Got her yesterday, and i can say that it rides good. The tire gauge for me is the issue because it can't seem to show in the car info. Here are some of her pic.
By bekmanizer at 2011-02-18
the V looks weird. pero bahala na as long as naka vgt na montys natin. congrats bro!
yes sir i like black even if it is very hard to maintain :D, ill try to look for that add on, i also would like to look for the led strips and audi tail lights, i hope they are compatible :D
[SIZE=4]Sir Bigboy2[/SIZE], yong umiilaw na led na kulay blue nagbi-blink lang yan tuwing naka-park ang sasakyan, yan ang palatandaan na gumagana or active ang immobilizer installed sa unit. Kong makita yan sa mag-tatangkang magnakaw ng sasakyan, magdalawang isip sila ngayon dahil your car is equipped with that instrument.
Kindly be advised, bring your unit at report immediately to your dealer dahil I confirm, it is not normal if it is 24 hrs blinking. The normal is while the car is in motion or nasa viahe tayo, THE BLINKING MUST AUTOMATICALLY STOP.
[SIZE=4]Sir Monterick[/SIZE], hindi nga acceptable ang gap nyan between the hood and fender, kindly be advised don't do it by yourself by adjusting those rubber supports. Very sensitive ang casa if we talk about warranty. They are very expert alam nila na ginalaw mo that will lead to the warranty avoidance. My point is they will do fix the trouble pero pag-bayarin ka na sa service.
[quote=locoroco777;1682025]The rubber supporter might just need some turning.....
I've encountered this problem in one of the 2010 stradas the hood wasn't well aligned with the quarter panel....did some turning of the rubber support....it did align....[/quote
Thanks for the tip, but i cant find any rubber supporter that i can turn.. maybe iba na ang mga support ng monty.
Sir, maybe your alarm is set at valet mode... try doing this: put your key on ignition, then press and hold the red button under the left side of the dash board (you can pull it out slightly, and push back to hide)... then the blue light will blink. Your alarm is now activated... and while driving the blue light will go off.
In this mode, when you use your keyless entry to lock your doors, the alarm will be armed and the blue light will blink.
To put your alarm in valet mode: do the same steps... hope this helps
very nice Blackie hehehe
parang di full chrome yung side mirror there something black rubber sa harapan ah
init naman sa mata ng walang magawang mabuti sa kapwa![]()
yup mayroon ngang black rubber doon sir, the guys that got a unit now are lucky kasi sabi sakin ng dealer ko by march or april (forget the month) the price will increase... i hope its not true for those planning to buy in the near future
2011 Montero GT-V in Masuoka Sport Challenge
2011 Montero in Top Gear Philippines
http://www.topgear.com.ph/news/mitsu...e712826140%2C0
