ergonomically designed as per the "average" human measurements of people in the region, say for asia. of course the design process will not be from zero, copying from a previous model (that was designed also) will do.
what i am saying is that, kung sobrang lapad ng paa ng driver ng montero na yun, aba e talagang sasabit nga ang paa niya sa mga pedals. anyway, it doesn't matter naman, yung isang video (TV patrol north, yung ilocano yung dialect) na napanuod ko at nakapost din dito, kahit pa i-floor yung accelerator ay hindi aarangkada basta nakatapak sa preno.
DTI Expert/comedian Witness...
^^^Face palm...
Alam namin sir ang meaning ng redundant sensor. Ang tanung namin, saan part ng makina merong redundant na sensor ang sasakyan.
Kasi kakabasa ko ng repair manual ng Toyota, wala ako nakikita na naka redundant na sensor. At sa totoo lang, di lang sensor ang ginagawang redundant if you want na masiguro ang safety, pati mga harness, ginagawang redundant yan, mga brakelines ganun din, etc.
Di ko ma-imagine na yung TPS, MAF, MAP, O2 sensor, crankshaft positioning sensor, accelerator pedal sensor, lahat ng sensor ay dalawa, sigurado, lugi ka sa maintenance at ang tendency rin natin, kung sira yung primary, i-swap natin yung secondary huwahaahha!
Bakit kaya ang tindi ng mga nakuhang experts ng DTI. Lagi ko pa man din carwash si monty. Lol. Oh ito.
2013 santa fe. Bakit di ito pinuputakte ng balita? Hahaha. Di na ako magtataka kung after ng mitsu hyundai naman. 😂 langyang media yan. Santa fe wuut ah.
I am very familiar with engine maps. I've tuned cars on the dyno.
Also: You have to read up on the tech. Vehicles do use redundant sensors for electronic controls.
During the Toyota SUA hearings, it was made public that electronic pedals use two sensors.
Toyotas sensors are set at different voltages. One runs from 0.5 to 4.5V. The other from 1 to 5V. They will always be reading different voltages through the range of motion of the pedal.
Some manufacturers use reversed sensors... one reading 0-5V, the other reading 5-0V as the pedal is run through its range of motion.
If you have an error in one sensor, or a short circuit between the two, the car throws a CEL and goes into limp mode.
If you want the specifics:
http://www.silent-cities.com/L200for...D5_STEPIII.pdf
Right there. The Mitsubishi 4D5-series engines uses two accelerator position sensors.
Now if only some of the so-called experts spouting nonsense on air would spend at least half-an-hour familiarizing themselves with data that is so readily available...
*as a side note, regarding engine sensors, there are those that are both redundant and non-redundant... thanks to stored fuel maps, most engines can ignore O2 sensor readings (easy way to prevent an ECU from "learning" around fuel map tuning), simply defaulting to the "normal" map rather than adjusting short term (and eventually long term) fuel trims around changes in air-fuel ratio as measured at the exhaust.
On the intake side, most engines use a single MAF or MAP sensor, but increasingly, modern engines are using both the Mass Air Flow and Air Pressure sensors to fine tune combustion.
Other, simpler sensors have no redundancy... crank and cam position sensors... have no back-up. Manufacturers expect these simple sensors to last a long time, though, as those of us in the Ford Club found out, the cam position sensor is a PITA when it starts acting up.
You have to look up the videos for that, too. No manufacturer produces a car that can accelerate itself if the driver is pressing on the brakes.
You can spin up the rear tires of a really powerful car while standing on the brakes (the Mustang comes to mind...), but the car still won't move. In a braking situation, there is more traction on the front tires, and this will slow the vehicle down. The brakes might overheat before they stop the car if it is going full bore at high speed, but this is obviously not the situation in the parking lot.
Again, the women on the highway, that's another matter. If the SUA occurs at speed, the brake fluid can sometimes boil if the driver does not hold the brakes down hard enough to stop the car right away.
Ergonomic issues are possible, but the Mitsubishi pedal box is not categorically different from most Japanese pedal boxes designed in the 90's / 00's. Pedal entrapment or sticking may be an issue, but having driven a lot of Monteros and Stradas, (and Forts, and Hiluxes, and D-Max/Alterra/Mu-X/Trailblazer/Colorado, and Everest/Ranger, etcetera ad nauseum), I can tell you they're all pretty much similar.
The one ergonomic gaffe, really, is the straight shifter... but most cars on the road use straight shifter gates. Very few use stepped gates, nowadays (or the even more bizarre J-gate from the Jags).
Any years that are more common? Was looking up this issue while doing this month's Used Car article. I knew it was a common issue, but I didn't know it happened as early as 30k!
Fact: The brakes are stronger than the engine. Check out these links:
The Trouble with Unintended Acceleration
https://www.youtube.com/watch?v=NOMYjiCiTYg
Of course the brakes will eventually overpower the engine and will take a bit longer on a torque y engine.
Let's put things in context... SUA ka sa kalye or parking areas dito sa pinas, I don't think your brakes will be able to stop you in a nick of time. That's why they developed the brake throttle override.
that person could be refering to an interchange of the floor mats that could possibly result in entanglement of the accelerator pedal after vacuuming the interior of the car which is part and parcel of a car wash service
some cleaners are not familiar with proper shape of the floor mat for the driver side or simply haphazardly return the mat without bothering to check. the mat for the passenger side ends up into the driver side instead
May tanung ako mga paps, may idle up tayo di ba? At di mo kailangan ang pag apak sa accelerator, para tumaas ang throttle mo, so it just means na ang nagpapadala ng data sa throttle mo ay ECU based sa map nya lamang na based rin sa nababasa nya sa external sensors except sa accelerator. Di kaya may sensor/s na nagpapadala ng erroneous data sa ECU para RPM nya ay isagad pataas?
From full stop ba yan? Any car will not move from full stop with brakes on and accelerator floored.
Iba ang tumatakbo na ang sasakyan ha. Mas mahaba ang stopping distance mo pag apply mo nang brakes with full open throttle. Di hamak na mas shorter stopping distance pag may brake throttle override ang car mo, para kang nag neutral nyan then punch the brakes.
