Page 203 of 330 FirstFirst ... 103153193199200201202203204205206207213253303 ... LastLast
Results 4,041 to 4,060 of 6591
    Jun 2009
    #4041
    Hello there.
    Mine is 2.8L /FM/Manual,4x4, I seldom use the 4x4 but recently due to flood & wet road, i tried to shift to 4x4, what I noticed is the engage lamp w/ color like amber is always on when engaged to 4x4, is this normal dahil sa matagal ko ng hindi na gagamit ,Im not sure if that is normal.
    I also noticed that the forward green light is busted when shifted to 4x4, how do you change the forward green light of 4x4 indicator, do I need to remove the dashboard?
    Thanks for any inputs regarding this queries.
    RTS
    #4042
    Quote Originally Posted by jru120 View Post
    -CP-05 sir test
    thank you sir. pero nung naghanap ako kahapon, walang maipakita sa akin na cp-05. iba ang pinapakita sa akin, pr-165 ata yun kung hindi ako nagkakamali, at ang mahal pa. sana sa banawe eh meron nyan.
    Quote Originally Posted by RTS View Post
    Hello there.
    RTS
    hindi normal yan sir. kasi it only mean na ang center differential mo eh locked. baka naman sir, gumamit kayo ng 4wd at na-shift ninyo sa 4llc o 4hlc mode? dapat pag ganyan lang, 4h mode lang dapat kasi not advisable ang 2 other modes sa paved roads. tapos sir, kelangan baklasin ang dashboard pag magpapalit ng ilaw. pero madali lang naman yan sir, wala pang 15 minutes ang magbaklas ng dash
    Jun 2009
    #4043
    *Testament11
    Thanks for your response, I will try this afternoon to move or shift the dual stick from 2wd-4wd-4wdlo,etc & find out if the amber light will be extinguish, pag I shifted to normal 2 wd nawawala naman iyung ilaw, only when I shift it to 4wd saka lang nag iilaw(blinking).I wil try the dashboard when I have time.
    Thanks again ,-RTS
    Jun 2006
    #4044
    [QUOTE=testament11;1276192]naku sir drake, kami lang ng erptas ko ang mekaniko niyan. kaya naman kasi namin ma-identyfy ang problema at kami nalang ang tratrabaho.
    thanks testi.recently na experience kong nag leak yung sunroof ko.eventually pag bukas ko sobrang dumi and naipon yung parang putik sa loob.ginawa ko nilinis ko mga railings and drainage and put grease ulit,hopefully di na mag leak.though parang may na vibrate dun sa glass pag naka drive ako,weird.pag nagbabawas ba ng tubig radiator ko may tama na yung water pump?araw araw nag top up ako ng tubig,wala naman butas yung radiator hose.
    #4045
    sir drake, tumulo na naman ang sunroof ko. wala naman bara dun sa drainage ng sunroof ko. pero ang possible culprit ko, eh yun goma na ang may sira. imagine, sa tagal na ng sasakyan, malamang worn out na ang goma. baka one time nga, papalitan ko na yun goma nun at yun motor ko, may kahinaan na.
    re: water leak mo sir, have you tried checking yun mga hose niya? baka naman may butas na rin yun hose nyo sir. pag wala, check water pump. pag yan basa, yun na problem mo. possible na yun o-ring nun eh bumigay na. hope this helps...
    Mar 2003
    #4046
    testi. pm-165 htk kitahara. 400/pc na dito.
    #4047
    ahahay! ang mahal na pala! kung ganun tama na pala ang napagtanungan ko! anyway, salamat ng marami bro pb!!!
    Aug 2007
    #4048
    post ko lang pic mo ah taz13.
    taz13, kailangan mo talaga bumili ng mahabang screw driver with magnetic tip. its a pita to to screw it back together, sa mga tiangge nakabili ako ng 30 pesos na long philips screw. turo saakin ni PK peel the front sticker para mas madali. pwede mo pa malinisan yung loob. yung 2 sockets ng bulb kayang dukitin sa likod ng daliri. hanggang diyan lang talaga yan. kapa ang dukot nalang, pag nabalatan m, why not try and put one of your leds inside and just wire it diectly, maluwag naman sa loob niyan baka maganda kalabasan,
    heres my before and after shot. cleaning and change to leds , both were shot in in total darkness using my phone cam,
    before both bulbs still ok
    after
    testy, sorry di ko rin alam part number, nung sinabi ko lang din 4m40 alam na sa auto supply.
    sir, ganito din problema ko. ano po bulb gamit pang palit nyo? thanks
    Jun 2006
    #4049
    thanks testi will do.regarding sa goma,meron kaya yung auto glass shops na goma for the sunroof,para mapalitan ko na rin.saka yung vibration ko pala sa glass ng sunroof nangyayari kapag nakatodo sara sa sunroof switch.nakita ko lang kanina.kaya leveled lang ang pag sara ko.pag nag leak pa papa seal ko na yung sunroof para di hassle.
    #4050
    last option mo ang ipa-seal ang sunroof mo. better have it fixed. ako kasi, kung ano ang mga nasa sasakyan ko, eh essential. kaya nga yan nilagay kasi may purpose yan. plus porma din kasi ang sunroof pero hard to maintain gawa ng tulo. kung mapapaayos mo, sabihan mo ako ah para ako din magpaayos
    Jun 2006
    #4051
    cge,ikaw ba yung nag inquire sa heater plug?nagtanong ako sa pemvew kanina htk brand,400 each.
    #4052
    oo bro, ako nga. pundi na kasi ang 1 heater plug ko
    Jun 2006
    #4053
    yan din ang cause ng hard starting ko,may pundi na rin na glow plug.though iniisip ko na paltan na yung 4 kasi di ko alam history nung previous owner .nga pala nag palit ako ng temperature sensor dati,nakakabit ba naman ay pang honda,kaya kinabahan ako sa mga pyesa ng pajero ko,baka di compatible yung ibang nakalagay.
    Mar 2003
    #4054
    My compass led upgrade,
    before, both bulbs are new oem
    after, white led
    janrye, I used led sa aircon controls.
    Aug 2007
    #4055
    Quote Originally Posted by Pajoz View Post
    +1 Vikoy
    All i can say is im also a satisfied Joseph Atutubo customer...he treats your pajero (or car) na parang sa kanya...
    Summary ng ginawa nya sa Pajero ko..
    Body paint + EUDM trims (looks),straighten rear right side bumper (nasabit kasi) change injector nozzle, a/c condenser fan, shifter lever bushing change, change ATF, Filters, Change oil+filters, Belts, Radiator hose, Clean tank (kasi madumi at may tubig) tune up....marami pa (di ko makita ung lists..hehe)
    Result..smooth ride and handling, nawala na ang mis shifting, tumahimik ang andar, at di na mausok..
    Again ibabalik ko pa for another job - change dashboard and rewiring...
    Before..
    After...
    sir, san po kayo bumili ng rear lights nyo? puti na ang signal light. ganda
    Aug 2007
    #4056
    after, white led
    sir, san po tayo makabili nya? madali lang ba palitan? thanks. 1996 pajero po sa akin. will post pix
    #4057
    sa motorix sa banawe ako may nakitang euro tail lights. 1800 ang 1, so 3600 per pair yan. i dunno nga lang kung original o replacement, pero most likely eh replacement lang yan
    #4058
    hello. san mkakabili ng altimeter, compass and inclination meter cluster nung pajero? gusto ko kase palitan yung instrument cluster na yun ng pajero ko.
    #4059
    guys, share ko lang ang ginawa ko last sunday. sana magustuhan ninyo eto
    from black tail light grills:
    to
    metallic silver tail light grills:
    DIY repainting lang ginawa ko dyan kasi mahihirapan ako maghanap ng tail light grill nyan sa market. kaso ang sad news, pangit ang pintura ng left side kaya uulitin ko. yun right side palang ang naikakabit ko
    Aug 2007
    #4060
    fuel filter warning light is below x1000 rpm medyo naputol siya sa pic. pinaka left light sa tachometer, beside the low oil pressure warning light. never ko pa napailaw yan.
    lakas ng ilaw. ganda
