Page 79 of 210 FirstFirst ... 296975767778798081828389129179 ... LastLast
Results 1,561 to 1,580 of 7539
    Jul 2016
    Quote Originally Posted by ads13 View Post
    search mo sa fb, shark phils
    Thank you sir!!!!! [emoji1]
    Sent from my SM-G925F using Tapatalk
    Sep 2009
    Me nag update na ba ng inav maps nyo?
    Sent from my HTC_E9pw using Tapatalk
    Sep 2014
    Starex kahit yun luma ganyan na noon pa
    _________________________________
    If you are wrong, turn right.
    If you are right, turn left.
    Sep 2016
    Ask kulang po kung may benefit kung magpapalit ng nitrogen na hangin sa gulong? Sabi kasi nila mas gagaan daw steering, is that true. Ano po advantage ng nitrogen instead of normal air lang?
    Oct 2009
    Quote Originally Posted by edwin.tpt View Post
    Ive been using nitrogen ever since.. No effect to me bigat kasi paa ko.. It all depends cguro sa driving style, only consolation to me is when long distance driving, medyo may peace of mind d basta nag expand nitrogen..
    _/_/_/The more things are forbidden.. The more popular they become. _/_/_/
    Sent from my iPhone 6s plus using Tapatalk
    Aug 2012
    Air is already 78% nitrogen. If libre magpalagay, why not. Pero kung babayad pa, wag na. Proper tire inflation is more important.
    With normal air, you lose 1psi per month. Basically you just need to refill air once a month. That is not difficult to do.
    I only use normal air. I have my own tire gauge and portable tire inflator in the car.
    Sent from my D5833 using Tapatalk
    Mar 2004
    It will have benefit if you drive long distance in the highway for more than 2-3 hours daily ... Nitrogen is a bit cooler compared to ordinary air so the tire pressure won't increase so much thereby maintaining ride comfort ... higher tire pressure = harder tires ...
    Aug 2012
    "But this fluctuation in temperature isn't as significant as you might think. A 2008 ExxonMobil study plotted the changes in temperature over the course of various inflation pressures. The lines on the graph were virtually on top of each other. In other words, the change in temperature when using nitrogen was negligible."
    "Based on cost, convenience and actual performance benefit, we don't think nitrogen is worth it. A much better use of your money would be to buy a good tire-pressure gauge and check your tires frequently."
    Should You Fill Your Car's Tires With Nitrogen?
    Nov 2007
    Ano cold tire inflation ng monty nyo? Initially 27 front 29 rear gamit ko. 29 / 31 ang naka indicate sa sticker pero nung sinubukan ko umaabot sa 31/33+ sa long drive and significantly mas ramdam yung lubak. Gusto ko bumalik sa 27 / 29
    Aug 2012
    Quote Originally Posted by Allan023 View Post
    Ilan ang sakay mo? If solo ka madalas, pwede ka naman magbawas ng psi.
    Nov 2007
    Quote Originally Posted by red_one View Post
    Thanks. 2 lang kami madalas. Bawasan ko 2 psi, mas comfortable
    Nov 2007
    Dagdag question, nasubukan nyo na mag instruct sa vulcanizing pano ingatan ang tpms?
    Sep 2010
    . I have checked the tool bag and its content. Based Sa manual may tire pressure gauge pero Wla ung gauge? Have you checked yours?
    Jul 2016
    Quote Originally Posted by Valsky1 View Post
    My tool kit doesn't have a tire pressure gauge either. Kala ko ako lang...
    Gls premium
    Aug 2016
    Quote Originally Posted by jumamps View Post
    Gls premium
    Wala rin yung sa GLS PR ko..
    Aug 2016
    Hi Guys,
    Question:
    Yung parking ko di gaano malaki at need ko igitna yung car sa parking area para makalabas ako ng maayos at yung passenger ko kabilang side. Tapos yung parking ko medyo paangat mula sa kalye.
    Ang pag pagpark ko ay paatras, pagnasa kalagiitnaan na ko at di ako nakaapak sa break at Reverse (tinatantsa ko kasi kung naigitna ko ung pagpark), pag aapak na ko sa Break medyo matigas, parang nakalock. Pero pag umapak na ko sa reverse, umookey na yung sa break.
    Eto ba yung break assist or brake override system ng Monty premium?
    Oct 2009
    Quote Originally Posted by chitomaru View Post
    Hi Guys,
    Question:
    Bro, brake override when brake and gas pedal are pressed at the same time the brake overrides the gas..tested it once talagang sudden brake sya.. Brake assist i think is during emergency it helps you stop your monty quickly..
    And wag mo na pahirapan sarili mo pag park.. Unload passengers first before going in para no worries about the door opening space sa garage.
    Sep 2010
    Is our engine same as that of strada? It appears that the 4n15 engine his timing chain and not timing belt?
    Nov 2007
    8k spoiler from casa, sulit?
    Oct 2009
    Mura na.. Sakin 10700 goes with blacknet rain visor..
2016 Mitsubishi Montero
