Page 11 of 134 FirstFirst ... 7891011121314152161111 ... LastLast
Results 201 to 220 of 4966
    Folks in south america also get the ms in LHD form.
    Yes, that could be a possible benchmark start. But to help kill the theory of the local Phil units having unique electronic, electric, or mechanical fault(s), we need to isolate any differences between possible benchmark countries. We need the south american LHD units to have the same specs, assembled at the same plant, using the same electronic components, components manufactured from the same support plants, and ECMs programmed/configured the same way, with those alleged "faulty" units supplied for the Phil market. If so, then this would then support the theory that all Phil cases were driver error.
    Vietnam and Russia also has the LHD form of MS.
    Apr 2012
    Hi guys! I just wanted to share my family's experience with the Sudden Unintended Acceleration phenomenon of Montero (you can find the story here Montero Sudden Unintended Acceleration). You may have already heard about it, because someone posted the link to the Manila Standard Today article written by Atty. Jimeno here.
    Anyway, the accident happened to my parents. Thank God both of them only sustained minor injuries. I can very well understand why there is a prevailing skepticism towards the SUA phenomenon.
    My dad is 56 years old. One can easily conclude that since my dad is relatively old, driver-error must be the reason. But on the other hand, my dad has been driving since he was 16. Does that make him an expert driver? NO. Since his old, does that make him any less of a driver. NO! I beg to disagree that age should be a factor in determining whether or not a reported SUA accident is true.
    Let me quote a statement made by Dr. Antony Anderson (a fellow of the Institution of Engineering and Technology and of the Institution of Diagnostic Engineers) regarding sudden unintended accelerations: "...These two possibilities—driver malfunction and electronic malfunction—are mutually exclusive, Anderson points out. Proponents of the “driver pedal error” hypothesis contend that where no physical evidence of a failed electronic component is found after the event, there could not have be an electronic malfunction and therefore the only plausible explanation is that it was the driver that malfunctioned. This is an example of the fallacy “Absence of proof is proof of absence,” Anderson argues. In fact, he says, “Absence of proof is not proof of absence” as intermittent electronic malfunctions do not necessarily leave permanent traces behind them after the event and may not be reproduceable on demand.”
    Let's keep an open mind guys. We are entitled to our own opinions. But surmising something as untrue despite us not being the ones who experienced it is unfair.
    Oct 2011
    Quote Originally Posted by johnachua View Post
    Grabe ang damage. nangyayari pa rin ang SUA to this date. may findings na ba ang Mitsubishi regrading this? I think they have the way to check and determine if the car indeed "roared" at high rpm para malaman kung ano ba ang caused.
    Feb 2007
    Impressive first post sir, thank you for your reminder.
    Think safe, Be safe and Drive Safely everyone.
    Aug 2004
    Absence of proof goes both ways.
    And I have issue with this declarative statement:
    Just because the driver does the wrong thing, does not mean that the vehicle is not acting strangely... and just because the vehicle is acting strangely, does not mean the driver is doing the right thing. Mutually exclusive suggests that an accident must have a single cause. This is not true.
    We try to keep an open mind, but an electronic malfunction cannot affect the braking system of the vehicle, because it is a completely different subsystem, and the only electronic portion of the braking system is the ABS.
    Apr 2012
    In the context of the statement made by Dr. Anderson, driver malfunction pertains to the error on the part of the driver (i.e. pedal misapplication) while the electronic malfunction refers to a defect in the vehicle which manifests "If the cruise control servo or the electronic throttle servo, in the case of an electronic throttle system, moves the throttle to the open position uncommanded".
    Now about the two possibilities being mutually exclusive, i don't think his statement is wrong. If for example the vehicle indeed has faulty electronic system such that even though the driver does not depress the accelerator pad, the throttle still moves to the open position, then regardless which pedal the driver depresses or whether or not the driver stepped on the brake the fact that the vehicle malfunctioned means that the accident was caused by a problem in the vehicle. Yes, the driver can worsen the situation by not having the presence of mind but it will be never be the fault of the driver if in the first place the vehicle malfunctioned. You cannot tell the driver that "Yes the vehicle malfunctioned but you should have done this or that so it's your fault." On the other hand, if it was a case of an error on the part of the driver then regardless whether the vehicle malfunctioned or not, if the driver inadvertently stepped on the accelerator pad, then accident is clearly inevitable.
    I did not say that there was a problem in the braking system of our Montero. What I said in my blog was that when our Montero surged forward from standstill, i took only 2 seconds before it rammed into a parked RAV4 (distance was approx 12meters only). My dad remembered hitting the brakes but it was already too late.
    Aug 2004
    What year and model of Montero was it? With or without cruise control? (Apparently cruise control is optional on higher end Montys now).
    Jan 2011
    There is one fact that I just have to repeat. The brakes are stronger than the engine, no amount of engine power from a montero can overpower the brakes. I tested this myself and Im convinced. I have to disagree with your post that it does not matter what pedal the driver is stepping and what matters is that the car had a SUA. Please also have an open mind sir, it would be impossible for a driver not to do anything if indeed the car has SUA. He would surely step as hard as possible on the brakes to avoid impact. If he is not stepping on the brake, then he must be stepping on the accelerator and if he is stepping on the accelerator then there is no SUA in the first place. This is probably the reason why all reported montero SUA ended up in an accident. I have yet to hear of a claim that a montero driver experienced SUA but the driver was able to avoid accident because he was able to step on the brake and stop the car. They simply could not since they were stepping on the accelerator, thinking it was the brake.
    IMHO, it would be more believable if the claim did not end up in an impact because the driver was able to apply the brake and stop the car. This case would indicate that the driver was indeed stepping on the right pedal.
    Oct 2011
    probably stepping on the accelerator pedal instead of brake pedal when changing from 'P' to 'D'. kaya bumulusok agad.
    Apr 2012
    Quote Originally Posted by spotdog11 View Post
    Hi sir! I'm afraid you have misunderstood my statement. I was merely trying to explain to Niky why driver malfunction and electronic malfunction are mutually exclusive in the context of what Dr. Anderson said. I did not say that a driver will not do anything if his car suddenly accelerates on its own. So yes I am keeping an open mind.
    Accurate ba ito, 12 meters in 2 seconds? parang 21.60 kph.
    Oct 2011
    baka 12ft. lang.
    neighbor, di ba 21.6 kph lang? kanina kasi parang 21,600 kph ang tingin ko
    Oct 2011
    Good point sir niky. Even the electronics of the ABS malfunctioned, braking system still operates conveniently.
    Apr 2012
    2010 Montero 4x4 GLS SE (vehicles was bought feb 2011). No cruise control.
    Oct 2011
    Sir, may findings na ba ang Citimotors?
    May 2011
    Hay pag ang puno mabunga, binabato lagi. Hihihihi
    Lovin' my '11 gls-v. 25k odo in 1yr. Nyahaha
Mitsubishi Montero Sudden Acceleration Accidents [MERGED]
