Page 88 of 377 FirstFirst ... 387884858687888990919298138188 ... LastLast
Results 1,741 to 1,760 of 7539
    Feb 2003
    #1741
    Ahh so remapping pala Sir ng ECU, is it permanent or could be reset back sa default? What if sa casa tech mareset nila? How much Sir yung ganun remapping?
    #1742
    Quote Originally Posted by Jiggs View Post
    default setting is being saved. then new settings will be loaded. remapping is 30k
    Apr 2012
    #1743
    Quote Originally Posted by zix888 View Post
    egr blanking, occ and k&n.
    nice figures, considering 181 on paper, halos walang drivetrain loss, 179WHP
    thanks bro. kung 181 on paper at 179 sa dyno, negligible na yan. at least hindi nandadaya mitsu sa specs sheets nila
    Nov 2015
    #1744
    Sir the dyno is accurate 178HP on paper, if you convert into PS 181 sya.
    Power converter: bhp, PS and kW
    Power converter: bhp, PS and kW - Driver tools - Driving your car - Which? Car
    TGP, HP/RPM ang ginamit sa power
    While sa brochure PS/RPM naman ang ginamit.
    Feb 2003
    #1745
    ��. Wow if that power increase was purely gained on tuning alone, that 4N41 engine is a real conservatively tuned machine. That's almost 30% gain in HP and 24% on Torque, am wondering what are those parameters na binago ng ecutek. Meron pa yan ibubuga by having Fuel injectors and blowers mods whewww...sweet machine��
    #1746
    Quote Originally Posted by micro24 View Post
    sir 179 wheel horsepower (WHP) not hp
    trailblazer's 2.8 200hp is 180whp (dyno)
    gen2 monty 178hp is 155whp
    gen1 fort 163 hp is 118whp
    Nov 2015
    #1747
    Oops! thanks sir!
    Feb 2003
    #1748
    Are those figures from Speedlab records? Meron kaya for the new Everest 2.2 and 3.2? It seems walang daya ang new Monty now sa advertised power dati pala medyo malayo ang figures��
    #1749
    3.2 ranger(new) 165whp.
    have not seen figures sa everest
    Feb 2003
    #1750
    Sir what made you decide to go for an ECU remapping / tuning instead of the piggyback chips i.e. DP Chips,DT Chip, Unichip. Pls share uour thoughts on this.
    #1751
    night and day ang difference. plus kawawa ang commonrail sa tuning chips.
    #1752
    I second the motion! True from 1st hand experience. Symptoms of which include rough part throttle operation lalo na pag matagal na naka chip.
    Feb 2012
    #1753
    May nakapag try na ba mag lagay ng front prox sensors or camera sa new monts? I'm thinking of installing one, wala lang. Haha. Saka may hud upgrade ba na available sa winterpine?
    Sino na ba may pinaka mataas ng distance travelled? :D
    Oct 2015
    #1754
    ano po ung Montero sport 2016 QX?
    Feb 2003
    #1755
    Sir ano pong brand ng chips ginamit mo and how long before it manifested that observation? Thanks that' s quite a first hand info.
    #1756
    Quote Originally Posted by bulawbusiness View Post
    What I remember nong nagtest drive ako, dapat pag switch mo, car info agad ang nagpapakita. info which are tire pressure, temperature, battery
    nakalimutan ko na yong iba. diba may home button yan? don sa home button magpapakita lahat ng function don. try mo iselect car info.
    pero much better kung ipa-check mo nalang sa casa.
    Update ko lang. I will bring monty to dealer to check "car info" since all info in the display are not working even the compass is not changing th direction.
    Once ko pa laang nagamit sa gabi and i observd that no significant difference ang low and hi beam. Not sure if its because halogen lang and not led. Any same observation?
    Or is it because my hi beam is pointing too high, drove in nlex and it was pointed to overpass not directly in front ;)
    Nov 2014
    #1757
    Has anyone here feel the "tug feels/sound" when going U-Turn or making Hard Turn?
    We tried bringing it kanina sa Casa and they did a test drive.. Their Driver keep on insisting na normal lang yun kasi bla bla bla.. Sabi namin it's not normal..kasi sa ibang brad new cars na nadrive ko walang gnun.
    They will report it daw sa planta kasi kami palang daw nagcomplain about it so far.. so if ever kapag halos lahat daw may ganung feel kahit sa test unit nila. it means it's normal.. how come?
    #1758
    Approx. 3mos. Bago may symptoms pero it depends on the overall condition of your fuel injection system. A friend of mine with an older rig started to manifest symptoms about after a month or so lang.
    Feb 2016
    #1759
    Quote Originally Posted by mcdon View Post
    same tayo ng observation regarding hi beam. tumataas lang yung light pag naka hi beam unlike ng iba naming cars
    Oct 2008
    #1760
    Quote Originally Posted by apt2a View Post
    It's the base variant aka GLS.
2016 Mitsubishi Montero
