I asked my father about this issue since he's the one driving most of the time. And yes, may alog/loose feeling kapag inuuga mo. Pero inunlock daw niya and diniin niya yung steering wheel pababa then locked it again. After that wala na yung alog. I don't know if this is the same issue, but so far wala ng alog sa steering
Yep it's pretty normal for modern cars. Our brake system is equipped with hydrovac assited brake system. Meaning it needs vacuum to have a softer push to the pedal and creating a much stronger plunger hydraulic force to stop the car. Vacuum is only achieved when the engine is running either from a slave vacuum pump piggyback *Alternator or from the intake manifold. Normally if you don't have any leak on the system the vacuum is good for one use of vacuum assisted brake without engine running. If you turn off the engine with your foot off the brake pedal it should retain the vacuum good for one use, if it doesn't then there's a leak on the vacuum hoses. or the brake diaphragm.
eto naman 0-100. ecutek tuned, k&n filter, egr blanked, oil catch can, throttle controller
montero sport 2016 - YouTube
wow even with ASTC ON. You still got htose figures and can hear thise wheels screeching. Zix you use the paddle shift at his test run? Noticed the launch rpm*1500
ano ba ang may alog? yung steering wheel? or yung steering itself? meaning may play at hindi smooth ang takbo kahit straight or during turns?
kasi kung sa steering wheel and was rectified by readjusting the sterring wheel position, baka may maluwag lang na part.
kung steering itself, ibang issue na yun.
so far, haven't experienced any of the two in my MS.
Iba pa ata yung issue boss. Hindi pa din clear kung panong alog. Pero yung samin baka loose lang yung pagka lock ng steering wheel kasi okay na siya ngayon and hindi naman nagviveer sa ibang direction kapag binitawan mo yung steering wheel while driving on a straight road. Meron thailand thread about the issue pero hindi ko na tinuloy basahin, dudugo utak ko sa google translate.
Si boss kreme ata naeexperience niya to. I just read it from the jerky transmission thread. Baka ma explain niya dito kung pano yung alog.
http://www.caradvice.com.au/431436/f...nissan-patrol/
in this review a stock 4x4 monterosport was able to clock a 9.6 seconds 0-100 sprint, while the mux with 177 ps and fortuner 2.8 gd engine registered a figure of 11 seconds respectively.
Kelan kaha maglabas ng manual trans ang montero sport 4x2.
Need advice. I want to upgrade my gls 4x2 halogen lights to hid. Do i need to get retrofits? Or changing it to hids is just fine since they already have projector housing? Anyone with base gls have done hid upgrade yet?
