Page 47 of 103 FirstFirst ... 374344454647484950515797 ... LastLast
Results 921 to 940 of 2054
    Jul 2010
    #921
    Quote Originally Posted by normyline22 View Post
    Same as mine my garmin 255w has the altitude info as well, and the barometric pressure.
    But it would have been better if its automatically adjusted already or can be done with just a simple calibration, my Protrek and suunto watch both has barometer, compass, and altimeter. The protrek was automatically calibrated and is 99% accurate if I will based it on the results given by google earth, garmin satnav I am using.
    If the atmospheric pressure changes you have to reset it as with any barometric altimeter, simple as that. The Casio Protrek has to be calibrated/reset before journeys just like any other barometric altimeter. The fact that you find it accurate is because the MSL atmospheric pressure at your location was same as the time before. In The Philippines the atmospheric pressure does not usually vary a lot; but it does vary.
    Every time you get on a PAL or Cebu pacific flight, the pilot feeds the QNH (pressure at MSL) into the altimeter; and and also gets this QMH (or QFE) from the tower before he lands (as the pressure in Manila can be different than say Cebu).
    Let me explain a little more simply. A barometer measures pressure, but that pressure cannot be converted to altitude unless you know the pressure at MSL or you actually feed it the altitude itself. You need one of the pieces of information fed in to set an altimeter (either altitude or QMH).
    The garmin is a different story altogether as it uses information/distance/time calculation on triagulation from satellites to determine actual altitude.
    Quote Originally Posted by SRGuy View Post
    Walang binigay na conduction permit ang SA namin. Sabi nya invoice lang daw pwede na supporting doc. kailangan pa ba i-request yan?
    Dapat kasi sir kapag brand new meron nang nakakabit niyan sa windshield AFAIK. Request mo na lang din sa SA. Sabihin mo na ayaw mo ng hassle na paparahin ka palagi.
    Sep 2010
    #923
    there's a conduction sticker but you must have a conduction permit. ang hassle if BUAYA yung naka pull over sa iyo!
    Jan 2011
    #924
    ako rin. di binigyan ng conduction.. wala pa daw na upload ng MITSU PHIL(MANILA) sa LTO yung CSR.. kaya di maka kuha ng conduction permit... standby sa bahay yung car ko since last SAT... naglalakad pa punta sa ofis..
    #925
    anong dealer po ba ang ma aadvise nyo near or within QC area?
    baka punta kami sa friday at pa quote para sa 4x4
    Feb 2011
    #926
    guys normal lang ba ung montero pagnakastationary lang na andar parang mausok? normal ba un or ano? salamat sa sasagot... un kasi napansin ko sa akin pagkauwi ko ng akin... or mawawala din yan pagnabreak in na....?
    Feb 2011
    #927
    guys normal lang ba ung montero pagnakastationary lang na andar parang mausok? normal ba un or ano? salamat sa sasagot... un kasi napansin ko sa akin pagkauwi ko ng akin... or mawawala din yan pagnabreak in na....? kahit matagal na biyahe na pagstop over namin ganun siya my usok na lumalabas.... ganun din ba sa inyo? pagtumaktabo ok naman pag hinto ganun....
    Mar 2004
    #928
    Quote Originally Posted by elisher0210 View Post
    parang sakit ata talaga ng 4d56 engine yung ganyan...
    Jun 2003
    #929
    Mine is GLX pero di naman mausok kahit noon naka regular diesel. Try nyo sir gumamit ng V-power diesel
    May 2005
    #930
    VGT owners, are there still very visible white/light smoke coming out?
    I once saw a brand new no plate # yet GLS 2.5 4x2 (non vgt) coming out of the Otis dealer and it was spewing out very visible white smoke as it accelerated ahead.
    Aug 2009
    #931
    guys, may nakapagkabit na ba sa inyo ng rear garnish? yun sa ilalim. pano ito kinakabit? 3m tape pede na ba? thanks
    Feb 2011
    #932
    Quote Originally Posted by boldventure View Post
    ung po ginamit namin pauwi eh~ may usok lang sya pag nakastationary ung sasakyan~it's spewing out light white smoke dapat sana mwawala na un kasi tumakbo na ng malayo kaso hindi parin masakit sa mata ung usok na lumalabas at sa ilong eh 200+ pa lang milage ganun na~
    Jan 2011
    #933
    Quote Originally Posted by bsn1 View Post
    yun rear garnish has clips on the underside, same clips with the rear bumper plus 3M tapes sa taas. Suggest not to use the tapes that comes with the package, use the heavy duty 3M tapes instead...
    Jan 2011
    #934
    Same problem with my friend's Monty (non-vgt) but the white smoke was gone after the 1k PM...
    Feb 2011
    #935
    Sir, a freshly baked bread got out from the oven emits smoke, a freshly baked new engine also smits smoke. Sa akin bumubuga din pero a less dense white smoke tuwing start ko sa engine during early in the morning lang. Meaning to say "nasa kalamigan pa ng makina".
    Don't worry sir, you should be thankful, dahil ang cooling effect timing ng clutch fan ng makina nyo ay to the max ang capacity......just imagine while in stationary position at naka-andar...kaya nyang i-drop at palamigin ang temperature ng makina nyo at a given time.
    If you are still in doubt, you should patiently wait until you will reach the break in run of 1000 KM, dahil mag-palit ka na ng diesel oil. Pero you should demand for a "synthetic diesel oil supplied by casa of course". After the synthetic diesel oil is loaded, start the engine car still is in stationary position.........observe.........and hopefully the result ay, mawala na sana yan.
    Feb 2011
    #936
    kakakuha lang namin ng MS namin~ i will post some pics later~ about the fuel consumption Manila to Pangasinan 500 lang naubos namin~ i'm satisfied sa performance
    Quote Originally Posted by rmsoriano View Post
    congrats sir to your new ride, so it is really fuel efficient talaga, maybe above 16 km per liter of diesel. Enjoy your ride.
    Good Eve Tsikoteers. I travelled from Manila to Urdaneta, Dagupan, San Fernando La Union, and back to Manila. Total fuel consumed 64.3Liters, with total Kilometer travelled of 687kms (798-111kms). So nag average lang ako ng 10.68km/L
    My ride is a week old 2.5l 4x2 monty. Hope consumption will improve after the first 1000kms PMS...
    Feb 2011
    #937
    Quote Originally Posted by QUARTZBRO View Post
    so sir wala po ba problem iyon? kasi dapat diba sa umaga lang po iyon pagmalamig pa makina pag uminit na at tumakbo po mawawalana~kaso ung akin while in stationary ganun po nagspew siya ng white/light smoke kahit mainit na makina at tumakbo na ng matagal pagtumatakbo wala naman pero pag huminto ayon naglalabas ng white smoke na light~
    Dec 2008
    #938
    so sir wala po ba problem iyon? kasi dapat diba sa umaga lang po iyon pagmalamig pa makina pag uminit na at tumakbo po mawawalana~kaso ung akin while in stationary ganun po nagspew siya ng white/light smoke kahit mainit na makina~
    well i think its better to take it back sa casa sir kung talagang doubt ka sa usok ng Monty mo then baka meron silang unit duon paandarin din then compare saka makikita kung may diperensiya witness pa ang mga taga casa
    Apr 2009
    #939
    Ganyan rin yung 4 montero sport GLS 2.5 4x2 (non-vgt) ang nakita kong mausok while in stationary mukhang bagong labas lang sa casa yung isa pero yung 3 with plate number na mausok pa rin kahit umaandar.
    Sep 2010
    #940
    noted white smoke when idling. cant tell if there is still white smoke during mobiling.
    noted same value for barometer
    noted ZERO value on altimeter
2011 Mitsubishi Montero Sport [ARCHIVED]
