Results 1,231 to 1,240 of 2693
July 7th, 2014 12:14 AM #1231
Sirs, Di ko po sure kung normal po ba ito or hindi?! yung naririnig ko na parang metal-to-metal contact habang tumatakbo yung monty,
3months na po yung monty namin, nasa 124KMS pa lang sa odometer at bihira gamitin, 2x ko na po ito na-encounter,
(1st nung unang takbo ng monty ng 120KPH sa daang-hari, then kanina sa molino blvd)
pag umabot sa 120KPH ang takbo, after stop, pag takbo ulit, meron na po ako encounter na parang grinding sounds, (similar sa worn out brakes) then, pag naka-park po ako at nakapag-pahinga yung monty ng 1hr, nawawala naman yung sounds,
di ko po sure kung nabigla lang yung monty or hindi normal?!
pero yung handling performance/braking capability, no problem naman...
- Jul 2010
- 844
July 7th, 2014 12:30 AM #1232
July 7th, 2014 01:04 AM #1233
July 7th, 2014 06:32 AM #1234
Sirs, try nyo epump ang foot brake na d umaandar hangang sa timigas na, 40x the most. Check brake reservoir fluid level after. D ko lang matandaan kong ilang km ang natakbo at nawala narin.
July 7th, 2014 11:49 AM #1235
kung under warranty pa, bring to casa and have your brake pads check and clean. since bago pa mga units ninyo, makapal pa mga pads niyan pero malamang hindi maganda lapat sa rotor kaya maingay. one thing to notice kung manipis na yung pads ay medyo bumababa o nababawasan din yung level ng brake fluid.
July 7th, 2014 04:35 PM #1236
for quotations/inquiries i can help kentcitimotors*gmail.com
Posted via Tsikot Mobile App
July 7th, 2014 07:25 PM #1237
Thanks Po Sir mangkas1178 and Sir monty_GTV for the info.
This weekend, try ko po yung pag-pump ng brakes pag engine off, then observe ko po muna,
saka suspected ko rin kasi yung hindi maganda yung pagkakalagay ng pad, if ever na hindi pa rin ito mawala, pa-check ko agad,
Mahirap na baka biglang kumapit yung brake, nasa rear side yung sounds...
So far, ayos gamitin yung 4H pag rainy condition, kapit yung gulong, saka during overtaking, lakas ng hatak hehe
yung lang medyo lakas sa FC.
- May 2014
- 27
July 8th, 2014 06:22 PM #1238hello mga sir,
I have a GLX MT 2014, 2 months old palang. Ask ko lang and confirm kung ganito talaga yung sa GLX MT
1.) Walang warning sound kapag patay na ang engine tapos binuksan mo yung pinto then naka suksok pa yung susi. Hindi ba dapat may warning sound ka maririnig para i-remind ka na naka suksok pa yung susi? or wala talaga sa GLX?
2.) Wala po ba talagang seatbelt light/reminder sa dashboard? Kahit di ako naka seat belt while tumatakbo walang seat belt warning light ako na nakikita sa dashboard. Kahit during bago ko i-start ang engine wala po.
3.) Yung autolock, sa driver side lang talaga sya? Hindi po sya nag a-autolock kapag tumatakbo na tapos tinapakan ko yung break pedal. Kailangan ko talaga sya i-lock sa driver side manually. Ganito po ba talaga ang stock ng MS or sa GLX po ito?
Thanks in advance mga sir.
- May 2014
- 27
July 8th, 2014 06:51 PM #1239hello mga sir,
July 8th, 2014 09:08 PM #1240
1. Ang alam ko wala.
2. Sad to say walang warning light yan pero sa dashboard meron sya at hinde nga lang nagana(sa glsv meron d ko lang alam sa glx). Pero ung kay sir zixx napagana nya ung sa gtv nya. Although dapat meron talaga as part of a safety feature dapat pati kung may nakasakay sa passanger seat.
3. Regarding sa autolock, mag autolock lang siya kapag nasa loob ka nang sasakyan, door closed at once inistart mo tsaka lang siya mag autolock. If naka open ung door tapos inistart mo you have lock it manually. Hinde siya nag autolock habang naandang tulad nang ibang sasakyan. Kahit ung adventure ss namin ganun din. . .
