kaya magmula ngaun dapat bago magbenta ang mitsubishi ng montero sa mga buyer dapat may screening ng mga buyer para malaman ba kung tanga ung buyer nila para sa susunod maiwasan nila un at wala nang case ng SUA oh kaya lagyan nila ng warning "WAG KANG TANGA TANGA NAKAMAMATAY" exclusive feature only in the philippines.
this could be her way out of poverty. she should demand a lifetime supply of catnip for maybe an outrage of modesty? how dare abs cbn show her in this less than gramorous state?! imagine the shame when her pact see this.
also a daily laser light show visit should be considered as according to sources, shes having the early signs of PTSD.
Watched bandila that started at 1130pm. Pangalawang balita ang sua. Di pa rin umaatras ang abs news.
you're absolutely right. if she succeeds in the litigation, that kitty would definitely be set for life (not to mention high on catnip as long as she lives)
she should get one of those primo ambulance chasing lawyers and sue those peeps and companies to kingdom come. her image has been ruined - especially among her very judgemental furry friends and i'm sure at least one of her 9 lives have been used w/ that stupid incident.
also, being afflicted w/ ptsd is no walk in the park, as you mentioned, so that means she'll be frequenting the hospital. since she'll be spending some time there, she might as well get that expensive lasik surgery to fix those creepy slit eye lenses of hers too. that way she'll purr her way back to normalcy
2 newbie drivers thinking driving an expensive car would make them a better driver. Clearly the reverse lights, brake lights and the tailpipe smoke tells it all - DRIVER ERROR! Goodluck to your multiple damage to property, or better yet blame it on Montero's SUA issue to escape your responsibility to your offended parties.
May stopper ba ang Montero sa pagpalit ng gear?
Parang the flash naman yung pag lipat from R to D given na kelanngan mo pa umapak sa preno at ilipat sa D?
Saan kaya iniwan nung first driver yung gear? P or N?
Letter sent with links to the maliciously edited video (by whom?) and which was broadcasted by ABS-CBN and the full video from TGP...
Hope something positive happens here. We should not tolerate irresponsible media institutions and people who lie on our faces in spite of the video telling us otherwise.
Sent from my Nexus 7 using Tapatalk
Dapat me Safety reminder under the sunvisor sa mga AT na Monty stating the following:
1. Your foot must know where the Brake and Accelerator pedal is.
2. When in D or R mode vehicle will move slowly even though you're not stepping on the Accelerator pedal.
3. There is no Sudden Unintended Acceleration, only Stupid Uninformed A55h0L3$ who mistakes the Accelerator pedal as the brake pedal.
4. Once you encountered an accident, don't blame it on the Sudden Unintended Acceleration issue to escape your responsibility - In the 1st place, you don't know how to drive a Montero Sports. Drive at your own risk.
Have a safe journey ahead...
You mean he intended to move forward talaga? Paano nya nalipat from P to R w/out stepping on the foot brake? or even from N to R/D di ba kelangan mo umapak sa brake?
As per top gear, di daw umilaw brake light nung 2nd driver na? Pwede sa Montero yun? no need to step on the foot brake?
yung arrangement ng shift lever ay P, N, D, R
checking the video,
1:50 bumaba si driver 1 (either nasa P or N)
1:53 sumakay si driver 2
1:57 kumambiyo ng R (reverse light lit up)
1:58~59 umusad slowly paatras (either di pa siya nakaapak sa brake or gas pedal)
2:00 umarangkada paatras (obviously ang inapakan niya gas pedal thinking na brake)
2:01 nag panic kumambiyo ng D (still nakaapak sa gas pedal)
2:02 umarangkada paabante
2:04 bumangga sa mga kotse na nakaparada
2:05~07 umuusok yung tambutso (meaning nakadiin sa gas pedal)
2:08~09 lalo pang kumapal yung usok (lalo pa idiniin ang gas pedal thinking na brake)
2:10~11 huminto
2:13 umilaw si brake lights
2:15 bumaba si driver 2
2:06~08 makikitang run for your life si cat...![]()
According sa manual ng montero sir
From P to R- the lock button must be pushed while the brake pedal is depressed to move the selector lever.
From R to N to D- the lock button need not to be pushed to move the selector lever.
From D to N- the lock button need not to be pushed to move the selector lever.
From N to R- the lock button must be pushed to move the selector lever.
From R to P- same as N to R.
Ahhh so P R N D din pala. Ang labo ni monty_GTV
If ganyan nga, for sure sa N iniwan ni 1st driver yung gear.
Si second driver instead na sa brake naka ready yung paa eh sa gas naka ready, akala nya sa brake. Pag lipat sa R umatras ng dahan dahan, pinisil yung gas na akala nya break kaya umarangkada paatras?
Though make me wonder, bakit kelanagan pa nya umabante? parang ang first instinct mo is to get out of the vehicle right away and tingnan kung may tinamaan kang tao. Maybe nataranta? gusto ilagay sa N napa sobra sa D while still thinking na naka apak sya sa brake na gas pala?
Na confused tuloy ako kung pwede sa Honda N to R w/out stepping on the foot brake.![]()
Ang bilis ng pag shift ng gear from reverse to forward less than 1 second lang, kaya ba ng driver ng ganoon ka bilis ng shifting gear?
