Results 1,241 to 1,250 of 2693
July 9th, 2014 01:45 AM #1241
As per Sir kik0matsing, walang alarm po once na naiwan yung susi sa off position, (ibang brand ng sasakyan ay merong buzzer/ajar warning), to remind the driver...may alarm man o wala po, a basic sense na once nababa ng sasakyan, remove the key automatically.
Yun din, meron talagang indication sa monty ng seatbelt warning, pero naka-deactivate po ito, pero sa akin is no big-deal,
once na nag-drive lalo kung nasa public road, automatic na buckle up for safety..
Sa autolock, yun nga starting lang talaga mag-activate po yung autolock, once na binuksan, pag sara ulit ng pinto sa driver seat, deactivated na yung autolock, so kailangan i-manual lock, (yung old car namin is naka-feature na pag nakatakbo in a certain speed, activated ang autolock) medyo annoying, pero a good practice na rin, to aware na once na bumaba ng sasakyan, at bumalik ulit,
basic instinct na dapat i-lock ang sasakyan before driving, (iwas sa technology dependent)
- May 2014
- 27
July 9th, 2014 01:45 PM #1242salamat sa reply mga sir, at least now I know na ganun pala talaga sya. This is my 3rd vehicle, the previous 2 were sedans and were all acquired as second hand pero may mga ganitong feature sya that is why I'm under the impression na standard dapat sya and considering that my MS is my 1st vehicle to be acquired as brand new, medyo odd lang na wala sa kanya yung mga ganitong feature. But it's ok, not a big deal naman. It's not being technology dependent, we're only humans hindi tayo perfect of course there will be times that these feature will be of great help for security and safety purposes.
Thanks ulit mga sir
July 9th, 2014 02:28 PM #1243
1) Unfortunately, wala itong feature na ito sa GLX MT non-VGT (kahit sa GLX-V Limited M/T wala din) and we have to live with it. Unlike sa ibang vehicles (like the wifey's Vios 1.3G) meron nito, an audible alarm (beep) can be heard when you open door from inside while the key is still inserted.
2) Wala ring seatbelt indicator sa instrument panel when the seat belt is not engaged to the driver or even sa passenger side. My wifey's Vios has this. Although the alarm won't sound, but after a couple minutes on the run, it will eventually activate. The only thing the MS GLX has is the door ajar indicator light and the alarm will activate after you have run on a distance from where you started when the door was ajar. Another thing, when you leave your car with the park lights on and the key is disengaged from the ignition, an alarm will sound as well.
3) About the autolock, it will only engage when you step inside your car, all door closed, and key inserted and turned to ignition point. Otherwise you have to manually lock it. What I wished was there should have been a manual switch to either lock or unlock it from the inside. The weird this is, the alarm will sound if you close all doors, and lock it from the inside manually.Last edited by leinahtan; July 9th, 2014 at 02:31 PM.
- May 2014
- 118
July 9th, 2014 02:59 PM #1244na drive ko sa Ilocos yung 2014 ford everest 4x4 nung tuesday as service and it doesn't have above features as well, pero parang sedan ang gaan ng manibela nya compare sa monty natin.
- May 2014
- 27
July 9th, 2014 06:29 PM #1245
July 10th, 2014 03:23 AM #1246
- May 2014
- 118
July 10th, 2014 04:11 AM #1247
- Jun 2013
- 29
- May 2014
- 118
July 10th, 2014 11:58 AM #1249
Tsikot Member Rank 1
- Jul 2009
- 4,090
July 10th, 2014 07:05 PM #1250
And also edit option is not allowed anymore :grin:
Problems with viewing Tsikot on non-Chromium...
