Page 303 of 330 FirstFirst ... 203253293299300301302303304305306307313 ... LastLast
Results 6,041 to 6,060 of 6591
    #6041
    sure... sana magkasya.. hehe btw.. mga binili kong led.. puros pang external lang.. tail lights.. clearancelights tsaka mga maplights lang... masyado technical yung sa dash... kaya hindi ako bumili.. i didnt come there prepared eh.. hehe
    onga.. kelan yung next eb natin... hehe
    Oct 2009
    #6042
    basta text mo ako sir pagmay sumobra hehehe dapat itaon natin yong pagluwas ni Master PB dito sa Manila para masilip din natin yong Rig nya
    #6043
    sir PB ano pinag kaiba nung GL-5 vs. GL-4, ang palalagay ko lang kasi is petron GEP 90. Pede na ba yun for both diff and transfer case?
    spec3, diffs 75w-90 yata kung tama alala ko, gl-5 sa diffs the gl4 sa transfer case. forgot ilang liters,
    Ac, daming leds ah,
    map lights, sikwat lang sa gilid, 30mm na festoon bulb
    tail lights, may screw sa sides, kalas buong tail light.
    park lights, may isang screw sa taas, then may alambre na hook sa loob ng engine bay, nasa fender. peanut bulb
    archi, thanks bro,
    Mar 2003
    #6044
    bg, guess ko lang may difference siguro kasi naka specify sa manual yung rating. gl 4 & 5. petron gearoil is gl4.
    rols, all stock lang pajero ko, nothing special. wala ka makikita.
    Dec 2009
    #6045
    Good day mga sirs,
    My family intends to sell our 2000 pajero fieldmaster 4x2 2.8 A/T and buy a monterosport, mga magkano po ang reasonable price ng fm ngayon?
    Isang option din po kasi, gagastus ng mga P100k - P120k to repair and refresh as if brand new and use for next years.
    Ano po kaya ang mas magandang gawin?
    Jun 2009
    #6046
    [SIZE=3]Hi ![/SIZE]
    [SIZE=3][/SIZE]
    [SIZE=3]My dashboard aircon grilles flaps connection are broken, so pag gusto kung itapat sa isang direction I used my finger. I tried to remove it by using flat screw driver but stiff resistance is there na baka puwersahin ko ay lalong masibak. Has any body tried this one before? Baka mali ang aking assumption na it is only the slots hole are holding, baka mayroon screw na humahawak kaya mahirap tangalin. Help your feed back how to successfully removed the grille. Where to buy the replacement ? or should I go to surplus shop. Thanks for any feedback[/SIZE]
    [SIZE=3]RTS[/SIZE]
    Mar 2003
    #6047
    rts, bad news bro, kailangan mo kalasin buong dashboard,
    it should look ike this.
    then buy this 3.5k sa casa
    naka screw yan sa likod ng dashboard,
    y909, get the ms.
    #6048
    PB yung sa side vents sa dashboard na susungkit ba yun? Me putol yun tig isa kong fins sa aircon vents...
    Tsaka bro baka me pics ka dyan ng connector/actuator sa 4wd shift stick ng indicator lights ng 4wd sa dash board? Kapag 4Hlc kasi di umiilaw yung sa amber lights ng diff lock, pero yung green ok naman. Tapos pag 4LLc patay lahat ng ilaw dash indicator. Tingin ko yung connetor or trigger sa 4wd stick marumi, kaya isasabay ko sa pag palit ko ng A/T shift knob & cleaning ng ilalim ng Shift Lever... Thanks
    Lupit ng mga D.I.Y. projects mo Sir!!! hehehe
    BG
    y909, get the ms.
    Mar 2003
    #6049
    bg, di ko napansin yung side vents, pero kasama siya sa dashboard. medyo maluwag sa baba ng side vents (dash speaker area) baka pwede mo madukut. sa 4wd lights di ko kabisado coonections.
    Jun 2009
    #6050
    * PROMDIBOY
    Thanks pal for the inputs re- air vent grille replacement, madugo pala ang labanan , I might as well let the expert do this, malabo na ang mga mata ko at maikli na ang pasinsya sa mga kutkutin. I meet somewhere out there guy from MITs & arrange to service my FM to check & replace whatever needed sa steering gearbox dahil palaging basa ng langis ang ilalim, nag umpisa ito when I change my cluch by some one not familiar w/ Pajero, although nagawa but bara bara bay ang gawa,also baka kayang gawin din iyung busina w/o replacing the entire steering wheel cover that includes the airbag assembly.
    Many thanks again-RTS
    Nov 2007
    #6051
    Quote Originally Posted by rols View Post
    sir paj-man may contact number po ba kayo sa diamond motors baka sakaling may ralliart mags pa cla don para sabay ko na sana pagpinalagay ko yong nabili ko na geolander ht-s 275/70/R16 nakuha ko lang ng 4200 bawat isa salamat po
    You may contact Citimotors, Pasong Tamo at this no. (02) 813-7867
    #6052
    Thanks PB, nice idea yung via speakers ah.
    #6053
    guys.. ask ko lang ano mas bagay na hid sa fogs ng gen2.5 pajero?
    my dad's is color white
    naka hid siya sa headlights 6000k
    naka hid siya ngayon sa fogs 8000k
    nagkaroon ako ngayon extra set ng 3000k.. iniisip ko ilagay sa fogs.. which kaya would look better?
    thanks
    #6054
    Install mo sir AC, then post the pics para ma kilatis natin...
    Quote Originally Posted by AC View Post
    thanks
    #6055
    sure sir blue gambit.. hehe
    btw..
    ano po kaya cheapest quality foglights? ano ba problema sa cheap foglights?
    i have seen foglights just 200 to 300 pesos each.. sa LY sa recto..
    ok na kaya yun?
    ano po kaya problema? sabog yung buga dahil low quality reflector?
    can anyone suggest the cheapest quality fogs? hehe
    gawin ko po sana ganyan grille ko.. hehe... 2sets po kasi h3 ko ngayon na 3000k.. hehe para magamit ko
    hehe any idea what size that is? hehe pero low budget lang sa foglights eh.. what should i look for ba? kelangan real glass? or good chrome reflector?
    pano po kaya malaman kung maganda or panget?
    thanks
    #6056
    btw..
    ok na kaya yun?
    thanks
    Yung nabili ko dati is DLAA, problem nya is madali pasukin ng moisture. Cguro dapat i reseal ng maiige bago i-mount. Nga pla glass din yung DLAA, sa concorde ko nabili, ok naman yung bato ng beam. Realy helps pag sa PIER ako dumadaan...
    Jun 2009
    #6057
    Hi,
    Final word for my FM, the power steering box need to be fix, the quotation sa repair kit plus labor is P 13K, parang namamahalan ako kasi the quotation of zafra is Php 9K plus including wheel balancing. Ano say ninyo mga Bros.???
    Thanks...RTS
    May 2008
    #6058
    Quote Originally Posted by RTS View Post
    Hi,
    Thanks...RTS
    Ingat lang sa Zafra, my dad advised me to stay away from that shop because of their doubtful diagnoses and labor charges. Same with rapide.
    Better check with El Dorado/Motorix (Both OEM suppliers) for a second opinion. Pareho naman may mechanics on duty 'yan. Wheel balancing can be done at Servitek.
    #6059
    thanks sir blue gambit.. magkano po yung dlaa? hehe ilan inch po? thanks
    Aug 2006
    #6060
    mga boss/tsip, kapitan!
    ok lang po ba iengine wash ang 4d56 natin?
    may nakita kasi ako trooper jdm, engine wash ng todo at tutok ang hose sa makina at lahat ng parts sa engine bay, and nagstart pa naman after, considering na may comp box pa ang trooper at walang tinakpan na parts kahit isa.
    sa tingin nyo, safe lang po ba kahit walang takpan?
