newbie here. Nag stuck up
Yung electecronic parking brake ko and umiilaw na parking brake service required. Ang layo namin sa casa kilangan pa tawid by barge. May idea kayo anong sira and may mabili ako parts? 2016 montero gls yung unit ko TIA
Report mo sa casa. Dapat sila or ung insurance mo mag tow papunta casa nyan.
BRAKE SYSTEM SERVICE REQUIRED ALL NEW PAJERO SPORT - YouTube
Call your insurance so towing can ba arranged as most comprehensive insurance has coverage for towing.
Sent from my SM-G920F using Tsikot Forums mobile app
Hello po. Gusto ko lng malaman ano po ginawa sa montero nio after nung nag bblink na parking brake service required.ganun din kc nangyari ngaun sa montero ko.tnx
Bring to your nearest casa/dealer if your unit parking brake mechanism is still on disengage status. That means you can still drive your unit while it displays blinking parking brake require. Its related to the sensors of e-parking brake. Someone posted here before happens to his unit. He brought to the casa and the cause as per SA was the sensors got wet... I hope your unit still under warranty.
Mga tsikoteers napansin ko lang lately na kung papaakyat ako sa steep road at naka dual on ang AC parang ang baho ng krudo galing sa labas ay maamoy sa loob although naka inner circulation ang AC ko. May naka experience nabang ganito? Nasa 2500 kms pa ang natakbo ni Monty ngayon.
Sir sinagot na dito yan eh. di ko lang matandaan kung ano page..pero related sa amoy na pumpasok galing sa labas, ang parang explain eh ganito once nag exceed na un lamig nia sa loob ng car dahil manually adjusted by us, so magexceed un lamig base sa auto temperature ni MS, nag aauto open daw un AC recirculation para may pumasok daw na hangin from outsde to neutralize or to meet un auto termperature ni MS..sana tama to sanabi ko.hahaha. napansin ko din kasi to sa GLS ko 2x na may pumasok na amoy galing outside while driving.
Hi po nasolve ko na po itong problem na ito![]()
kailangan lang ipress ng 10-12 seconds yung aircon switch (encircled in red) hanggang may marinig na 2 beeps to disable yung pagpasok ng hangin sa labas if more than 27 degrees ang naiset mo na temp while on full AUTO mode. try niyo guys. Yung yellow line and circle proof na maski naka set sa 31 degrees e AC recirculation parin ang nangyayari and hindi parin kumukuha ng hot air sa labas. Yung second picture actually nasa manual siya kung pano ko siya nadiscover. check the pics po and do this para hindi na magpapasok ng hangin mula sa labas while on FULL AUTO mode ng aircon.
You are welcome ;)
Guys how do i edit yung FIRST post ko sa AC recirculation? nagkamali ako ng na encircle. this should be the revised instruction. tama na yung na encircle ko in red dito
sir jc thanks,sabi kasi sa instruction eh wag daw iistart engine while pressing the red button as well turning on the ignition button to accessories?meaning ba nito just press the ignition button without pressing the break pad at magaapear na ang accessories?newbie sir at first car to kaya wala pa masyado alam..salamat
Pressing the ignition button without stepping on the break does switch on the accessories (multimedia system powers up, power windows work, instrument panel and dashboard light up). Pressing it again without foot on the break switches everything off.
