Results 91 to 100 of 4959
- Aug 2006
- 37
June 23rd, 2011 08:51 PM #91. in most modern cars today if the car is A/T you cannot start the engine unless the gear is in neutral or park postion. and you wont be able to change the gear if you are not stepping on the brakes from P to R then N to D yan ang mga safety features ng car today . sometimes kung sanay ka sa A/T then gumamit ka nang manual bigla it is very easy to loose your sense of footing . i hope human error nga lang since car defect yan pwedeng mangyari satin lahat .
Registered User
- Mar 2011
- 276
June 24th, 2011 10:14 AM #94fyi: in MS invecs II you can shift it into D from P without stepping on the brake as long as you are pressing the button on the shiftknob.
that's their design but it really depends on the driver, like me i always step on the break first coz i used to drive on a car with a/t features like what you posted.
June 24th, 2011 12:56 PM #95
That is true, but the engine will not start if the lever is in N.
There is also a reason why all new vehicles comes with a hand brake.
If the driver doesn't know the use of these safety gadgets , then he is not qualified to drive.
So don't let him drive. In western countries, during driving test, there is a demerit for improper or failure to use the hand brake when necessary.
June 24th, 2011 01:28 PM #96
car owners should always take the time and patience to read the owner's manual to avoid accidents due to unfamiliarity with their vehicles especially the transmission system
Registered User
- Mar 2011
- 276
June 24th, 2011 03:54 PM #97
- Jul 2010
- 57
June 24th, 2011 08:41 PM #99Nai-experienced ko po ang nagsabay yung brake at gas pedal sa GTV ko nung pinalitan ko ng sport pedal kasi pagkalagay about an inch lang ang difference ng both pedal kaya pagapak mo ng brake nakakasaby din ang gas pedal at nag ha-high revs buti na lang naka park na ang tranny ko, it was happen many times during parking before stop engine. Kaya mga kasamang monti owners check nu mga pedals at kung maaari paglayuin mabuti. At huwag gumamit ng malapad na shoes during driving.
- Dec 2009
- 129
June 24th, 2011 09:20 PM #100ganyan din sa saudi pag kumuha ka ng lisensya kahit anong galing mo mag drive pag nakalimutan mo i hand brake pag baba mo bagsak ka sa result.
I want to be clear that I'm mainly against just putting in water (deionized, distilled, or tap -...
Coolant...
