Page 134 of 135 FirstFirst ... 3484124130131132133134135 LastLast
Results 2,661 to 2,680 of 2693
    Jul 2014
    #2661
    is it before the engine even cranks?
    it can mean anything, po, depending on one's fertile imagination.
    a recording of the actual sound would be appreciated.
    Thanks po dr. Will try to record po. Sa cold morning medyo malakas po-after 3-5 mins idle run. Wala napo yung noise. Thanks again
    Jul 2014
    #2662
    Should be about normal for an ageing diesel engine...
    Thanks po CVT, possible nga po. Pero just 65K km odo only and well maintained kopo naman. Normal driving lang tapos very seldom *turbo rpm speed. Kaya annoying sounds talaga sa cold start yung noise. Thanks again po
    Apr 2012
    #2663
    Quote Originally Posted by kamote25 View Post
    the "tick" sound are audible enough after switching off. i think nasa 3 ticks yun. i don't know if its the same as what you are experiencing after starting. i don't notice naman sa unit ko. but at 65k kms odo, should not be a concern kung ok naman yung unit mo from the beginning, annoying nga lang. brand new mo ba nabili unit mo?
    Jul 2014
    #2664
    Brand new po Boss. Tama kpo sir,naririnig ko po nga po yung “tik” sound after switching off,3 ticks nga po. Pero yung noise naman po after cold start prang iba po, nasabay sya sa engine rpm specially kapag pumalo aircon po. Thanks po again Boss_GTV; kayo po ba yung nasa youtube GTV channel din?
    Apr 2012
    #2665
    hindi kaya kapag nag-switch on/off thermostat ng AC naririnig mo? hindi ako yung nasa you tube bro, baka si bro Zix yun
    Jul 2014
    #2666
    Akala ko ikaw Boss. Try ko nga po ivideo bukas. Thanks po
    #2667
    Quote Originally Posted by lawrence82 View Post
    hi you can buy in harisson plaza malate
    2nd floor Workstation ata ung hardware na un
    at the entrance left part
    35P iirc each
    kya isang banig 10pcs na kinuha ko
    mtagal nmn expiry at new stock
    kc 2mos ago kinuha ko nkdisplay
    den kareplenish lng nila new
    fyi
    it is energizer
    kc experienced using different brand
    from Ace same size cr1616
    pero didnt function well
    hope malapit ka dun sa harison
    Thanks bro. I found one here in LPC at P150. Pinatos ko na.... The backup remote controller is now working....
    Yes I know Harrison in Malate... HP Boys kami Rati e....😎😎😎
    Jul 2014
    #2668
    Boss_GTV, eto po yung audio recorded.. sana maview po.. TIA
    New Recording 2.m4a - Google Drive
    Jul 2014
    #2669
    dr_d: eto po yung recorded engine noise po. patulong po.. TIA
    #2670
    my guess:
    at cold, metal parts have not yet expanded to operating tolerances. as such, there is bigger space in between metal parts, causing the louder ticking noises.
    when the engine warms up, the space in between metal parts decreases, and the ticking noises decrease or disappear.
    bottomline, "it's normal".
    Jul 2014
    #2671
    my guess:
    Thank you Boss dr. d., you’re really a dr. Thanks again.
    Apr 2012
    #2672
    yup narinig ko. though hard to figure out. parang may nagtouch or something. check mo siguro mga belts baka may lamat na. im not sure though. another doctor here, car dr. Zix might be able to diagnose better[emoji1787]
    Jul 2014
    #2673
    Thanks boss GTV, check ko po mga belts ulit this coming offdays, diko muna pinadiagnose sa casa baka t-belt agad irecommend. 24K yung quote nila last week but they said *80k km. thanks again
    Aug 2006
    #2674
    question lang. napundi na kase yung bulb ng brake light which is p21/5w. bought an led bulb (bay15d) to try kung gagana. working siya as park light and brake light pag naka-off ang engine but once nag start ng engine, full brightness na lang sya so parang nakabrake palagi yung bulb. may fix ba dito or need ng special bulb? kase kung di talaga mag work, bili na lang ulit ako incandescent.thanks sa makakasagot.
    Jul 2014
    #2675
    Quote Originally Posted by heille1221 View Post
    Boss Heille: AFAIK: basta po dual contact bayonet dapat working npo yung bulb. Magkaiba naman po sya ng terminal at wiring. Yun lang po Boss. Happy Christmas[emoji3]
    Jul 2017
    #2676
    Anung mas ok na combo?
    Stock avt headunit + tv box with media player + headrest monitors
    Or
    Android headunit (China budget HU) + Headrest monitors
    #2677
    ask ko lang kung may naka experience sa inyo pag naka incline si monty ay hirap umarangkada paakyat, very slowly ang movement nya paakyat then bibilis na rin, both D drive at manual mode, kya yung kasunod ko panay busina kasi bagal umakyat
    #2678
    Mga paps, meron ba kayo jan ma share na list for 20k PMS? Thanks!
    Jan 2017
    #2679
    Quote Originally Posted by spiderjon96 View Post
    How new is your unit sir? And how hard are you stepping on the accelerator?
    May 2013
    #2680
    Quote Originally Posted by toliptej View Post
    Hi Guys, my MS 2014 Ceiling Sunglass holder cannot be close anymore, can it be repaired? Can anyone refer a me a shop who can fix this? I live in Sta.Maria, Bulacan and use this going to my office in Makati. Does anyone know how much it will cost to replace the whole module?
    I have the same issue. sana may makatulong.
2014 mitsubishi montero
