Sa balintawak sir pwede mo pa lapitan at kwentuhan yung gumagawa
Re change oil on first 1000 kms..
It seems it varies among dealerships.. Got my unit at Carworld Pampanga, they advised me that there is no need to change oil on the first 1000 kms, only 15 point check; then just top up on the 5000 km.. Regular change oil starts at 10k then every 5k maintenance check..
One of the reasons I got my unit from them, the other dealer in our area insists on a change oil on the first 1K with an estimate cost of Php 5K..
Sent from my D5833 using Tsikot Forums mobile app
Yung na-interview ko na car tech ng Jabez motors, ok lang daw sa 5k na lng magpachange oil and filter. Ewan ko na lang kung papayag yung mga tao sa service. Nasa 800km pa lang ako...
Yes sir, my unit is now running 5k plus kms kaya due to schedule na for PMS.. They did not do any oil change on my first 1k kms, only 15 point check.. Wala naman problem with the performance.. I just don't know if they changed their recommendations now..
Actually, light tint lang allowed ng LTO sa windshield . Medium tint is already a violation.
Para malaman if mahina na ang halogen bulb, turn on the headlights at lumabas ka ng sasakyan para makita mo how it actually lights up the road.
If kulang sa liwanag, replace with Osram Night Breaker or Philips Xtreme Vision series halogen bulbs.
Sent from my D5833 using Tapatalk
Why do you need high beam and low beam sa fog lamps?
I don't even use the fog lamps unless there is super heavy rain.
My other car is a 2012 Montero GLS-V which I find na mas superior sa light output versus sa 2016 Monty ko sir. So i needed the added light output of the modified fog lamps for night drivingTayo naman po ay disiplinadong mamamayan at projector Fog lamps with hi and low beams ang ininstall ni HIDRETROFIT.net (Gary QQ)
No signal because of vkool vk series tint. Saan kaya maganda ilagay yung antenna?
It's a common experience with those who have Vkool tints for their satnavs to lose signal, especially those portable models whose antennas are built-in. It probably has to do with the reflective material Vkool uses to keep the interior cooler than other brands.
A workaround would be to buy an external antenna.
