Page 153 of 660 FirstFirst ... 53103143149150151152153154155156157163203253 ... LastLast
Results 1,521 to 1,530 of 6591
    #1521
    Photo of a typical tire pressure monitor system [they come in different brands but look pretty much the same]: http://www.wkjeeps.com/wk_tpms.htm
    Aug 2006
    #1522
    Mga sir,
    I wonder if anyone can help me diagnose a problem I have with my '99 Fieldmaster. Anyway, napansin ko lang na upon slowing to a speed of around 30 to 40 kph, I hear a whine/groan (whooo.....whooo.....whooo sound) at the front part of the car.
    the funny thing is, if I switch to 4 wheel drive, nawawala yung tunog.
    Has anyone experienced this? Any thoughts?
    BTW, automatic yung unit ko.
    Thanks,
    Philip
    #1523
    I'm planning to replace the stock rims of my 07 strada with ralliart. Can this tire pressure sensor be transferred to the ralliart? Or does the ralliart rims have this since ralliart naman ata ang stock rims ng fielmaster? Many thanks!
    #1524
    Quote Originally Posted by phildg2000 View Post
    Mga sir,
    Thanks,
    Philip
    That happened to me. It happened along with the dreaded 'flashing front wheel icon' symptom so I knew there was a problem with the 4x4 system.
    I just switched it to 4H for about two months since I didn't have time to have it checked. When I finally switched it back to 2H, the problem was gone! hehehe. It might have been a vacuum leak. Some of my vacuum lines were oily and had some sludge on it (maybe the sludge covered up the leak?).
    Mitsubishi claims that switching to 4H (which is designed for road use unlike the off-road only 4Hlc and 4Llc) adds only about 2% to the fuel consumption because whether or not the Pajero is powering all 4 wheels, the front drive components are still rotating at road speed. The front axle does not really freewheel unlike those on old school 4x4's.
    JET,
    Supposedly you can transfer them. But you'd need to replace the gasket if they are not in good shape already.
    Apr 2004
    #1525
    has anyone heard or used ATLAS brand ball joints and tie rod ends??? I plan to use it on my paj, i need a front end rebuild soon.
    Aug 2006
    #1526
    Wow, thanks sir Otep. It's good to know na may ibang naka-experience nito. And I also have the flashing front wheels icon. Similar to your experience, pagbalik ko sa sa 2WD after using it for weeks in 4WD, okay na ulit. then babalik ulit yung ingay so switch na naman to 4WD. Will check the vacuum lines, I guess it's worth a try.
    Aug 2007
    #1527
    Bro need some help sa 2000Pajero ko, may mga leak na A/t nya and plano ko sana ipa overhaul ang engine, saan ko pede dalhin? how much kaya estimated cost?
    Mar 2003
    #1528
    pajero peeps nagpalit na ba kayo ng wheel bearings and repack? nas 91k na kasi mileage ko di pa nagagalaw, wala namana akong naririnig or feel na kakaibang sound. dapat na ba palitan?
    jessie saan nanggagaling leak ng AT mo? sikat na taga ayos ng pajero dito si Mr. atutubo, a few pages back si pajoz nagpagawa sa kanya, super ok daw.
    Apr 2004
    #1529
    nag pa repack na ako, bought my SUVic clocked at 102T kms, did all the recommended maintenance, sinabay ko na din repacking.
    #1530
    Front bearing lang napa-repack ko. Yung rear pressed-in ata yun. Natulog yung Pajero ni woodfire sa shop ni chieffy dati para magawa yung rear bearing.
