Results 1,061 to 1,070 of 6591
March 16th, 2006 02:26 PM #1061
USDM, Mas gusto yong Gen2 kasi yan lang kaya ng budget ko.
All White nga ang rear fog ng Montero
- Aug 2003
- 317
March 17th, 2006 02:28 AM #1065
pajojo, i had to swap our bench seat with a forward-facing from an ex-JDM unit. same mounting holes naman so no issues.
question lang guys...
would adding a turbo timer be enough to kill the starter ng pajero? or did they wire it incorrectly?
went to wizzards kasi to have the timer installed since they do electrical stuff...then biglang sabi nung mechanic na sira na raw starter. pulled it out, di raw kaya ng palit ng carbon brush(es). what happens now, with or without the timer (to go back to original settings), is iilaw lahat when you try to start it, pero you don't hear any cranking sound.
di ko lam, hay. hirap mag-isip if the started just decided to go kaput at that moment or may nagawa na mali yung mechanic. asar.
March 17th, 2006 10:47 AM #1066
AFAIK, starter's dont just die, you will experience symtoms of slow crank and sometimes click no crank and click sobrang mabagal na cranking pag ganyan hinde sa carbon brush yon. I hope na hindi mo pa pinalitan ang strter mo. Kayang i-repair pa yan kahit sa casa they do repair of starter's. Bakit may umilaw while starting may wrong connection and hindi na nila nabalik sa orig setting.
Yong 91Pajero namin wd almost 300k on odo reading hindi nasira kahit minsan yong turbo so sa tingin ko hindi kelangan ng turbo timer ang pajero, hangang sa nabenta na ito hindi nasira. My brother may JDM Pajero sya 88 Model sa seat belt, his been using since yr. 2000 pa, walang problem ang turbo until now ok parin, mileage is 200k plus
March 17th, 2006 10:58 AM #1067
Wouldnt the turbo timer conflict with your car alarm? I mean, could you arm the alarm with the turbo timer doing its job?
- I like the blings on the blue one. Looks like 22"s
- Larshell, i havent seen anyone selling those USDM tire covers locally. pero simple lang nman ang design, so you can have coventry square make you a blank one and diskartehan mo na lang yung "montero" ;)
March 17th, 2006 12:00 PM #1068
pajerokid,
Oo nga no, di ko naisip yon a sanba pwede mag print? he he he
- Sep 2005
- 110
March 17th, 2006 06:56 PM #1069Originally Posted by pajerokid
salamats ho... may # ka ba seatmate? thx ulit!!!
March 18th, 2006 12:30 AM #1070
pwede siya i-wire in such a way that when you arm the alarm and the timer's on, the timer will run the engine muna and after a set time, it'll shut the engine off, and arm the alarm itself...
the casa said they'll try to replace muna the assembly and carbon brushes. i'll followup uli bukas.
Same po. Can't create new thread
Post New Thread
