, the technician found the source in the power steering pump areas so I suspect na one of the oil seal or o ring to, kasi parang lagi ngang maitim o basa sa area na yun,...sana nga o ring lang,,
    Aug 2005
    #6156
    Promdiboy, thank you so much.
    I started the Pajero and it blew black smoke when I started it. The owner says that its normal for any diesel suv to do such thing. Is that true?
    I also stepped on the accelerator pedal while it was on Park, and it would nudge everytime i'd step on it. The owner said that it was a sign that the turbo was still strong. I'm so not sure about what ever he says. All my cars are gasoline feed (CRV and Jazz) so I'm pretty stupid when it comes to Diesel SUVs..
    Hope you could help me out.. I also noticed that the Pajero sits pretty low.. As if it was lowered..Could the adjustable "Soft" Suspension mode be the reason why it sits low?
    #6157
    I started the Pajero and it blew black smoke when I started it. The owner says that its normal for any diesel suv to do such thing. Is that true?Mine doesn't, puro carbon deposit siguro exhaust pipe nyo sir.
    I also stepped on the accelerator pedal while it was on Park, and it would nudge everytime i'd step on it. The owner said that it was a sign that the turbo was still strong. I'm so not sure about what ever he says. All my cars are gasoline feed (CRV and Jazz) so I'm pretty stupid when it comes to Diesel SUVs..wala kayang kinalaman turbo dun sir, kaya nga Park para di gumalaw yung car di ba?
    Kung gen 2 & 2.5 yung front height I think is adjustable cause its torsion bar springs, yung rear naman its down to the springs. IMHO
    Mar 2003
    #6158
    pajeri, kakatapos ko lang diyan, dont forget to buy yung o ring in between the PS pump and engine. hiwalay siya sa repair kit ng PS. may pics and info ako a few pages back. pati yung hose kasi pag kinalas hose mag ka crack siya. para di ka balik balik sa bilihan ng parts,
    1 liter pala ang PS fluid na kailangan
    bougart, like what pareng BG said kung 2001 pa yung pajero mo malamang sira na adjustable niyan. silip mo shocks kung oem pa.
    #6159
    mga sir ano maganda gawin sa field master na pumapasok sa loob amoy ng usok ng mga sasakyan sa labas kahit sarado na vent?
    Mar 2003
    #6160
    junkun, check for air leaks muna, spray ka perfume sa loob ng black grill sa baba ng windshield wiper mo sa passenger side. then mag tambay ka sa loob with aircon on. pag naamoy mo sa loob it means yung vents mo hindi na sealed, palit na ng foam.
